Question about Minolta Office Equipment & Supplies
I have a minalta DI350 when I turn machine on the error c0010 come up seams that the motor is trying spin but can not can you help
    New Friend:
  • 170 Answers
Remove the drum cartridge check the mechanical gear in that assy. try to rotate all the gears if its ok try to check the mechanical parts at the back of the machine to check the parts remove the back cover of the machine then inspect all mechanical gears & motor
Posted on Mar 28, 2011
HELP! Minolta Dialta Di350 Showing Error Code C0F35
Well the C0F35 is because there is no toner in the image unit so replace the image unit. just buy a whole new unit. as for the c0070 try this
Power off the machine. Then remove the toner bottle, be careful the hole might be on the bottom and the toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KNUB on the side of the bottle is damage put a new one in. That KNUB is what the toner motor uses to turn the bottle, if it damaged you get a code. If that does not work, you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 12, 2017 | Minolta Office Equipment & Supplies
EP 3000 ERROR CODE COO10
Main Motor, remove the fuser and check the gears, also check the gears that are located in the back of the copier where pulled the fuser from. Also check the drum developer units
Jun 09, 2014 | Konica Minolta Office Equipment & Supplies
I have a minalta cs pro ep 1085..when I tried to take copy the paper jumed and errore code apeared (c0010) ,, any help will be greatfull
Sir/Mam the Drum Motor is failing to turn the drum it self mite be jammed. Not allowing the motor to turn . Remove the drum cartridge. And see if you can turn the drum with your fingers DO NOT TOUCH The color part of the drum turn by both thumbs on the edge of the drum TURN CLOCKWISE if you turn Counter clockwise you will flip the cleaning blade that is not good. The cleaning blade removes the old toner before the new image is placed on the drum if it looks yellow then get a new one and replace it. IF you think the drum is stuck to the cleaning blade then for about a half inch push the drum counter clockwise the then clockwise. Also might remove he drum to see if its jammed. Also the motor might be bad or the circuit board that replaces it. Hope this works for you
Hope this works for youH
Nov 23, 2013 | Minolta Office Equipment & Supplies
F21 has appeared on my Bosch classixx 6 1200 model
F21 normally indicates a fault with the motor or the main control board. It could be the motor brushes need changing.
If you've changed the brushes you now need to erase the stored errors and try the machine again.
Turn the knob to off.
Close the door.
Turn the knob to 6 o'clock position.
Wait 2 seconds.
The start/pause should begin flashing.
Press and hold the spin button. (the spin button is the one that changes the spin speed, it may be marked "RPM")
Turn the knob to 7 o'clock position.
Wait 2 seconds.
Release the button.
This should erase the error code and get you running again.
If the error code returns, you have a problem with the motor, wiring or main control.
If the machine won't go into diagnostics to erase the error code, it would suggest a faulty control board.
Try it several times to see if you get it reset.
Note, If the start button doesn't flash, just carry on trying to erase the codes.
Dec 22, 2012 | Bosch Classixx WFL 2066 Front Load Washer
Minolta Copier EP 6000 copier error codes: C:C0010, C:C0992, C:C0410. Any ideas what these mean?
As for the C0992 code that deals with a paper draw fault, looking at the control panel do you see a small wrench located at the left hand lower corner. Touch it , it will take you to another screen when there open and close the front door, if the code comes back you have problem with main draw.
The C0410 is a problem with the very, bright lite under the big glass is bad. try to reset, open the front door to your left is a small access plate open and press trouble reset, if the code comes back replace the exposure lamp.
C0010 code main motor fault, remove the fuse unit the hot part and check for broken gears check the section where it goes look in the back for broken gears, remove the drum assy. check for broken gears, open close the front door to reset, If it comes back get a new main motor and or main control board,
Dec 03, 2010 | Minolta Office Equipment & Supplies
Aeg oko lavamat 6555 cannot open door no response to buttons F9 flashing
Hi
Error code F9 means an error with motor or motor tacho failure. Try resetting the error by pressing quick and prewashing buttons together while turning the knob to gentle spin. All LED's will glow, now turn the knob back to Off and the machine should work. Hope this helps... Please post back for any further assistance.
Daniel
Aug 29, 2010 | Washing Machines
LG WD(M)- 16220FD Error LE
The problem you are having is with the Hall sensor. To be 100% sure, here is the test proceedure, it is located on the stator. Replace this and your problems will go away. If you are not already using HE detergent, start using it, as well cut back on your fabric softener.
Sgt 48
Jun 01, 2008 | LG WD-1280FHD Front Load Washer
215 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
