Question about Garden
I cannot get the automatic chain lube to work - it is a mac 335 chain saw - any ideas
  • 2,239 Answers
The pump is fairly simple, however you will need to remove the clutch and sprocket to gain acsess to it, start by removing the two bar nuts and the chainbreak side cover, remove the guide bar and chain, the clutch is just spun onto the crank left hand thread, there are two cut a ways in the clutch centre, this is to take a special tool, once inserted into the cut a ways you use a 19mm spanner to jar the clutch off against compression, an impact wrench works well, the tool is part no. 530031112, you could maybe make a pin spanner to do the job, once the clutch is removed the sprocket will just pull off, there are then two cross head screws securing the pump assembley, the drive gear is pressed onto the crank, the pump pinion runs at right angls to the drive gear, the pinion is nylon so check the condition of the gear, behind the gear is the pick up pipe and filter, you will need to pry off the silver bar protection plate.
Posted on Mar 27, 2011
Automatic chain oiler on my Partner s 55 chain saw doesn't work
First check the lines to make sure they are clear of chips. Use only bar and chain lube. If this does not work, the pump may be bad and need replacing.
Feb 09, 2014 | Husqvarna Chain Saw 20" Bar
Mt 9999 chainsaw manual
Put fling oil into the oil reservoir and that will automatically lube your chain, adjust the flow by turning screw at the underside of the saw
Apr 30, 2013 | Garden
My chain oiler is not working on my MAC 335
Sounds like something is clogged. I recommend contacting your local service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Jan 02, 2013 | McCulloch Garden
What is the correct fuel for a mac 335
Unleaded fuel mixed with good two stroke oil at a ratio of 25-1
Aug 19, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have a craftsman 16" 36cc chain saw. Engine
First thing is make sure chain brake is not engaged is so equipped. Next make sure that chain tensensioner is not to tight to allow chain to rotate. I wouuld remove bar and chain from saw and spray both several times with WD-40 and work chain link by link until they all move freely.Clean and lube guide channel on bar and make sure that bar is not dented or badly rusted.If all else fails replace bar and chain. Good luck and thank you.
Mar 14, 2011 | Craftsman Garden
Brand new poulan pro 4620avx--bar oil is coming out of oiler but not getting onto chain
Hello. Thin your bar oil just a wee bit with some kerosene. If you have a gallon of bar oil add 1/4 cup of kerosene, stir it up and you will be fine. For starters also, directly apply some bar oil to the chain so that you are always using a well lubed chain. Joe
Oct 03, 2010 | Poulan Pro Chain Saw 46cc 20"
Doesthis thing need oil or some other liquid type
The bar and chain require bar oil (only) to be placed in the capped tank. The motor itself is air cooled, and should be blown out with compressed air often to remove the accumulated sawdust. Make sure the chain is tightened just enough to prevent the lower part of the chain from drooping from the bar and can be turned by hand. Make sure to keep the chain teeth sharp by properly filing for best cutting. Test the chain oil pump operation by running the saw with the chain tip near a piece of cardboard--it should throw off a thin line of oil after a moment or two of running. Hope this helps!
Apr 05, 2010 | Remington Electric Chain Saw
MAC 7-38 chainsaw stalls when you open the throttle. Any ideas?
We are talking about an electric chain saw ?
I would say you are not getting oil to the bar chain sprocket. Do you have enough bar oil in it ?
Feb 01, 2010 | McCulloch 10" Electric Pole / Chain Saw
Hi i have a bahramshahr chain saw and cant get oil to lube the bar, ihave traced the hose and made sure its not blocked and its all clear .are these gravity fed or does it work on venturi action , or does...
I dont know this saw but most saws have a pump
mounted behind the chain drive. On most saws it is not too dear and easy to replace. Stephen
Aug 09, 2009 | Garden
Ryobi 40cc chain saw oiler not working correctly
Hi
Check and clean the oil filter from oil tank.Check the worm gear wich engages with the oil piston pump(under the clutch).Near the hole where the oil comes out from oil tank there is an oil tank valve(see if it is clogged),it equalises the presure between interior and exterior of the oil tank.
best reagards savumihai71
Dec 23, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
74 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
