Hello, my wasning machine has been very noisy for a few weeks and today I put a cycle on and the water went in to the machine but the drum didn't spin. Any ideas what it could be? It is 10 years old!!
    Genius:
  • Washing Mach... Master
  • 1,474 Answers
Now if this is a hotpoint then it sounds like motor brushes, simple to fit parts cost about £14.....
Posted on Mar 27, 2011
We've been given a spare Bosch Maxx 900 washing machine by friends which hasn't been used for a few years. Have plugged it in, connected the hoses, and switched it on for a standard cycle 40...
Hello is this a front loader machine and if so in the back of the machine there are 4 bolts that go thru a 3' piece of plastic. they should be around the drum area they use these to keep drum stable while being transported so look for them. Hope this helps you out
Jul 21, 2011 | Bosch Washing Machines
My machine has been very noisy for a few weeks and today I put on a cycle and the drum didn't spin at all. Any ideas, ny machine is 10 years old!!
Noise could be worn drum bearings in which case pulley would wobble knocking off belt, hence no spin......
Mar 27, 2011 | Bosch Washing Machines
Hi! I have a Maytag Neptune front loading washer machine. On a few occasions I have found a small amount of water in the drum before starting my weekly laundry. Today when I went to start my laundry...
This is symptomatic of a water control valve not closing completely- its no power/fail position is closed.
Whichever it is, hot or cold, needs replacing!
Service call ;-0(
Good luck,
John C
Mar 06, 2011 | Maytag Neptune MAH5500B Front Load Washer
I went to use it today and it wasn't working properly. i set the laundry in, put in the detergent, closed the door and then deposited my money and selected the cycle. the machine ran for 1 minute then...
yes, your guess is most likely correct. Problems on the water supply into the drum of the washing machine. you can check the start of the tap water, hoses and water inlet valve Selenoid. Hopefully help.
Aug 18, 2010 | Maytag MAH21PDD Commercial Front-Load...
Loose drum
If your machine is a front load washer, and it's a few years old a loose drum which is noisy, probably means that the bearings at the rear have collapsed.Water gets through the seal and goodnight bearings and probably the shaft as well......Sorry......Nomess
Apr 18, 2010 | Washing Machines
Maytag Washer noisy & leaks lots of water from bottom of machine
the drum bearing are damaged due to water leak from seal inside the drum. that's why water on the floor. silicone paste mo use as it has other major problem.
Nov 02, 2009 | Maytag Washing Machines
Water drains during wash cycle. I have used this washer for many years without a problem. About two months ago I noticed that the water level in the drum was going down during the wash cycle. Last week I...
Take the drain hose out of the drain pipe and put it into a sink to test the machine
If that works make sure that the drain hose is being allowed to breath (ie let air into the main drain pipe so that the machine does not set up a syphon).
Jul 16, 2009 | Whirlpool Washing Machines
Drum will not rotate or spin
oooops - the motor was stuck under the carriage. Once
moved it came off easily.
Jun 17, 2008 | Bosch WFK 2401
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
