Question about OnDemand Nova Development Invoices and Estimates Pro (GB0U3C0GN0000NE066) for PC
Could not configure PDF Driver (Error Code:-8) for window 7
PDF Driver (error code:8)
If you have version 2 it only works in Windows 7 and Vista.and you will need to update.
Jan 21, 2014 | Nova Development Computers & Internet
Gobi4000 em7700 problem configuration with Windows 8
I would look on samsung's site for a current driver. You may also want to check Sierra's site for a driver. Also what exaclt is the problem, error message when you try to configure.
Dec 08, 2013 | Samsung Notebooks Xe700t1c 11.6" Tablet Pc...
Canon printer prints an extra page with a message ""@PJL INFO STATUS""
More information is required like are you using windows 7 or windows 8. Suspect you may have wrong PCL driver. PCL.
Press additional functions on printer keypad. Press report settings on LCD screen. Press Printer on lcd screen then press configuration and press yes to printing configuration page.
Look at the configuration printout to see if you can find the language the printer is using is it PCL3 ,PCL6, PCL5E, PS3 ..
This has to match the driver you are using !
All these drivers are available to download from Cannon but finding the matching driver can be done via trial and error but the configuration page is easier and less painful.
A mismatched driver to printer is possibly the cause of the extra page print.
Nov 09, 2013 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Printer scans OK but will not save file as a PDF document I am running Windows 7
There are some possibilities not to save as PDF file from the Scanner.
1. Driver compatibility.
- You should install windows 7 compatible driver of your scanner by clicking this link. Select your operating system first (Windows 7 or Windows 7 64-bit), Then click on the link of the file which is listed under the Drivers headline. (mp760vst.....exe file). Download and Install (run) it in your computer to update your printer driver.
2. Software configuration.
- You need to setup the menu while saving. And you must know some properties related to the PDF saving.
For example: You cannot select [PDF] or [Multi Page PDF] when selecting an image scanned at 5105 pixels or more in a horizontal direction.
To read the detailed set up informations related to the software configuration and saving as PDF, please download the Software Guide of your printer by clicking this link. I uploaded it to my FTP site for you and it will be there for a limited time.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
May 12, 2010 | Canon PIXMA MP760 All-In-One InkJet...
I am running windows 7 (upgraded from Vista which came on the machine at purchase). My dvd drive stopped working suddenly and it won't allow me to reinstall the driver. (hl-dt-st dvdram gsa-t20n ata device...
The Code 10 error code is generated when Device Manager has insufficient information or the error that is bubbled up by the device drivers is not recognized by Device Manager. Additionally, this error may occur when one of the drivers that the device needs does not start.
The Code 10 error pertains mainly to hardware and device driver issues or to compatibility issues.
Did you try Windows Update? You need to configure it so it looks for drivers as well.(is not by default).
It's strange since most drivers for Vista will work for Windows 7.
Another thing you can do is update and uninstall the driver, and restarting... that should take of it. I hope this helps. Please let us know if you solved the problem and do not forget to rate and provide positive feedback for our fast-free support today. Thank you :D
May 03, 2010 | Microsoft Computers & Internet
OnDemand Nova Development Invoices and Estimates Pro (GB0U3C0GN0000NE066) for PC Logo
1,789 people viewed this question
Top OnDemand Computers & Internet Experts
David Payne
David Payne
Are you an OnDemand Computer and Internet Expert? Answer questions, earn points and help others
