Question about Wowwee Robopanda Robot
The arm has become disconnected from our Robopanda. It looks like a screw has sheered off. Can this be fixed?
    Problem Solver:
  • 10 Answers
I think u know up your answer. you should tight that screw.
Posted on Mar 27, 2011
  • kimgarrigan Mar 27, 2011
    The screw is a machine screw and has sheered off and the other end is inside the arm housing.
How do I remove door panel on 87 C4 Vette
to remove door trim you have to disconnect negative battery cable.then remove two screws attaching arm rest to door trim.remove arm rest it held in place by front and rear hooks that fit into slots in door trim.to release the hooks grasp the arm rest with both hands push it towards thr door pull up on the side of the arm rest facing door.remove four speaker grille mounting screws and the grille.then remove door trim panel screwss from bottom edge of the panel.remove the three remote control plate screws from the plate and the single screw in the rear edge of the door.then lift up on the door trim panel to release the molding from the top edge of the door then slide the panel forward to clear the latch release handle and down to clear the lock rod knob.if job look to difficult let a body shop fix.removing window door motor need tools to drill out rivets and reinstall rivots you need special tools to fix window motor and regulator.
Apr 14, 2013 | 1987 Chevrolet Corvette
My robopanda is in spanish
Use Translator for that prupose buddy
Dec 21, 2012 | Wowwee Robopanda Robot Panda With Mini...
Robopanada wont turn on
hi i bot robopanda sec hand and he was working fine untill i put new batterys 4 rayovac 4.0 aa batterys it worked just two seconds the everything whent dead and i,m unable to start him agine i even pushes the reset button im so un happy about this please please help me martin.
Dec 28, 2011 | Wowwee Robopanda Robot
I'm looking for instructions on how to replace the window wiper motor and switch
Windshield Wiper Motor Removal & Installation To Remove:
Using the J 39232, remove the wiper transmission from the wiper motor crank arm. gmpc_wa_1.gif
  1. Remove the wiper arms
  2. Remove the air inlet grille panel.
  3. Disconnect the connectors from the wiper motor assembly.
  4. Remove the three screws and the wiper drive system module.
  5. Using GM special tool J 39232 or equivalent, separate the wiper motor crank arm from the wiper drive ball joint.
  6. Remove the wiper motor crank arm from the wiper motor.
    • Remove the rubber boot.
    • Loosen the mounting screw.
    • Tap on the screw with a plastic or leather faced hammer while supporting the wiper motor crank arm.
    • Tap the screw until the crank arm is loose.
    • Remove the screw and crank arm from the motor.
  7. Remove the three screws and separate the wiper motor from the module assembly.
To Install:
  1. Position the wiper motor on the wiper drive system module assembly. Install the three mounting screws. Tighten the screws to 62 in lb (7 Nm).
  2. Install the wiper motor crank arm on the wiper motor.
    • Connect the wiper motor electrical connector.
    • Turn the wiper switch to the accessory position.
    • Turn the wiper switch to the pulse position.
    • Turn the wiper switch off when the wiper motor is in the middle of the wipe cycle.
    • Disconnect the connector from the motor.
    • Maintain a gap of 0.157-0.314 in (4-8 mm) between the wiper motor crank arm and the bracket tab. If the gap is not 0.157-0.314 in (4-8 mm), remove the wiper motor crank arm and repeat installation.
    • Install the mounting screw. Tighten to 142 in lb (16 Nm).
    • Install the rubber boot.
  3. Position the wiper drive system module on the vehicle. Install the three mounting screws. Tighten the screws to 68 in lb (10 Nm).
  4. Using GM special tool J 39232 or equivalent, connect the wiper motor crank arm to the wiper drive ball joint.
  5. Connect the wiper motor assembly electrical connector.
  6. Install the air inlet grille panel.
  7. Install the wiper arms.
  8. Check the windshield wiper operation.
Oct 28, 2010 | 1999 Buick Regal
Transmission cable falls off linkage arm
I'm looking for this part too. The shifter arm in my Trailblazer has become disconnected from the transmission cable and I currently have it held on with wrap ties. Any luck finding this part and installing it?
Apr 13, 2010 | 2002 Chevrolet TrailBlazer
I have 2004 saturn vue and the rear door latch on the passenger side will not latch shut. i have taken it apart and it looks like a small black box.where could i find a cheap one, or an easy solution to...
It sounds like the the linkage, actuator (power locks), or the mechanism has broken or become dislodged. On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls. Pull back the weather seal and you should see everything and hopefully see the cause.
Apr 07, 2010 | 2004 Saturn VUE
Handle on top oven is disconnected
On the plastic part if pieces large enough:no fast cyano-acrylate superglue to be used. use 2 component epoxy based glue. super glue can't restit water and temperature and really never works. Get to the screw by dismantling the door looking at how it is screwed to gether. Usually from the inside.
Top is you can order an original replacement. Sometimes by local handu man store. If the construction is such that was screwed in from outside then it becomes a driling out procedure with a small HSS drill. Try to center point that screw a pit that the drill wont run away. Another trick is trying to make a square groove and screw it out. This is almost impossible if nothing sticks out. If sticking out you can use carefully thin metal saw or catch it with right type pliers. Trying to drill from the inside is a good way because driill goes right direxction to screw it out or the screw is sticking out far enough to use pliers for turning pack out or the saw method to make a groof for screwdriver. Wenn all fails:b drill all out, use larger screw. If needed thread it. If no success at all, check back
Apr 17, 2009 | Maytag MGR6772BDS Gemini Gas Kitchen Range
1996 honda accord windshield wipers
Sounds like the wiper arm has become disconnected. There may be a clip or bushing that has broken or fallen off. The wiper motor/arms etc are accessible by taking the cover off (usually plastic and possibly held in by screws or large plastic slots) that's at the base of the windshield. You may have to lift the hood for access and removal. Just take your time and don't force anything.
It's really simple after that. You turn your motor on and look for moving parts, that'll be the wiper motor. Either it's disconnected at the motor or it be disconnected on the arm. Usually one arm will move both wipers. If you're lucky, maybe it's just fallen off and you can find the clip or bushing and re-attach it. Otherwise, you may have to get a new part, which in this case would probably come from the dealer.
You may possibly also get it from a junkyard, but chances are if it's a small part, then they may not sell it to you. However some junk yards WILL sell you these small parts, and others may even let you pull the part yourself. If you could do this, you could also see how the part properly attaches.
If it's confusing how to re-attach the parts, then you may have to buy a Haynes or Chilton manual to see exactly how everything looks. Diagrams would be great. If there's no good pix in the manual, then try online. The best would be to see fully functional operating wipers on a similar car. Maybe find a buddy to take a peek at his after you practice on yours.
The part if broken should fit multiple years of your make of car.
Get this fixed soon because not only will it not pass inspection, but it is highly unsafe.
Feb 10, 2009 | 1996 Honda Accord
Wowwee Robopanda Robot Logo
51 people viewed this question
Top Wowwee Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Wowwee Toy Expert? Answer questions, earn points and help others
