Question about Victor ® 000TE Replaceable Tip End ® 000TE Replaceable Tip
What do i have to do to convert a n acetylene torch to use propane?
  • 6 Answers
Usually I have just changed to the appropriate brand of propane tip for that style torch IE: if you use a victor torch take out the acetylene tip and replace it with a propane one making certaing the seats are correct.
Posted on Mar 29, 2011
Remove ford f250 catalytic converter
Well the normal way would be to use a acetylene torch an heat it up cherry red an twist it off . Not the cat , the connections .
Oct 13, 2016 | 1990 Ford F250
Can I fusion weld light gauge sheet metal with L.P.G. instead of acetylene.
Anon, I use L.P.G. and Oxy, for cutting metal and for silver welding/brazing , a little fussy and not as hot or quick heat as acetylene. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oxy Propane welding
How to bronze braze with LPG or butane gas
Can use Propane instead of Acetylene
http://www.hobartwelders.com/weldtalk/archive/index.php/t-36696.html
Jun 02, 2016 | Welding Tools
How to remove front wheel bearing is a special tool required ?
I had to do my 2001 Yukon XL and it took about 4 hours of beating on a chisel with a short handled 10 pound sledge hammer to seperate the bearing from the hub. Even applying heat with a propane torch didn't help, if you had access to a acetylene torch it probably would have went quicker. I wanted to give up 5 times but just took a rest and went back at it.
Apr 18, 2016 | Cars & Trucks
I need to replace the point on my auger. Is there a trick to removing the old one? I can't get it to budge
If there is no bolt or weld holding it on, it could be that you need to heat the shaft up, not the point, to get the metal to expand and release the point. You would need an acetylene torch to get it hot enough. A regular propane or mapp gas torch would not put off enough heat to expand the metal all the way through
Oct 27, 2015 | Garden
My 95 honda civic runs fine except when i put it in gear it stops running
This condition is usually caused by a bad intake manifold gasket. The failed gasket causes a vacuum leak which causes the engine to stall when placed under a load. This is a common problem. Some of them are pretty easy to change depending on the type of engine. There are a couple of ways to diagnose this problem such as a scan tool or a smoke machine. An alternative method is to use a hand held propane torch. Open up the fuel valve on the torch but, do not light it. with the engine running, point the tip of the torch towards the intake manifold. As you move the torch along the intake manifold listen to the engine for a change in RPM. If you notice a change then the gasket is leaking.
WARNING : This is a hazardous procedure that is best performed by a qualified technician. DO NOT use an acetylene torch for this procedure. Always wear safety glasses and keep away from moving engine parts.
May 14, 2011 | 1995 Honda Civic
Hi there, despite brand new torch, brand new regulators and gas tanks, I cannot get a decent hot flame on my oxyacetylene torch, and what flame I can get, goes out within seconds of heating a...
Hi:
If your flame goes out check the following:a) check your acetylene and oxygen pressure, for this kind of job acetylene should be at 4 psi and oxygen at 10.b) Check you're using the right type of nozzle for the job and this nozzle is clean.
Apr 04, 2011 | Smith 23-1001C OXY/ACETYLENE LITTLE TORCH...
Vacuum leak
I don,t know where your vacuum leak is but if you have access to an acetylene torch then you can use it to find the leak.Simply turn on the acetylene only and then run the torch tip around all of the fittings and lines until the engine revs up,that will be your source of leak.Let me know how you make out.
Aug 25, 2010 | 2004 Chevrolet TrailBlazer
I have a Miller Synchrowave 180 sd and have been having difficulty welding aluminum. Can you please help.
I'm not sure what it's doing to know why it's not working but if I was trying to weld aluminum I use 100% argon in ac with high frequency continuous and a 9 second post flow with 5356 crown weldind rod.
Jun 05, 2010 | Miller Welding Tools
Torch is used for jewelry work and is a acetylene air torch. the torch keeps going out when lite. also would like to know how to adjust the air flow on the tips and what it should be. thanks
Usually, the blow-out problem is caused by excessive fuel flow at first--too much pressure or valve is opened too far. Once you have a bushy acetylene flame, turn up the air source to bring the flame down to a fuzzy point near the tip end. Brazing and silver soldering work better with just a little less air. My experience is with an oxy-acetylene torch, but results are similar.
Jul 23, 2009 | Welding Tools
Victor ® 000TE Replaceable Tip End   ® 000TE Replaceable Tip Logo
116 people viewed this question
Top Victor Welding Tools Experts
Bill Boyd
Are you a Victor Welding Tool Expert? Answer questions, earn points and help others
