Question about Technics SA-AX7
How do you wire amp for bi-wire hook-up - Technics SA-AX7
I have Xavian xn125 speakers. How do I connect them in a bi-wired or bi-amp
Bi-wiring basically works wtih one amp. You need a crossover network and a signal doubler to use two amps (bi-amping). There are many diffent ways to bi-amp (horizontal, vertical,...) This link: - -http://www.soundstage.com/synergize/synergize031998.htm-- explains them all. Bi amping is usually not worth the extra price and complexity when used on smaller speakers.
May 13, 2014 | Audio Players & Recorders
Tip
How To Bi-Amp And Bi-Wire Speakers!
What is the difference between bi-wiring and bi-amping?
Bi-wiring is using the same power source (amplifier) but separately connecting that power source to a woofer and a midrange/tweeter on a speaker.
Bi-amping is using two separate power sources (amplifiers) and connecting one amplifier to a woofer and the other amplifier to a midrange/tweeter on a speaker.
How do I bi-wire?
Your speaker must have two separate positive and negative connections (one set for the woofer and one set for the midrange/tweeter). Connect one wire between the positive terminal on the amplifier/receiver the positive terminal on the speaker. Connect the other wire from the negative terminal on the amplifier/receiver to the corresponding negative terminal on the speaker. Remove the jumper straps connecting the two sets of speaker inputs. Repeat this process for the second set of terminals on the speaker, connecting them to the same positive and negative terminals on the receiver/amplifier. Repeat the steps for each speaker you wish to Bi-Wire, connecting them to the appropriate terminals on your receiver/amplifier.
How do I bi-amp?
Bi-amping is similar to bi-wiring, but involves separate amplifiers: one for the woofer and one for the midrange/tweeter. Passive bi-amping involves a direct hookup between each amplifier and the speaker terminals. True bi-amping involves hooking the preamp to an electronic crossover that replaces the passive crossover network in the speaker. The active crossover then connects to multiple power amplifiers.
on Jul 13, 2010 | Audio Players & Recorders
How to hook up my speaker wires
Just follow the color code of where the wire suppose to go, it's like a puzzle, but it's that your following the Bi-Amp wiring on the back of the unit of your amplifier output
Mar 30, 2013 | RCA RS2652 Shelf System
How to hook up Panasonic SB PM19 speakers to SA-PM23 reciever
yes you can. these are called "bi wired" speakers which means there's a hook up for the woofer and the tweeter individually. If your amp have just 2 speaker hookups it's no problem to hook the woofer/tweeter wires of each speaker together. If your amp had 4 speaker hookups, you could put the tweeters in 1 and the woofers in the other but it will still work fine with 2 speaker hookups.
Mar 21, 2013 | Panasonic Audio Players & Recorders
Do i hook the speaker wire in to the top or bottom wire recepticles of the speaker
These are bi amp capable speakers...if you have the jumper in place (connects top and bottom terminals together) it's set up for standard full range connection - you can use either set. If the jumper is not in place, it's set up for bi amp which means you would connect your low frequency wire to the bottom terminals, and the high frequency wire to the upper terminals.
Aug 20, 2012 | Sony SS-X70ED Main / Stereo Speaker
I'm having a problem hooking up these speakers... It has 4 hookups in the back of it which ones do I use? I just have a standard reciever to hook them up to...
look at this picture...
http://www.helpus2move.com/sold-items/b-w-dm602-s3-stereo-speakers-bowers-wilkins/
The vertical jumpers are removable if one wishes to BI-amp them. If not, leave them in place and connect your speaker wire conventionally - plus to plus, minus to minus.
The picture here...
http://community.whathifi.com/forums/post/265617.aspx
shows what to do if the jumpers are missing. Just fashion a short jumper for each to connect the top woth the bottom on each side.
Google bi amplification speakers if you're bi-curious. ;-)
Feb 02, 2011 | B&W DM602 S3 Speaker
How do you hook up the speakers to a receiver. It has duel inputs. Is it two separate channels, or what?
Hello,if the speaker has 2 red and 2 black connectors then its designed to have an option for bi-amping and or bi-wiring.If you dont intend to do either than simply connect the reds together with a speaker wire and do the same with the blacks(if there is already a metal post connecting them than dont do anything but connect your speaker to the reciever as usual.
Jan 19, 2011 | Digital Audio DA-600SL Main / Stereo...
Speakers to amp
With the CLS-215 speakers, you can Bi-Amp or Bi-Wire them.
Here is how to Bi-Wire and Bi-Amp Speakers:
http://www.oregondv.com/Audio_FAQ_Bi-Wire_Bi-amp%20.htm
Jul 13, 2010 | Cerwin Vega CLS-215 Main / Stereo Speaker
How do I hook up mono amps in a two channel stereo system. Speakers are two way bi wire capable. Thank you
Your question is not very detailed but you should use one mono amp for the L channel and another for the R channel. Don't bother with any Bi-wiring.
May 03, 2010 | Kenwood Audio Players & Recorders
I have had a set of Polk Audio SDA1 speakers that I had attached to an old but great Pioneer SPEC-1 pre-amp and SPEC-2 power amp. The old speakers had one connection for the right speaker positive and...
bi-wiring requires the removal of the copper jumpers between the hi and low speaker terminals. you can use two wire pairs twisted together at amp out connections and the four separate ends at each speaker, but the quality of sound will not be as good as buying quality bi-wire cables. But a pair of quality single set of wires at each speaker would be fine, but put jumpers back on and attach to the top terminals, they are designed that way. bi-wiring does allow the crossover to put out a little better sound. Hooking up four sets of wires to the a and b speaker terminals sounds bad. i have had alot of trouble with my rti10's and learned the hard way that it is best to pay more for wires with quality terminations.
Jun 21, 2009 | Polk Audio RTi A7 Main / Stereo Speaker
41 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
