Question about Bosch Washing Machines
My machine has been very noisy for a few weeks and today I put on a cycle and the drum didn't spin at all. Any ideas, ny machine is 10 years old!!
    Genius:
  • Bosch Master
  • 1,474 Answers
Noise could be worn drum bearings in which case pulley would wobble knocking off belt, hence no spin......
Posted on Mar 27, 2011
Last load of washing has lots of black dirty marks on them
It would appear that the drum seal and bearings have failed. If you have been doing constant cold water washing and using fabric softener and the machine is over 5 years old, I would say its time for a new machine. There are not many that last past 5 years any more especially with cold water and fabric softener usage. Bearing and seal replacement can be very expensive. The drum shaft (Spider assembly) will probably need changing as well.
Dec 21, 2017 | Zanussi FLA1101W Front Load Washer
Loose drum
If your machine is a front load washer, and it's a few years old a loose drum which is noisy, probably means that the bearings at the rear have collapsed.Water gets through the seal and goodnight bearings and probably the shaft as well......Sorry......Nomess
Apr 18, 2010 | Washing Machines
My Hotpoint BWD129 washer/dryer has got noisier and noisier during the spin cycles. It is now so loud it is unbearable to be in the same room as it and it rattles anything off the worktop nearby. Any...
This is most likely the drum bearings failing.
Drum bearings normally last a long time (10 years or more isnt unusual), but quite often drum bearing failure is caused by a faulty drum shaft seal allowing a small amount of water through and in to the bearings. The bearings then start to rust and this accelertes how quickly they deteriorate.
Replacing a drum bearing requires well above average DIY skills, so unless you feel you can do it, can get hold of a tech manual, and can find a supplier for the bearings, it's time to get a quote from an engineer.
Nov 13, 2009 | Washing Machines
Very noisy on spin cycle only
Hi, please describe the type of noise you are hearing. If it is a grinding type noise, it is likely to be the drum bearing.
Oct 25, 2009 | LG WM1814CW Front Load Washer
Washer noisy in spin cycle
It sounds like your drum bearings are about to go. I am not familiar with this model, but I would assume it is pretty much like all other front-loaders. Bearing kits can be purchased for all models but there is a great variance in cost eg. in europe €25-€75. It is also quite a difficult job to undertake for the sunday diy enthusiast as it involves stripping down the machine and removing the drum. If you are going to repair the machine as opposed to replacing it I would strongly advise doing it asap and continued use will cause the bearings to collapse rendering the machine irrepairable. Hope this helps.
Jun 27, 2009 | LG WD-1280FHD Front Load Washer
Runs great stuck on rinse cycle
Peace,
ngafm to your rescue,
Yes it is in the dial and mechanism of the timer!
Things wear out! So is life!
Only a trained laundry tech can make the electronic diagnoses.
How old is the washer?Sounds old!
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Sep 06, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine
Peace Friend,
ngfam1 At your service!
1-it may be the belt squealing or high pitched nosies telling you it wants to go!
2- It more than likely is the rolling suspension that the drum spins on!I've seen the older models with one of 3 wheels that the drum rolls on is worn and wobbling or screaming or screeching etc.
3- I've seen also a few times that the motors heat shield, a simple piece if tin with two screws or bolts holding it down was "loose" and vibrating causing a loud metal squeal noise all the time or intermittently!!
If I were there hands on I could fix it!
Unfortunely, another point to consider!!
How old is the appliance?
You will be fine
Bless You ngafm1
*****PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF*****
Aug 05, 2008 | Kenmore 24032\24036 Top Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
My old Hoover top loader Washer is noisy & doesn't spin out properly - how can I fix it?
Sounds like the switch which cuts the machine off when the load is unbalanced. My guess is that: This switch is being triggered too easily The springs holding the bowl up are either stretched or one is broken; The machine may not be level.
Mar 30, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
88 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
