Question about HP Office Equipment & Supplies
My printer wont print a document .....I called the 1300 no: and someone told me to uninstall the the printer from my computer and then reinstall it .....thanks i did this and now my computer does not what to reinstall the program from the disc i recieved with the printer( is this someones idea of a joke or is this the normal service and customer support on gets from HP) The problem was simple im sure the printer would print the self diagnostic page perfectly but not any document or pictures from the computer .......A customer service consultant told me what to do and now nothing works it wont read the installation disk ???? Please advise Gavin van der Westhuizen H) 07 5501 5661 W) 07 3804 9572 The computer is at home so no point i calling me at work ( work from 06h00 until 17h00 ) Printer serial No:MY689D61B9
    Master:
    Sergeant:
  • 398 Answers
Go to HP.com and click on support, you will see downloads, select your printer and download software and drivers, they usually have updated versions and they work better than the disc you recieved with the printer.
Posted on Aug 04, 2008
CANON PRINTER MP560 WONT PRINT IN BLACK
This is seems to be weird issue you are facing with the printer. I would like to know what is the application you are trying to print from ? Is it Microsoft word etc ? Try to type something in Notepad and print and check if the black is printed.
If you are able to print from Notepad then probably it there are chances the application you are tying to use is corrupted and might need to uninstall and reinstall
Regards,
Suhail
May 14, 2012 | Canon Office Equipment & Supplies
PRINTER WON'T PRINT DOCUMENT ONLY SERIES OF QUESTION MARKS.
Your printer is printing "garbage print". To make sure there is nothing wrong with the printer, try printing an internal report. If the report is good then there is a problem with the printer driver, interface cable (USB, parallel, ethernet) or port.
Start by uninstalling the printer driver and then reinstalling it.
If the unit still wont print properly, try using another cable or try installing on another computer.
If the same thing happens on another computer with a new cable then the printer is at fault and needs to be reset. You should be able to find the reset procedure in your user's guide.
Thanks,
Pat
Nov 07, 2010 | Epson Office Equipment & Supplies
When I click print the document goes into queue then when I troubleshoot it says the printer wont print because a document is in queue. When I clear all documents it says "printer ready" but then it says...
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
Sep 18, 2010 | Epson Office Equipment & Supplies
Epson 880 printer will print one document, then computer freezes when I try to print another document. Have to reboot, but the problem repeats
what's your operating system? If your using PC, try to restart your print spooler. try to uninstall and reinstall the driver.
Apr 28, 2010 | Epson Stylus 880 InkJet Color Printer
Every so often when I try to print a document I
Try reinstalling the printer driver, make sure you uninstall it first.
Jan 10, 2010 | HP OfficeJet G55 All-In-One InkJet Printer
Running windows 7 printer wont print anything but installed ok
Is this a brand new computer or did you upgrade to Windows 7? If you did an upgrade, you needed to uninstall the old drivers (with the printer disconnected from the computer). Then you could install Windows 7 and finally install the printer.
You can try unplugging the USB cable, uninstalling the printer and then reinstalling it.
What software are you using to create the file that you want to print? With Microsoft Office, I have seen reports that changing the font on a document can cure a failure to print the document with Word.
I hope this helps.
Dec 29, 2009 | Lexmark P4350 All-In-One InkJet Printer
How to reset printer epson stylus CX4500
First, install the driver on to another computer and try.
Looks at the picture for the computer having problems. If it there listed. Try make the printer properties default or uninstall and reinstall.
Jul 30, 2009 | Laser 3115cn All-In-One Printer
Installed new yellow print cartridge for HP printer, prompts to install new cartridge but my ink level says full
I have this same problem and some sites said to uninstall the software then download the software from the HP site and reinstall it. So I am giving that a try tonight
May 29, 2009 | HP Photosmart C5180 All-In-One InkJet...
Document goes to the print queue, then errors
To start with You check the data cable is properly connected to your printer than you open the printer dialogue box and remove the documents pending in the queue and retstart the computer and before giving the print command select the printer that you are going to use(if more printers are connected to the computer).if all this does not work i suggest you to reinstall the printer after uninstalling it
May 27, 2009 | Office Equipment & Supplies
Uninstalled my hp1300 and when reinstalling I am being told my operating system and admin rights are not valid but I have been using the 1300 for 2 years.
Did u receive the computer from someone two years ago? Are you on the internet when u try to reinstall the drivers? Sometimes windows_verify programs goes for a loop. It thinks that u are not a true owner of the software. Are you trying to get the software drivers from the internet or are using CD to install?
If u have the hp1300 CD install drivers, Disconnect yourself from the internet, install drivers & bootup.Make sure that your printer works, then we'll try to deal with windows
p.s bootup, pressing f4, bypass admin rights, install drivers...reboot
May 02, 2008 | Office Equipment & Supplies
59 people viewed this question
Seeker5211
Seeker5211
