Question about Wharfedale Valdus 500 Speaker
Can a tear in the rubber around the speaker be repaired
    Brigadier General:
  • 8,546 Answers
Http://www.ehow.com/how_4922557_fix-stereo-speaker-foam-perimeter.html
Many sellers on eBay sell repair kits. Identify the speaker diameter and look around.
Posted on Mar 27, 2011
My right speaker has stopped working. Any work around this? by tearing it open?
Unlikely. Check the wiring and the plugs. If they are OK, then you will need to take them apart. The right one is the one that holds all the amplifier parts. The left one is just a speaker.
If you are in the market for new ones, I can recommend Bowers and Wilkins MM1s. They are pricey, but high quality, have a warranty and are repairable. I have been around the factory.
Logitech have support for your speakers here
Logitech Support
Nov 21, 2015 | Logitech Z320 Speaker System
I have a 13w7 and i am wondering if its possible to find the replacement foam around the top of the speaker. mine has a tear in it and i find it hard to believe that the speaker would be wasted because of...
The foam is molded, you can not remold / repair
If it is a small tear you can repair with a bit of rubber cement. Eventuly it will fail and more will tear causing the sub to sound very bad
Sep 27, 2010 | Jl Audio 13W7 Car Subwoofer
Repairing 1/4inch tear in foam around sub
click the picture for product website
I used this stuff to repair a tear in the rubber surround on a kicker solobaric 10", it has held up for 10 years, seal the front and back if possible and allow to dry/cure completely. good luck :)
Feb 14, 2010 | Car Audio & Video
Water leaking in front of washer mainly from what seems to be the gasket around front of washer.
Either the rubber boot is damaged in some way, or the door is not locking tight enough. Thoroughly inspect the boot for tears or gouges in the rubber surface. Small imperfections can be repaired with silicon glue, but larger tears will require replacement of the boot--which can be done done through the door opening, but requires patience to do so. Inspect the door lock for damage or wear if the boot looks to be in good condition.
Oct 12, 2009 | LG WM2277H Front Load Washer
Espresso machine rubber ring tear causes water leak
hi may i know whether Electrolux Pump Espresso Model EES200 can make single shot of espresso? Cos I tried but the machine only make 1 cup of coffee. Please help. Thank you
Sep 09, 2009 | Electrolux Coffee Makers & Espresso...
Buzzing/humming noise that increases as you raise volume. So loud that you can not even watch tv
Hello snow1525,
You may have a torn speaker element. This is usually the cause of buzzing noise in the sound, also you may have a bad capacitor in your audio section. This is what I would suggest doing as a test open the front bottom panel of your TV and visually inspect the speakers for signs of ripping and or tearing in the speaker element. If the element or elements are torn it may be possible to repair it with rubber cement or rubber paste just coat the tear with the rubber cement to hole the torn edges together and allow it to dry for two days before testing the sound. If the speaker elements are not ripped then the problem may be a bad capacitor either in the audio section (power supply) or in the filter block (usually attached to the speakers to separate bass and treble signal to the speakers.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Apr 16, 2009 | Televison & Video
Speaker repairs
fingernail polish....it works great and stays flexible
Jan 05, 2009 | Blaupunkt Vx652 2-Way Speaker Car Speaker
Rubber gasket around opening
Iserial #15616047cc i want to know how to repair it my self
have a ANANA washer machine model alw 480daw
Jan 27, 2008 | Bosch WFMC 3200 Front Load Washer
Kicker l7
That is called a suround my freind. depending on the exact size of the foam surround they are available with good instructions at many many places that do speaker repairs on-line. Heres one I have used in the past http://www.simplyspeakers.com/2doityourself.htm?src=overture Like I said there are tons of them available on-line. Simply search for speaker surround repair. Good Luck Please do not forget to rate this thread.
Dec 15, 2006 | Kicker Solo-Baric L7 12'' Car Speaker
Wharfedale Valdus 500 Speaker Logo
261 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
jason
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
