Question about LG LDF6920ST Fully Integrated Dishwasher with 5 Wash Cycles 3 Spray Arms
Water leaking from bottm left front from white plastic vent
Water leak in left front windscreen of 2001 model statesman
it is probably coming in through the firewall some where after being splashed up by the wheels check behind and above the left front wheel for holes
Apr 08, 2013 | Cars & Trucks
Water leaking from vent hose outlet
Does your User Manual say anything about this being likely to happen?
Sounds as if there is a throw-up of water into this hosing in the spin cycle or some such thing?
Do check your water hoses are tightly screwed. I have seen cases where fine jets of water spray into odd places which cannot be seen when the machine is backed to the wall.
Poppa
http://www.cdbaby.com/cd/poppamadison
Mar 04, 2012 | LG WM2277H Front Load Washer
Water dripping from front left side of dishwasher
feel the botom of the door is it leaking from a plastic tube on the left between the door shell,if ti is you need a vent ***. good luck!
ERIC
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 26, 2010 | LG Dishwashers
My dryer is leaking water from the bottom of dryer
Check the vent coming out of the back of the dryer. Somewhere in the vent there is a blockage. If you clear the blockage you may solve the problem.
Jan 07, 2010 | Abbaka White Knight 44AW Electric Dryer
My Zanussi dishwasher DE6744 leaks clean water during the wash cycle. The water appears to be coming from the plastic tank overflow holes, left hand side as you look from the front. Any ideas?
I have the same machine and I took mine outside and turned it on its side and removed the clean water feed and all the screws holding the white plastics off and then un-clipped them off and I saw that there was a blue tube that was leaking on mine, I cut the end off and reattached it with a new clip and hey prestow all working now with no leaks.
Dec 29, 2009 | Zanussi 24 in. DE6744 Free-Standing...
Leak on left fron area
the defrost drain does not regularly need to be emptied, it will evaporate on its own, if you are indeed leaking from the defrost pan perhaps you have a hole in the defrost pan, or a partial blockage of the defrost pan so the water does not spread throughout the whole pan call a service guy or just take off the back panel and look at the whole pan with a flashlight.
Aug 27, 2009 | Estate TS25AFXK Side by Side Refrigerator
Water dripping out of door vent in lower left side
This is being caused by the vent tube design. The lower fitting is pushed up into the upper fitting so water leaks out from the top. The fittings are designed backwards. Remove front door panel and their will be a white tube running down the side. That tube is pushed up into its mate. Pull it down and silacone calk all around the out side of that pieces and the inside of the upper piece. put them back together and then tape it with some duck tape. DO NOT US FOR AT LEAST 24 hrs.
Jul 25, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Door leak in LG LDF6810ST Built-in Dishwasher
Your drying vent tube is probably leaking inside the door panel.  Remove the outer front panel and on the top left side, there is long white plastic tube connected to the dryer fan assembly.  In that connection is where the problem is.  You will need to disassemble the fan from the door, disconnect the tube from the fan, clean out the water and debris and use silicone when reassembling the tube to the fan.
May 26, 2008 | LG LDF6810ST Stainless Steel Built-in...
Re: lg wm1812
There is a vent at the back of the machine near the top that is covered by a small round white plastic cross pattern. Inside of the machine there is a black flexible hose that attaches to the vent from the top of the outer tub. inside of the tub attachment point is supposed to be a light blue plastic valve that looks like an old style army helmet on a peg. The peg fits into a flange in the opening on the outer tub. If this valve is missing water will escape from the vent on the back of the machine. Another likely point of water leak is a loose inlet hose or missing washer on the inlet hose.
Mar 14, 2007 | LG WM1812C Front Load Washer
LG LDF6920ST Fully Integrated Dishwasher with 5 Wash Cycles 3 Spray Arms Logo
44 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
