Question about HP Color LaserJet 2600n Printer
Get shadowed or double images. Didn't have this before I changed the cyan and the replacement is genuine HP
  • 3 Answers
This problem of vertical shadowing is a fusing problem.
The only way around it is to connect the printer to your network and browse to it with Internet Explorer, eg http://192.168.1.100 (check it's IP by 'Reports' & 'Config Page'
Once your browsed into it go to..............
Settings->Print Modes and set the plain paper Fusing to Less Fusing.
Get more discussion results
Posted on Feb 13, 2013
  • HP Master
  • 1,915 Answers
You may need to try running a couple of calibration sequences on this printer before it will print properly. Try putting the old cartridge in, if it prints ok then you know that they new cartridge is defective and you can ge it replaced. Defective cartridges do happen.
Posted on Mar 28, 2011
Blue Streaks & "Shadow Prints" on everything?
Mam, try replacing the cyan (blue) image unit may have a bad cyan image unit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 15, 2015 | Konica Minolta Magicolor 5450 Printer
Trouble c-2551 call service
Cyan Image Unit (Blue) Pull out cyan image unit not the cyan toner, Shake the image unit along the axis of the unit we want developer and toner spread evenly along the entire image unit. Then re-install. Reset code by closing and opening image unit door, not toner door. Worse case replace the image unit you do get bad ones.
Additional questions:
1.Is this a new unit?
2. Is it OEM or third party?
3. Is it new?
4. Did you chip it?
Sep 12, 2013 | Genuine Konica Minolta Konica Minolta...
BizHub C452 shadow printing
Recommended replacing the fuser unit. or is the color off not laying on top?
Jan 15, 2013 | Genuine Konica Minolta Konica Minolta...
Im seeing shadow/double images of text,icons etc.even a system recovery has not helped.what is causing the problem?
Most probably you have a problem with the connection between your graphics adapter socket & your monitor. Check this connection & make sure it is not loose & that the cable connecting your computer to the monitor is not damaged or is not running very close to a source of electromagnetic interference.
Oct 02, 2009 | HP Pavilion m7750n PC Desktop
Large Toner Streak... Bad Imaging Unit?
Check to see if you waste toner recycling for the cyan is working or being blocked. Check the transfer bias roller next to the cyan drum. Return you cyan imaging unit for a warranty replacement. Check for obstructions to the cyan developing unit. Check that the cyan IU was put into the machine properly. Check for toner leaking from the entrance to the developing unit or from the toner cartridge.
or, call a qualified KonicaMinolta tech to check out and service your machine.
Sep 12, 2009 | Konica Minolta Office Equipment & Supplies
Shadows and text curved. Double images
The convergence IC's need to be replaced. The generic part # on them is STK392-110. This is not easily done by yourself.
Apr 09, 2009 | Panasonic PT-53TW53 53" Rear Projection...
HP COLOR LASERJET 3500
Hi!
If you could possibly manage to access the machine status menu and have it print to check the drum's life, fuser life, developer, etc.. pls refer. Kindly replace the toner cartridge accordingly use the menu settings when replacing any color if needed. Please print solid image or block in each color Cyan, Magenta, Yellow and Balck. Well see if what color causing the problem. Please let me know the print result it may be; washed out or too light, too bright or black, double image, or not clean. Don't hesistate to contact me again about the result.
Best regards,
Rosener Guyano
Jan 31, 2008 | HP Color LaserJet 3500 Printer
HP Color LaserJet 2600n Printer Logo
204 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
