Question about LG WM1814CW Front Load Washer
HOW TO REPLACE HALL SENSOR ON LG TROMM - LG WM1814CW Front Load Washer
  • 1,543 Answers
Unplug machine. Remove back panel (4 phillips head screws). Remove large bolt in center of motor. Pull motor rotor off shaft. Remove phillips head screw(s) holding wire protector and possibly ground wire at bottom of motor area. Remove metric bolts from motor coils and remove coil assemble. Unplug 4 wire harness from Hall sensor. Unclip Hall sensor from coil assembly. Install new Hall sensor, and re-assemble. Plug machine back in. There. Done, and it only took 10 minutes!
Posted on Mar 27, 2011
  • chrismsie
    chrismsie Jun 17, 2012
    What if the large bolt on the center of motor will not come off...then what?
5 Suggested Answers
codfish124
  • 36 Answers
SOURCE: hall sensor
no you do not have to replace the motor when replacing the hall sensor. unless the motor is not reading on the hall sensor. most of the time it just the hall sensor that needs replacement
Posted on Dec 10, 2008
blueextc3221
  • 15935 Answers
SOURCE: LG Tromm WM2277HW with LE error. Replaced the Hall
LE indicates a fault with the motor on the appliance.
LG suggest you switch off, wait for a minute, unplug the appliance.
Wait 15 minutes then plug it back in again.
Try the machine again.
If it's still faulty, you can try changing the Hall Sensor in the motor, this can sometimes cure the problem.
Unplug the machine and remove the rear cover. There are 4 Philips head screws. Take them out and remove the rear cover.
You should now see the rear of the motor, which is mounted to the back of the drum.
In the middle is a large bolt which holds the stator cover.
You'll need a 17mm socket and a ratchet to remove this bolt.
Remove the stator cover and place aside.
Toward the bottom-left, you will see a couple of wire bunches held to the motor by three screws. One holds a metal bracket, one actually holds a ground wire, and the last is through a plastic bracket toward the bottom. Remove these three screws and don't lose them.
Through the motor there are 6 bolts holding it onto the back of the drum assembly.
You'll need a 10mm socket and ratchet to remove them.
You will now have the motor off the back of the drum.
Disconnect the two wire harnesses from the motor.
Looking at the surface of this motor that was facing the DRUM (not the outside), you'll see two small pieces clipped onto it, toward the bottom.
The sensor you are looking to replace is the one that looks like a kitchen magnet.
It is attached by small clips. You'll see how it goes on. It's easy to remove.
Go to google and search for part number 6501KW2002A.
This will bring up an LG sensor assembly.
Double check with the supplier that this is the sensor for your appliance.
When you receive the sensor, simply reverse steps 1 through 5.
Once re assembled, try the machine again.
If still the same after this you'll need to replace the motor and/or control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Posted on Sep 15, 2010
MNTECH
  • 1543 Answers
SOURCE: LG LE error. WM2277HW Have replaced the Hall Sensor and ran
As long as that Tide HE is not 2x or 3x concentrated, that would be the maximum amount of detergent for a large, heavily soiled load. Lighter soiled and/or smaller loads should be about 1 tablespoon. If 2x concentrate soap, use only half that. The reason this could cause an LE error is that suds between the inner and outer drum will cause excessive drag on the inner tub, with the possible result of an LE error. I'd try to run a load on Sanitary, heavy soil level, with no clothes, and a washer cleaner such as Affresh, Washer Magic, Whirlaway hot tub cleaner, Smellywasher cleaner, or Tide washer cleaner to remove any possible build up of soap residue from the outer tub area.
Sometimes, cycle selection/ loading level/ load type can cause LE errors. Gentle wash cycles, such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because these cycles are more gentle in tumbling and spinning, putting too much in the drum can register an issue with the motor. Remove items, reset unit and test with a Rinse/Spin cycle.
Another possiblility would be a loose electrical connection dealing with the Hall sensor, at the sensor, the control board, or (much more unlikely) the wire connecting them.
On rare occasion, the main control board can be at fault, but generally, replacing the Hall sensor does take care of the problem. (over 90% of the time)
Posted on Nov 05, 2009
Testimonial: "Right on with the solution...After fully disassembling the washer ohming all the wires checking all connections. It turns out a loose hall sensor."
SOURCE: I need to replace my hall sensor - LG WM0264H
I fixed this myself. I found an on-line LG service manual and bought the hall sensor (about $30). It took all of a half an hour to repair this myself. I read that too much soap and fabric softener will make the circuits on the mother board heat up and short out the hall sensor (gunk and resistance on the wash drum). It is running like a top again. The local parts store said to periodically run bleach and water through the soap, and softener despenser to help keep it clean.
Posted on Mar 26, 2009
My lg tromm model number wm2277hw/01 has the error code le show 2 seconds into the cycle even if nothing is in the washer what is going on
Hall sensor needs replacing (motor position sensor). Pretty easy and under$20. Check out appliancepartsproscom, repairclinic.com or YouTube for how to videos.
Jan 22, 2017 | LG Washing Machines
Lg tromm wm2077cw le code
Replace "hall" sensor. Motor sensor is an easy fix and a known problem. Try appliancepartspros.com. They have video to show you how. And part.
Feb 27, 2015 | LG Washing Machines
I have a LG Tromm with an LE error code. I just replaced the hall sensor
With a digital volt meter you need to measure the ohms value of the hall sensor. It has 4 wires. White red blue and gray. With the meter set at 20k ohms check hall sensor at the control panel. From white to blue you should read 9.5 K ohms. Same with white to red. If u get 9.5k ohms on both readings u have a bad main board. However to me I think your pump is bad. LG washers will not spin if they don't drain.
Apr 03, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
"LG Tromm WM2277HW will not
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Mar 27, 2011 | LG WM-2277HW Front Load Washer
My Tromm Lg washer has a code that came up LE what does it mean
Hi
Error code LE indicates that either the motor is not turning or has locked up for some reason. It can also be due to Hall sensor which monitors direction and speed of the motor. If the sensor is faulty then also this error appears. Motor lock can be caused by several things from a loose connector, to a bad motor. To make sure it's not a locked motor, try turning the drum with your hand. And, if there is any resistance while turning the drum or the drum doesn't move freely then the motor is locked and you'll need to get it replaced. If the motor seems to be fine then you would need to replace the Hall Sensor. To replace the hall sensor, take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Hope this helps...
Daniel
Jan 10, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have and error code on the LG Tromm front load washing machine. is is flashing LE
this is a problem with the stator assembly or the hall sensor check the wiring to the hall sensor and make sur eit is connected properly. the hall sensor is located in the rear of the machine remove the rear panel and look for the wiring to the motor assembly.the last thing to change if neede is the main control board.
Nov 03, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
On a LG Tromm washer, what does error code ''LE'' mean?
LE indicates the motor is locked. Check the 3 pin connector at the motor and check the 4 pin connector at the main control if they look good ( no corrosion and fit tight) replace the Hall Sensor. You can enter your model # at www.appliancehelponline.com for diagrams and illustrations.
May 28, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm washer is not working with getting LE message.
LE code means locked motor error. you need to check the Hall Sensor. unplug the power, remove the rear washer panel, locate the Hall sensor connector on the stator behind the rotor. you can test it with an OHM meter for failure. it may just be an unstable connection.
Nov 07, 2009 | LG WM2688HWM TROMM SteamWasher
Mar 19, 2009 | LG Washing Machines
LG WM1814CW Front Load Washer Logo
2,358 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
