Question about Vtech ia5877 Cordless Phone
Vtech 5874 phone new batteries will not hold charge. ALL connections checked & good; charge light on, but no charge in batt. Exact same problem in 2nd handset on separate charging station. Any ideas?
SOURCE: Not Registered
I had the same problem and this procedure fixes it! First, unplug the power to the main base (answering machine) for 20 seconds. Plus it back in. Put the phone that says "not registered" in the main answering machine. It will say "press the find handset for 4 seconds". Do that. It will run thru a series of stuff and will find the handset. It works! Rich (jambones.com)
Posted on Jun 01, 2007
SOURCE: Vtech 8L55 2 unit portable phone
I just had the same problem. Could be dirty terminals. I took the battery out, cleaned the terminals on the battery and phone with a pencil eraser, put the battery back in and it's working fine. (Says fully charged, where just a few minutes ago it said low battery).
Posted on Nov 09, 2007
  • 3 Answers
SOURCE: Vtech phones loosing connection to base
You are pretty close to the solution. The problem is the charge detection in the handset. All handsets on a cordless phone detect the battery level with an hexadecimal value in the memory. Each hex value equal a volt value of the battery. EX: 3.5v = 9B
3.6v = 9C 3.7v =9D etc... The problem is the hex value in your defective handset are all mess up. So 9B is not 3.5v anymore. Then your handset could last 1hr after foul charge or doesn't alert you before the phone goes dead due to low BAtt.
Posted on Nov 21, 2007
  • 103 Answers
SOURCE: charge/in use light
Typically the charge light will stay on as long as the phone is on the charger. After 16hrs, the battery should be fully charged. Leaving it on the charger constantly can actually overcharge the battery, shorening it's life. The best thing to do is use it until it tells you the battery is getting low, then charge it uninterrupted for about 8-12 hrs. Of course, that's ideal and can't always be done, but the more you can do that, the better.
Hope that helps, and please rate my answer, good OR bad.
Posted on Feb 04, 2008
SOURCE: BT Studio 3500, Base station,
eventually contacted the BT team via telephone and apparently this is a common problem when using BT products with Talktalk & Virgin. To overcome this in the majority of cases, dial 1571 and connect to your voicemail, listen to the options and finally delete all messages. Hope this can be added to your list of solutions.
Posted on Sep 19, 2008
97 checvy astro 4.3 6cyl. I replaced battery, Starter and the batt wont hold a charge. Is it possible to check the wiring from the alt to the starter without having to remove the alternator?
Yes, If you have a volt meter, jump and start engine, with engine running you should have approx 13.5 to 14.2volts that would tell me that batt is getting charged when engine is running. you said new batt would not hold a charge, I would be thinking about a parasitic draw(small amount of power) that in time will drain batt. things to look for are glove box lights, under hood lights that dont turn off. one easy way too see if you have a draw is to disconnect one batt cable, now use a regular (12volt non-self powered) test light and touch one end to batt cable and the other to empty batt terminal, with no light switches on and doors closed, this test light should not light and if it does then you have a drain on batt that will kill it say overnight.
Feb 12, 2011 | Chevrolet Astro Cars & Trucks
Battery will not hold a charge. told by dealer that load test indicate battery is fine. I knew that already. some gibberish about the watts/amps being put out by the system indicated parts were bad. Two...
hav batt charged if it holds 12.6v while letting it sit an hour then its good--if it does then connections are loose or alternator/rectifier is failin--please chec that fuse tho
Oct 07, 2010 | 2005 Suzuki Boulevard C90
Alternator is not charging the battery. The battery has been tested & will hold a charge. The alternator has been tested and is also good putting out 75 amps. I've checked the connections, all appear...
thats not always a great way to diagnose alternator problems if you have alot of electrical components on your vehicle the alt will not run the vehicle,also the alt. is not going to charge your batt. its job is to maintain your batteries life, if you do not have a load tester to test your batt. have some one at a autoparts help you most are free of charge to check.. goodluck
Mar 10, 2010 | 1989 Ford F 150
Good batt & new alternator.. but battery keeps losing charge
Make sure all connections at alternator are attached. On some, the regulator is inside the computer and if bad, requires computer change.
Jun 26, 2009 | 1994 Jeep Grand Cherokee
Battery is not charging nokia
check batt model r it arthorised batt and check charger and batt model no
Jan 23, 2009 | Nokia 6630 Cellular Phone
VTECH VT9121
voice message light keeps blinking
Aug 25, 2008 | Vtech 9009111 Cordless Phone
I have an electrical, problem the battery is being drained overnight and i can't seem to find out what is causing the problem ,any ideas?
start with battery. sometimes older batt. won't hold a charge overnite. disconnect battery and reconnect next day and check. if batt is ok disconnect alternator overnite and connect next day to see if it was problem.
Aug 12, 2008 | 1997 Dodge Stratus
Mar 20, 2007 | Vtech i5808 Cordless Expansion Handset
Vtech ia5877 Cordless Phone Logo
20 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
