How many PSI = 1 HP - Office Equipment & Supplies
  • 96 Answers
PSI is a measurement of pressure, and HP is a measurement of power. Because they are not the same unit of measurement they are not interchangeable without other variables.
Posted on Apr 04, 2011
1/2 hp suddendly quit pumping. has 50 psi motor kicks on but no water
check for water supply problems to the pump
could need priming or a release of the pressure to make it switch back on
Oct 13, 2017 | HP Office Equipment & Supplies
Can I get 80 psi with dials set at 40 psi
this compressor should be able to fill your tires to 80 psi. Look for a pressure switch and adjust it so the motor shuts off at a higher pressure. Do not exceed 100 psi.
Sep 08, 2014 | Air Tools & Compressors
Why would my 1 hp pump only maintain 45 psi running 1 garden hose?
Without knowing all your variables with well it is hard to say. Bladder tank needs to have 30 psi with no water pressure. It is possible that the screen down the well is restricted and you are only getting that much water. Or you may have clogged impeller in pump.
Sep 04, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
PUMP JUST RUNS AND WONT SHUT OFF MQ3-45
DOES THIS SYSTEM FEED YOUR HOME.DOES IT HAVE PSI TANK. WHAT COULD BE HAPPENING.IS.THERE IS A PRESSURE SWITCH (fyg-2) THAT WAS INSTALLED ON YOUR SYSTEM. THIS ITEM, DEPENDING ON IT'S MANUFACTURE.COME PRESET AT 20/40 PSI OR 30/50 PSI OR 40/60 PSI. THAT MEANS ON START/OFF START PSI. SO IF YOUR PUMP CONTINUES TO PUMP AND WON'T TURN OFF.YOUR SYSTEM PUMPS MAY HAVE SOME WEAR TO IT OR A POSSIBLE HOLE IN THE DROP PIPE THAT IS NOT ALLOWING YOUR SYSTEM TO REACH PSI THAT IT SET FOR. ALL U HAVE TO DO IS READJUST THE PRESSURE SWITCH TO THE PSI READING THAT IS ON PSI GAUGE.
Oct 28, 2011 | Grundfos MQ3-45 1 HP Pressure Booster...
1 hp 3gal craftsman compressor will only build up to 20lbs pressure in tank. how much compression should single cyl have on compression stroke?
A piston in any engine should be around 100 psi I would guess. A Chevy 350 used to be around 150 psi. An air compressor that only pumps enough air to reach 20psi is obviously too low on compression. Nailers and the like need 80 or more psi. The intake valves may be shot, the unloader might be stuck or piston rings are worn.
Dec 08, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Need Manual for Husky Model 41214 Air Compressor
You can get the manual for model 41214 from my dropbox area:
http://dl.dropbox.com/u/54567653/husky_aircompressor_model_41214.pdf
BTW, if you find this manual helpful consider installing dropbox using this link (full disclosure -- I do get about 0.2 GB freespace from dropbox if you install using this link):
http://db.tt/vQycqXIW
Thanks,K
Dec 20, 2009 | Air Tools & Compressors
Compressor shuts off before reaching max pressure
Yes,but if the max is 125 you don't want to increase it above 110 and set off the pressure relief valve.
Jul 21, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Pump runs continuously with not water
replace the pressure guage.
prime the pump by pouring in water in the impeller basket area and replace lid-try running pump again
Mar 22, 2009 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Will a 1/3 hp compressor fire an 18 guage 5/8'-2" Finish nailer?
You compessor is ideal for a small spray gun however a pin nailer requires 80 to 100 psi and a small air storage thank to operate properly. The nailer may very well shoot a short nail into very soft wood at 30 psi, however there may not be enough pressure to push the piston back to top positon to load another nail and fire again. Good Luck
Jan 31, 2009 | Air Tools & Compressors
35 people viewed this question
k24674
jasbo
jasbo
