Question about Belling Solitaire G747 Gas Kitchen Range
Hi my belling gas hob keeps sparking/clicking on one of the igniters. I've trued replacing the fuse in the plug but it's still sparking. Any ideas? It's only on one of the rings
5 Suggested Answers
  • 2976 Answers
SOURCE: convert my belling DB90
You will have to change the orifice to accomodate lp gas.
Posted on May 08, 2009
SOURCE: hob regulator wiring
OK, they are wired so that the two elements are switched in and out, to form, a single, a dual but in series, and a dual, but in parallel. like this Low, ONE, Element ONLY, The Other is out of circuit. Med, TWO elements are connected using the switch, in SERIES with each other. High, you switch TWO elements in PARALLEL. Simply meter the switch out to do that when each position is turned. Just think of it like, It's just two resistors, wired up. single, series, & parallel.
Posted on Apr 19, 2010
  • 193 Answers
SOURCE: why does my beaumatic gas hob/electric oven keep tripping?
water has gone into back of element or oven light you will need to remove the back of the machine a check they are dry WITH THE POWER OFF
Posted on Apr 25, 2010
Testimonial: "thanks phampton25, will try that later and let you know how i get on. thanks again joemc61"
  • 222 Answers
SOURCE: Hi There, I have a
your unit is batery or power supply operated? if batery supply depend on the model or brand were exactly the battery but mostly at the back of the unit,but if power supply pls can you check if the power plug is in outlet.or your outlet try to use any kind of appliances to check if der a power supply,check also the plug of your range if have a fuse inside the plug?to make is sure replace to a new one.
Posted on Dec 17, 2010
Hi there, I have a belling gas oven cooker, which when you try to ignite the oven or grill it keeps ticking but wont spark up. The gas is fine as you can light them manually and the hobs light fine so...
why would they be trying to light an electric oven ( see which product do you think they mean ) You need to check that the spark being produced is close enough to the gas outlet
Oct 03, 2012 | Ovens
Ignition on hob not sparking
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 06, 2011 | Belling Solitaire G747 Gas Kitchen Range
Gas hob continually clicking, as though wanting to ignite gas rings, all 4 of them pleasr help its driving us mad, cant switch off at mains as i it switches others off.
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
Jan 05, 2011 | Ovens
Hi There, I have a Belling 5 burner gas hob. Just cleaned it down and now the igniter keeps on sparking as if i am pushing down on one of the knobs to try and light it, but i'm not touching anything. ...
Dec 17, 2010 | Belling Solitaire G747 Gas Kitchen Range
Electric ignition to hob seems to be jammed
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 31, 2010 | Cooktops
Smeg gas hob ignition
There is a problem with the board. It has malfunctioned onto an ignition mode. By switching it off, it shows the capacitor is holding chage untill flat.(Hence the continual sparking) Replace it.
Sep 20, 2009 | Cooktops
Ignitor keeps sparking not wet or dirty even when no burner on
Will most probably be a problem with your ignition box. If you want to test this try taking off the hob by undoing the screws under the burners, be very careful with these however as it is very easy to strip the thread on them, once you have the hob off try unplugging the ignitor that keeps sparking and swapping where its plugged into the ignition box with another ignitor. These ignitor can be plugged into any plug in the box so no worries there. If the ignitor keeps sparkings in another hole its the ignitor. If the new ignitor sparks its the ignition box. It will most probably be the ignition box. Is a common fault
Aug 08, 2009 | Fisher and Paykel GC913 - Stainless Steel...
Gas hob is permanently igniting
hi gud day,try to clean the area of knobs by using vacium,remove all the knobs firts then clean it,unplug the unit before u clean.
tnx gerbee
May 19, 2009 | De Dietrich DTG775X Gas Hob 22 in. Cooktop
Hob ignition switch keeps on clicking.
Hi
Glad to Help you!!
Take the knob off, them remove the cover that housed the switches, OK, Now, Look at the switch that is continiusly clicking and it will have two wires goin onto it, remove these wires and just lift the sending unit, and inspect it for water, grease etc ect....clean and dry and put back on and try again it should work, if it does not work, then just get a replacement one, they are not expensive, I just replaced two on my Jenn-Air myself and it cost me $25.00.
Hope this will help!!
Eddie Rentas
Tupper Lake NY
Jun 26, 2008 | Cooktops
Kitchen Ranges Logo
243 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
