Question about Carrier 38BRC060 Air Conditioner
How many ton is a 38BRC060 - Carrier 38BRC060 Air Conditioner
  • 1,420 Answers
5 ton
Posted on Mar 27, 2011
Carrier 38brc060 fan motor will run about 4 minutes then stops. What could be the problem?
Probably overheating and would need replaced. Carefully touch back of motor to see if its really hot after it shuts off. If
it is really hot the motor is bad if its not hot its probably the capacitor is bad and needs changed
Nov 14, 2015 | Carrier Heating & Cooling
How do i test the large capacitor on my A/C compressor
You need a multi meter with a capacitor test mode on it to check it accurately. The large silver capacitors usually have a swollen end when they are shorted but not always.
May 09, 2014 | Carrier 38BRC060 Air Conditioner
Compressor blow circuit breaker when turned on.
Yep and your compressor has given up the ghost it shouds like.. do not continue to reset it call a tech on this .. you are adding to the contamination of your system and makeing really hard to clean up internally. In the future if you reset the breaker and it trips right away just stop right there and call a tech.
Jul 13, 2011 | Carrier 38BRC060 Air Conditioner
Condensation pan has several holes, where can I go and buy one since Idon't think it can be fixed.
Hello, any heating and cooling store wil have condensate pans in stock, just make sure you have the proper measurements of the pan.
May 19, 2011 | Carrier 38BRC060 Air Conditioner
How much is this now....is this type ideal for a church that holds 200 people???
Hello my name is Heath it will be my pleasure to assit you. The unit is a 5 ton unit it may struggle to keep up on very hot or very warm days with the amount of pwople you have depending on the climate you are in.
Oct 06, 2010 | Carrier 38BRC060 Air Conditioner
The fan on my carrier a/c model 38brc060360 does not move when the compressor kicks on. it will start of i give it a small push
That is probably just a bad capacitor...that is what gives it the kick to get it going...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 17, 2010 | Carrier 38BRC060 Air Conditioner
My air conditioner has 2 zones. It does not open the proper vents when turned on. What can I do ??
Make sure the zone dampers are connected to the correct zone in the controller. Let me know what you find.
Jul 07, 2010 | Carrier 38BRC060 Air Conditioner
Compressor not doing much
I am assuming that you are talking about a central ac unit. On a central air unit the outside fan must be running whenever the compressor is. If it's not the compressor will shut off from overheating withing minutes. First you need to shut off the unit for several hours and let it cool completely down. Then turn it on briefly to see if the compressor starts and see if the fan tries to start.( I am assuming the compressor starts and runs.) If the fan won't start try testing the capacitors. There are usually two one for the fan one for the compressor. Sometimes there will be one combo one. Mark the wires and remove the capacitor. Get it tested and if bad replace it. This will probably do the job. If not test for current at the fan motor. Also test to see if it turns freely. The motor may need to be replaced. This will run about $50. The capacitor should always be replaced when the motor is changed anyway.
Jul 09, 2008 | Carrier 38BRC060 Air Conditioner
Carrier 38BRC060 Air Conditioner Logo
308 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
