Question about GE WWSE5200B Top Load Washer
Washer machine model WWSE5200B2WW - will occasionally not start, will start fill and then stop, or occasionally go through the cycle to final spin and not shut off. It has started over a few times after completing the full cycle. On a few occasions, it wouldn't start at all - unplugged and plugged back in and it worked.
  • 4,323 Answers
Hi
The issue is with the motor that is bad and should be replaced. If it was the control board then it won't even start. You can check this diagram and buy the parts from this link. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 27, 2011
Kenmore washer model #417.42042100 is not spinning the clothes all the way.
First you need to open the cabinet and remove the boot from the tub to the pump and clear the filter. Try that then run a cycle and post back the results.
Dec 05, 2012 | Washing Machines
I have an asko 11505 clothes washer. For some reason, it is not going through all of the spinning cycle, it spins for a short time, then stops abrutely. I cleaned the coin stop, cleaned out all water...
My Asko 11505 washer fills only a little water then shuts off. If I drain the washer with the drain hose from under the machine, then the machine will start up and fill enough water to fill the hose again, then shut off.
Oct 19, 2009 | Asko Washing Machines
Won't stop filling. When I go through the cycles it continues to fill until I reach the final spin cycle then it will start draining and spin out.
Two common problems for this simptom:
If water stops filling when you disconnect the washer:
Change the pressure switch.
If water keeps coming in after you disconnect the washer:
Change the water valve.
GOOD LUCK MY FRIEND
Aug 30, 2009 | GE Washing Machines
Cold water pours in during final spin
No - the timer is the likely suspect.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
There is something clogging your pump, dismantle it to clear it. Plug off the wall socket mains first.
Jan 15, 2009 | GE WDSR2080D Top Load Washer
Washer fill with water after final spin cycle
CHECK THE TIMER MODULE ,the one you pull and push to start and to stop ,that could be damaged , try different cycles , like DELICATES cycle , see what happens, hope it helps AJ
May 05, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
70 series Kenmore washer
POWERUP, YOUR WASHER COULD BE THE LID SWITCH OR THE COLD WATER VALVE. AT THE END OF THE WASH CYCLE, THE MOTOR WILL SPIN OUT THE WATER, BUT ONLY IF THE LID SWITCH IS ACTUATED. IF THE SWITCH IS BAD, IT WILL NOT SPIN OUT THE WATER AND THE TIMER WILL NOT ADVANCE FROM THAT POINT.
IF THE WASHER SPINS, THE NEXT STEP IS TO FILL WITH WATER FOR THE RINSE CYCLE. MOST WASHERS USE COLD WATER FOR RINSES. IF THE COLD WATER VALVE IS RESTRICTED OR FAULTY, THE WASHER WON'T FILL. IF THE WASHER WON'T FILL, THE WATER LEVEL SWITCH WON'T ACTIVATE AND THE TIMER WON'T ADVANCE TO THE NEXT STEP.
Mar 31, 2008 | Kenmore 22422 Top Load Washer
Washer will not Spin during SPIN CYCLES
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. (consult your manual to know where/how filter is cleaned). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 29, 2007 | Washing Machines
Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
May 17, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
GE WWSE5200B Top Load Washer Logo
115 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
