Question about ASUS P4P800-X Pentium Motherboard
Asus p4p800-x no screen no beep
I got problem with my mobo asus p4p800-x,there was no screen or no beep at all......blank screen(only "no signal" shown).i asked to my friend at YM an he told he got same problem but with mobo asus p4p800-mx. Now i used my bro's comp,his mobo asus P5B. What's wrong with asus p4p800 series??????????? i hate this brand now.
ugh...i looking for solution.
please...give ur hand....
thanks.
tony.
Got the same problem when adding 2x1Gb RAM PC3200 in addition of original RAM 2x512Mb PC2100.
After some testing, it appears these no-name RAM do not work with the P4P800-X.
But they works in my other PC.
Will buy new PC3200 RAM and hope this will be OK this time.
Posted on Aug 11, 2008
Could be that your ram is either Bad or the wrong type. I just had a similar problem. I changed the ram and up it came.
Posted on Aug 04, 2008
My computer (3.0 GHz Pentium 4 with Asus P4P800-E Deluxe mobo) will boot to the POST screen, and it successfully identifies all of my hardware (memory, hard disk, DVD-ROM drive, etc.), but then won't...
Checked your RAM chips? Remove them and boot up and see if it will beep. If you have another DVD drive, swap it and try again. The board battery rarely goes, and only change it when it is not keeping the date/time etc, it won't help in outputting video.
Sep 10, 2011 | ASUS P4P800-E Deluxe Motherboard
Please help me.. i need VGA,SOUN CARD,LAN for ASUS P4P800-X
http://support.asus.com/download/download.aspx?SLanguage=en-us this is the driver section of asus on the first row that says select a product choose MOTHERBOARD on the second row select Socket478 on the third row select your mobo P4P800-X than the site will prompt you to select operating system and you will see your driver page
Dec 12, 2010 | ASUS P4P800-X Pentium Motherboard
I have a asus p4p800 se mobo everything works but when i push the power button i get no video. i tried multiple video cards and still nothing
Please Check your motherboard in your motherboard having problem that why its happen please repair motheboard. or Change Motherboard.
May 11, 2010 | ASUS P4P800 SE (890552603657) Motherboard
I got problem with my mobo asus p4p800-x. the system restart immediately in 10 seconds after booting.
change the battery then check the power supply with tester jim lok at cpu fan as well if it works jim
Feb 20, 2010 | ASUS P4P800-X Pentium Motherboard
I have a homemade system with a P4P800SE mobo. The system is about 3 years old and has worked great until the other day it wouldn't turn on. I tried the power switch and the reset button. Nothing. The...
there are many things that can shut down a motherboard.
power spikes, the caps on the board, a blown diode, voltage regulators alot of people use a power strip to protect there computers which is wrong they will not prevent a spike from getting to your hardware, even tho the light comes on the board (3.3v) if you do not have 12v or 5v getting through the board theres no way to get it to go the only thing you can do is see if you can find someone who fix's the boards or upgrade to a new mobo or find a replacment on ebay or one of the other sites
Dec 06, 2009 | ASUS P4P800 SE (890552603657) Motherboard
ASUS P4P800 SE DVD WRITER NOT WORK
Turn the burn rate down.If that does not solve the problem.reinstall the burn program.
Was this solution helpful? Show your Appreciation by rating it..RICHARDM69
Dec 14, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Blank Screen, no beeps, New Build
Hi Durmo, your troubles may be the SLI card. If you are using a single 8500GT make sure your SLI card is plugged into the motherboard as a single graphics card. See page 3-9 in your manual. If your 8500GT has dual out puts check both for display. Only one will show you display.
If you have this set correctly & you have tested your monitor on another system (& it is good) yet no display from the system than contact Asus. This board was make in 2007 & is warranted up to 2010. You can do this online or call Asus at 1-812-282-2787 M-F EST. Other countrys click the dropdown menu at Asus home page. http://www.asus.com/products.aspx?l1=3&l2=11&l3=473&model=1474&modelmenu=1
Post if you need more info.
Mike
Aug 19, 2008 | ASUS P5N-E SLI Motherboard
No signal
try taking out a gig of ram and then start computer.
Jul 03, 2008 | ASUS P5N-E SLI Motherboard
Computer kept on restarting
First off take out your pc ram, then listen for a alarm to beep continually. If it does not beep then either your mobo is not getting power or it overheats for some reason and the protection functionalities in the bios has been set to switch off or it is broken.
Basically strip down your pc to bare essentials to get it working. Only hook up one ide/sata drive your os drive, one cd/dvd rom, powersupply to mobo and cpu and ram offcoarse. Start from bottom and work your way up.
Dec 19, 2007 | ASUS P4P800 SE (890552603657) Motherboard
ASUS P4P800-X Pentium Motherboard Logo
769 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
