Question about SimpleTech SimpleDrive Portable USB 2.0 60GB 5400rpm 480Mbps USB 2.0 USB 2.0 External (STIUSB2560FT) Hard Drive
External hardrive problem
My motherboard recently malfunctioned and so i took my hard drive from my pc and put it in one of those generic external cases. problem is that my log in on my pc was password protected and although the external hard drive is recogized when connected via usb to my laptop i can't gain access to it because it is denied. can you help please? many thanks tony
    Genius:
  • 1,066 Answers
Try do access it with a version of linux. linux is a free operating system.
Posted on Mar 11, 2009
Computer won't recognize external usb hard drive
try it on another computer if that dosent work you should
reformat your computer but first backup all your data by putting your another internal hardrive on your computer and move all your files you need to the empty hardrive and after that take the hardrive with all your stuff in it off the computer and then reformat the hardrive which the external hardrive does not work on and install a new operating system then put the other hardrive with all your stuff back on your computer and transfer your stuff into the hardrive with a operating system then try the external hardrive
OR
you can burn all your stuff into a CD or a DVD
OR
you can put all your stuff into FlashDrives and then after you reformat the hardrive with an operating system put your stuff back into the computer and after that the external hardrive should work
Dec 27, 2012 | Toshiba HDWC130XK3J1 Hard Drive - Canvio 3...
Seagate Barracuda external hardrive - damage to usb connector on
Assuming the drive itself is still ok (it sounds like it would be), then yes, you can put the drive into another case or directly into the motherboard if you know how to do that.
May 27, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Astone 1 TB ex hardrive no longer recognised by computer
You need the device drivers for Win-7 for that hard drive to work. You can try to locate one on their website, but I couldn't find any....
http://www.astone.com.au/index.php?downloads=yes
Jan 07, 2010 | Computers & Internet
Itunes messed up my external hardrive
I doubt that iTunes really moved/reorganized files on your computer.
iTunest may have created its own "Table Of Contents", presenting a "view" of all your files.
Open "My Computer" and open your external hard-drive.
The files should be in "your" order.
Open "My Documents". Open "My Music".
If iTunes really did "reorganize" your files, there's no way to "go back", because "Windows System Restore" does not automatically created time-stamped backups of your 'My Documents' folder (nor of any external disk-drive -- where would it put that much data???).
Jan 02, 2010 | Seagate Free Agent Go Small 12 GB USB...
See: http://www.fixya.com/PostAnswer.aspx?thid=3781106&prdid=512305
for a "duplicate" question.
Jan 02, 2010 | Western Digital My Book Essential Edition...
Monitor doesnt reckinize that the hardrives on
try taking the ram chip out then see if thats the prob by turning on the computer without it if its not, try unhooking the cd drive and then try turning on the computer if thats not it then try unhooking the hard drive and check if thats it one of those should be the problem i had the same prob but i messed with the ram chips and it worked i just took it out started it up and it worked if thats the prob just start it up then shut it down and put the ram chip back in and it should be fine
Jun 10, 2009 | Northgate (STAX2517C2) PC Desktop
Jumper Settings
are you talking about the jumper on the hardrive?if so if you have only 1 hardrive put the jumper on the 'cs' pins.if that doesnt work put the jumper on mas or (master).if you have 2 hardrives make sure the jumpers are on mas and the second drive on slave.hope this helps.let me know.cs means cable select
Feb 02, 2008 | EliteGroup P4S5MG/GL+ Motherboard
Usb connection failure
ok" take a small needle , streighten the pin very carefully.
Jan 21, 2008 | Western Digital 320GB MyBook External USB...
Seagate external hardrive
Here is the link to the Seagate's utility tools: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=Downloads&vgnextoid=51e092db8a13d010VgnVCM100000dd04090aRCRD The links that you are looking for are DiscWizard and SeaTools. And if you have just lost it, here is a recovery program that you can use: http://www.download.com/VirtualLab/3000-2248_4-10642058.html
Mar 20, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
Try to plug it into more than 1 computer other than your PC. If it works, then the problem is the interface between the hard drive and your computer and if it really doesn't work, you're solution is have it recover by data recovery experts. Here are a few things you need to keep in mind, on taking your first steps in such a situation: Do not open the hard disk and try to repair it on your own. If you're data is really, very valuable, don't use automatic data recovery tools. Before you bring it, wrap the defective units in anti-static envelope if possible, bubble wrap it, and seal package securely. You also had an option to recover it on your own by using known data recovery software but it's risky compared if you bring it to a data recovery experts. If the problem is within the mechanical parts of a hard drive, there's a possibility that you will not attain a 98% chance of recovery if you do it on your own.
Computers & Internet Logo
129 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
