Question about Fellowes Powershred 4800CC Shredder
Bottom empty bin will not open to release contents. It was the first time I emptied it.
4 Suggested Answers
SOURCE: Fellowes S8-*5c
If this is actually an SB-15C I posted a solution elsewhere and will repeat it:
I called the toll free number for Fellowes Help Line, 800.955.0959, and spoke to John who was most familiar with the SB-15c. I indicated that the "bin full" LED was bad (actually the transmit bulb). After John ascertained that I had indeed cleaned the bulbs, he made available a replacement part, MasterCard or VISA required. Replacement of these bulbs is not for everyone. A level of technical ability and some tools will be required.
I have never had this level of technical support available on the first call. Kudos for Fellowes.
Posted on Jul 07, 2009
  • 610 Answers
SOURCE: SHREDDER INDICATOR KEEPS COMING ON WHILE SHREDDING
look for two LED lights where paper falls into bin and wipe them off, but the sensors could be faulty as well. I have seen both.
Posted on Nov 11, 2009
  • 41 Answers
SOURCE: BIN FULL ON CONTROL PANEL IS ON EVEN THOUGH
you need a bin full retrofit kit if it under warranty fellowes will install it if you need to buy the kit we have the kits cooksmobileshred@bellsouth.net 901-565-8188
Posted on May 10, 2010
How do I clean behind the fine net on the cyclone unit
CLEANING BEHIND THE CYCLONE MESH
1. Detach the Cyclone and bin from the main body as you would when emptying.
2. Standing over a bin. empty the contents of the cyclone by pulling the bin flap release button upwards.
3. Whilst the flap is still down detach the bin from the cyclone by pushing up the button on the middle of the cyclone.
4. Sit the bin to the side as you dont need to use it.
5. Get a pair of pliers
6. Use the pliers to pull the fins from the bottom of the cyclone. 1 by one you will hear them click out of position. When you pull the 4th and final fin the baffle will detach and you will then be able to clean the baffle and also the cyclone.
Apr 24, 2014 | Dyson DC07 All Floors Bagless Upright...
Hi, I have a relatively new Dyson DC19 and the
Hi David, it's Jack at Dyson.
I'm surprised to hear you've having difficulty emptying the bin on your DC19, as this should be straightforward. It's possible the catches could be a little stiff if they haven't been opened before, but our online Support guide shows what you need to do: http://www.dyson.co.uk/support/dc19t2/dc19t2/how-to-use-your-dyson-vacuum/emptying-the-clear-bin-step-1
If you do need further help after you've given this a try, please call our freephone UK Helpline on 0800 298 0298, or email us at askdysonUK@dyson.co.uk
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Aug 11, 2013 | Dyson Dc19db Multi Floor Cylinder Vacuum...
Deleted recycle bin
It depends on what version of Windows you are using. If you open Windows explorer by pressing the "windows" and E key at the say time you should see it. Otherwise, modify your display settings as the option to show the recycle bin is usuall there. Another thing you can do to empty the recycle bin is to run a disk cleanup, as this will give you the option to empty the recycle bin as well.
Jul 29, 2013 | Fujitsu Computers & Internet
I do not know how to remove the canister that catches the dirt. I do not have a manuel.
Sorry to read about your problem, I hope this helps you out.
Emptying the Clear bin caution: (i) switch 'off' and unplug machine before emptying the bin.
Empty as soon as the dirt reaches the level of the MAX mark - do not overfill.
To remove the clear bin from the machine press the button at rear of carrying handle. to release the dirt, press the button again to open the bin.
Please note: (i) Do not use the machine without the clear binin place.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Model 106.57789704 - ice wont release into door bin
This probably is not what you wanted to hear but... I recommend you to the human manual defrost method to free things up as a result of the ice that built up post power failure. That somewhat messy method being:
1. Unplug the unit.
2. Remove Freezer contents (You do not need to empty fresh food contents)
3. Place a fan blowing into the freezer section for around 2 hours. (Messy part so be ready to tend to the drips with rags & mop)
AFTER 2 HOURS
4. Take a rag or sponge and remove most of the water out of the ice maker as best as you can after the manual defrost.
5. Completely empty the ice bin of all ice or water paying particular attention to the auger making sure there is no ice at all in the auger.
6. Plug in the unit.
7. Reload Freezer contents.
This should get things back to normal. If not there is much more that can be attempted. At this time I really believe that the above procedures will normalize your unit. If and when you need more assistance just respond here I and I will gladly assist you.
Thanks for choosing FixYa.
Kelly
Jul 29, 2010 | Kenmore Refrigerators
Please tell me how to empty a Dyson Dc05. I don't have instructions. Thanks
Hi its Darran at Dyson.
To empty your DC05, press the button on the top of the machine at the front of the carrying handle to open the lid. Then lift off the cyclone top and bin assembly. Over a dustbin, press the button on the front of the cyclone/bin assembly to separate the two sections. You can then tip the contents of the bin directly into the dustbin.
For full step by step instructions on how to empty the bin, please visit www.dyson.co.ukl/support.
Kind regards
Darran
Dyson Customer Service
Jan 08, 2010 | Dyson DC05 Bagless Canister Cyclonic...
HOW DO YOU EMPTY THE BIN ON A dc07
Grasp the handle on top of the cyclone, then press the button which will be just by your thumb. That releases the cyclone (with bin attached) from the rest of the machine. Then unscrew the cyclone from the bin. Job done.
Dec 22, 2009 | Vacuums
Shows more stored on hard drive than is there. Keeps saying hard drive space running out.
Empty the "Recycle Bin"? Files are not really gone until you empty the contents of the "Recycle Bin". They still take up drive space.
Oct 08, 2009 | Gateway M275 Tablet PC
Dyson DC07 Clear Bin Flap will not release
I just received my replacement root cyclone in the mail today after waiting in the back-ordered status for three months. I positioned a butter knife in between the rubber gasket on the bottom flap lid and the bottom rim of the clear bin at the farthest point from the hinge and slowly and gently wiggled the knife between until the bottom flap just fell open. I examined the rubber gasket and it survived without injury and the bottom flap seals without any gaps...good luck
Jun 07, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Bottom of dirt container doesn't stay closed
The catch/latch that is on the bottom of the bin button release has likely broken.
If you take out the canister (as when you are dumping the bin), and flip it upside down and then squeeze the bin release button, you will see that it moves a rod inside the cyclone assembly.  At the end of this rod is a plastic (plastic.. redundant, as the entire Dyson is practically plastic) latch that catches onto the bin's lid and locks it in place.  A broken latch means it doesn't lock the lid in.
What you need is a replacement latch.  Note that the "Bin Release Button + Rod assembly" that are sometimes sold on ebay do *not* contain the latch at the end of the rod.  Also the bottom bin assembly does not contain the required parts.
The cyclone assembly should have the full bin release rod + latch, so if you can't find the latch, then a new cyclone assembly would work also (but will cost more, obviously).
Oct 09, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
29 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
