Question about eMachines Computers & Internet
No problem, I just want to open the front & clean the dust inside
  • eMachines Master
  • 27,725 Answers
You might use a high pressure fine air blower from a compressor focussing on the laptop keyboard first the turn over and remove some of plastic covers this should blow all of the dust out but make VERY sure ther is no MOISTURE in the airline
hope this helps
Posted on Mar 27, 2011
How to open Cozy gas heater
See if you can blow out the dust with compressed air. Make sure you get ALL the dust out...that dust could ignite & start a fire!!!! If you can't, don't use the heater. Be sure to re-assemble per original design; or if you can't, don't use the heater!
SAFETY FIRST!!!!!!!
Nov 14, 2013 | Cozy Enclosed Front Console Heater 70,000...
Real hard to see & not focused 5 feet in front of whatever trying to look at.
Try this, take both lens out. All you have to do is just unscrew the lens. Use a very good optic lens clean with anti-static charging elements in the clearner. Only remove lens in a room semi free of dust, mites--little monster that live in the carpet, flaky skin, pet hair, etc. If it is dust inside of the NV devise, use a computer air spray to clean the inside. Assembly in reverse order. stewbison
Aug 06, 2011 | Night Owl Optics Explorer NOCX3 Monocular
My unit seems to work fine, except there is a dark shadow covering the right third of the projected image. Is this a sign that the bulb is going out?
this is the light tunnel needing to be adjusted or replaced because is has collasped due to the heat given off by the lamp during the life of the projector.
Aug 27, 2010 | InFocus ScreenPlay 4805 Multimedia...
I vacuumed all the dust from my c525a including
Clean inside printer using cleaning rod. Open front cover, pull out lever on right side to open access window on right side (outside) of printer. Pull out and push in cleaning rod several times.
Apr 07, 2010 | Xerox DocuPrint C525A Laser Printer
The printer won't print, it's trying to pick up the paper inside
Pull out the paper tray, at the front of the tray, there's a translucent roller in the middle. Remove the roller and clean out any waste paper dust inside & wipe clean the roller before putting it back.
Dec 10, 2009 | Brother HL-2040 Laser Printer
How can I remove the back cover on a SAMSUNG HCR5245W, I need access to clean the mirror and projectors. Already removed all screws. The back cover appears to be made of two parts but I cannot split. From...
Hi my name is Roety,
I can help you with your issue ,
Leave the top rear half bolted on.
Remove the rear edge screws to remove the front half, then remove the front lower section by taking out the few rear screws holding it, then there is another piece just below the screen that pulls off revealing the last few screws holding the top front screen section in the front lower edge.  Take the front off, cleaning the mirror and lens will help, but I'll bet the fluid is dirty inside the blue and green tubes, look into the tubes with the TV on to check.
best of luck
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Oct 19, 2009 | Samsung HC-R5245W 52" HDTV
Lasko heater shut down
The 5840 has a problem with dust getting on the heater element and turning itself off after 2 minutes running. HERE IS THE FIX. Unplug the unit from the AC outlet, Then using a can of dusting air ( the kind you use to clean a computer key board) aim the compressed air INTO the middle louver of the upper adjustable heater vent and blow out the dust that has gotten on the heater element. ( You are actually blowing into the unit, clearing off the lint/dust that has gotten on the backside of the heater element that you can not see without openning the entire case).You can see the front of the heater element inside the louvers, It's the shinny metal part that looks like a small radiator.It sits behind the middle louver. After blowing out the dust, shake the entire unit to allow the dust to settle to the bottom of the case. Using a vacum cleaner try to vacum out any dust from the LOWER FRONT intake. Once the dust has been blown OFF the heater element, the unit will work just as new and not shut itself down!
Feb 15, 2009 | Lasko Ceramic Heater
DVD's not playing
My HT-X40 plays cds and mp3's but doesnt play DVD's, this is happening after like 4 months of my purchase. Sasmung DVD's ****.
Mar 03, 2008 | Samsung HT-X40 System
Front door won't open
open the player wit the door ejected then clean all dust particles inside it especially below the door and on the way where the door closes ... and then also clean the rubber belt & near by which is connected to dc motor... and clean the lens also... remember clean only wit dry clothes...
if the door doesnt open means just hit on upside surface lightly after pressing eject button only...
Feb 03, 2008 | Technics SL-MC700 110-Disc CD Changer
Large dust circle on a Toshiba 50H95 RPTV
No the front panel will only give you access to the CRT circuits. Remove the back panel. UNPLUG your set. You should be able to reach inside (its a stretch for sure) to clean the screen, clean the tubes and if you reach up behind you can actually clean the mirror. This will greatly improve your picture. Do not use windex just a damp soft cloth then dry with a soft cloth. The mirror cleaning is most important to get a nice bright picture. Over the years the mirror tends to get dull. Hope this helps.
Jan 20, 2008 | Televison & Video
Computers & Internet Logo
Top eMachines Computers & Internet Experts
Computer Links
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
