Question about Kodak EasyShare EX1011 Digital Picture Frame
Kodak Easyshare SV1011 turns red and then pictures come up and they are all red and then shuts down after about 5-10minutes?
mcomijohns
  • 477 Answers
SOURCE: Bad pictures on my Kodak easyshare M753
Your CCD is out this is the unit that converts light imaged to data and has gone out. it needs replacement. normal ccd run 65.00 installed. goto www.digitalcamrepair.com for contact information.
Posted on Jul 19, 2008
  • 3 Answers
SOURCE: Screen turns black after taking a picture
I also have a Kodak Easyshare and when mine did that I had dropped it and had to send back to factory for repair with no warranty on it if it had been dropped.
Posted on Jun 02, 2009
  • 8 Answers
SOURCE: My Kodak Easyshare M1063 won't turn on
Try cleaning the contacts from the battery and the battery compartment of the camera. I had the same problem and this fixed it, it seems to be a common problem.
Posted on Aug 15, 2009
shockwave727
  • 262 Answers
SOURCE: I turn my camera on, the green light blinks then
Red light indicates that the battery is out of charged
are you using the recommended battery the (KAA2HR or Ni-MH). If yes make sure that your charger is working fine.
now if your charger is working fined the second you need to do is to recondition the battery or purchased new KAA2HR battery it means that the chemical content on the said battery is already crystallized., this is also applies to your C530 since their using dame battery
Posted on Nov 03, 2009
shockwave727
  • 262 Answers
SOURCE: kodak easyshare c530 troubleshooting won't start
Red light indicates that the battery is out of charged., Now if th ebatetry is out of charged there will be no chances for you to connect it using your computer., C530 will not charged using the USB cable., try to charged the batetry or purchase new sets of battery
Posted on Nov 17, 2009
I have misplaced the user manual for my SV1011 Kodak Easyshare digital picture frame. How can I download music to play, along with my photos?
You can view/download the manual at
http://support.en.kodak.com/app/answers/detail/a_id/18780/kw/sv1011/selected/true
The relevant instructions are in "Playing music" under "Doing more with your frame".
Jul 10, 2011 | Cameras
Tip
Kodak EasyShare Z740 Turns Off Fix Does your Kodak EasyShare Z740 Turns On...
Does your Kodak EasyShare Z740 Turns On Then Turns Off right away?
Does your Kodak EasyShare Z740 Turns Itself Off with new AA batteries in it?
Many of these Kodak EasyShare Z740 cameras that shuts off right away and will not stay on, will actually stay on if you select FAVORITES to view pictures, but just flash back and turn off if set to auto or camera mode. Try this.
If the lens cannot extend, the camera will turn itself off. You can try giving the camera a thump with the heel of your hand, but I would recommend servicing the camera rather than smashing a delicate digital instrument. After trying the steps below, a last chance alternative that works for some people is to grab and actually PULL the lens out as it tries to extend itself. Again, its delicate; if you can afford it, maybe pay for servicing before hitting and pulling on your camera.
However, before servicing your Kodak Z740 try this fix:
  1. Hold down the Time/Ascending Folder button (the button under OK on the circular panel)
  2. While holding that down, press and hold the ON/OFF button.
  3. The camera may turn itself on and stay on this time, acting normally again.
If this doesn't work for your try this:
  1. Hold down the '>' button (the one that brings you to picture review)
If that doesn' t work, try again with the 'Trashcan' button, and ON/OFF button.
I hope that helps.
____________________________________
Kodak EasyShare Z740 Manual Download
on May 01, 2010 | Kodak EasyShare Z740 Digital Camera
Camera shuts off after taking one picture and put in new batteries.
I may be able to help with your Kodak EasyShare Z740 that turns itself off.
Try these steps to fix your camera.
I hope that helps.
_____________________________________________
Mar 30, 2010 | Kodak EasyShare Z740 Digital Camera
KODAK SV1011 ALL PICS HAVE A RED HUE??? ANYTHING
1 utf-8 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Try these troubleshooting steps:
1. Turn the frame off.
2. Unplug the power cable from the wall outlet.
3. Remove any memory card or flash disk from the frame.
4. Connect the power cable directly to a wall outlet.
5. Turn the frame on.
6. Use a paper clip to press the button inside the pinhole on the back of the frame.
If after trying the above steps and the frame still have the same problem, then we need
to send the frame in for a repair as per warranty guidelines.
Your frame will be repaired per warranty guidelines. A product is warranted for 1 year from the date-of-purchase. For an In-Warranty repair, a “Proof-of-Purchase” is required. If the repair center finds any customer induced damaged, the warranty will be voided and you will receive a notification from the repair center in such cases.
Process the repair at www.kodak.com/go/itg
Dec 15, 2009 | Kodak EasyShare EX1011 Digital Picture...
When i upload photos to kodak easy share...it duplicate the photos
Rebuilding the catalog might solve your issues.
If your on Windows XP
Shut down Kodak Easyshare SW, also shut it down from the system tray near the clock.
Go to C: then Program, Kodak, Kodak Easyshare Software, the Bin Folder, rename the catalog folder and change it to OldCatalog.
Then on same window click on search on the top of your screen and type on the search box ESBK, once you found it, delete the two icons that says ESBK.mb and ESBK.mbb.
Then relaunch the easyshare software then try to transfer again those pictures.
Hope this would help.
Aug 25, 2009 | Kodak EASYSHARE M1063 Digital Camera
My Kodak Easyshare 1011 has recently started to turn off
The firmware of your digital picture frame needs to be updated but since you can't do anything because after a few seconds the frame will shut down it needs to be send for repair. To process repair visit www,kodak.com/go/itg. Follow the troubleshooting guide page and at the end of the troubleshooting guide you will be able to fill up a form to send frame for repair.
Jun 06, 2009 | Kodak EasyShare EX1011 Digital Picture...
How do I get music into SV1011 digital Picture frame
There is no internal memory on your frame. Therefor you must transferre the music onto the SD card and then it will play from your frame.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Mar 09, 2009 | Kodak Digital Picture Frame
Kodak EasyShare EX1011 Digital Picture Frame Logo
138 people viewed this question
Top Kodak Photography Experts
Bill Eager
micky dee
Are you a Kodak Photography Expert? Answer questions, earn points and help others
