Question about Amana ARS2661BS Side by Side Refrigerator
I have an Amana side by side. Freezer and refrigerator gets warm. Took back panel off and coils are frozen. melted the ice off and works great for about 2 weeks and then does the same thing. What can I do to fix it?
    Problem Solver:
  • 8 Answers
Probably your defrost timer or the defrost element. If you take the leads off of the element and test it with an ohmmeter you'll be able to determine if it's blown.
Posted on Mar 27, 2011
Freezer not cold enough fridge fine
The issue is the defrost timer.
Jul 10, 2013 | Amana Refrigerators
Freezer door not sealing at bottom right side
if you removed the inner section of the door for the drying process then it is possible that the door has warped and you have locked it in that shape on installation of the inner section
loosen off the screws and twist the door so that it touches all the way around , then retension the screws
make adjustments at the hinges after that
Jul 09, 2017 | Amana SXD524VW Side by Side Refrigerator
Over a period of days the freezer gets warm then cold. Ice begins to melt then freezes together. Ice cream gets soft, then hard. I removed the panel in the back of the freezer. Unlike other defrost...
The refrigerator is sticking in defrost mode...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 20, 2010 | Amana Side-By-Side Refrigerator 26 cu. ft...
Freezer section is no longer freezing or keeping anything but ice frozen. It's 11 or 12 yrs old. Maintains refergerator tempature, but the freezer size no longer keeps things frozen, even if the...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 22, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerator is warm, but freezer works. Coils are frozen.
you are having a defrost problem, probably needs if it is a maytag, it probably needs a control.
Jun 15, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
Amana side by side ars2365ac
That fan is most likely on trying to defrost that frozen coil. It sounds like you may need a thermostat, a coil cleaning, and hopefully the system is not low on charge, those are 99% of the causes for a freezer, or refrigerator to freeze, hope all works out.
Feb 15, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Freezer fan stopped working
Sounds like you need a new fan motor. First make sure the fan blade turns freely and see if you can move the shaft side to side, or up and down. If you can feel any movement in the fan shaft the bearings of the motor are bad. It is possible for some ice to have the fan blade frozen causing the motor to stall. Some models also have a fan light switch install at a point near the hinge side of the door.
May 02, 2008 | Haier HTE21WAAWW Top Freezer Refrigerator
Amana BX22A2W - freezer works, fridge not cooling
Same problem here with an Amana refrigerator with the freezer on the bottom. I removed the back panels and vacuumed dust and cat hair out. The back panel in the freezer was frosted over with ice on the bottom. I removed the shelves and food and used a hairdryer to loosen the panel. The ice maker made it harder to remove the plastic panel so I pulled it back and saw the cooling fins frozen solid. I used the hairdryer to melt the ice and a shop vacuum to collect the water. It works like new again.
Dec 02, 2007 | Refrigerators
Drs2662aw amana side by side
Sounds like you may have a restriction or blockage, may also be low on freon
Aug 23, 2007 | Amana ASD2326HE Side by Side Refrigerator
Amana ARS2661BS Side by Side Refrigerator Logo
90 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
