Question about Dryers
Can you tell me where the heat element is on my dryer
    Problem Solver:
  • 8 Answers
On a typical machine you unplug it, remove the vent and then remove a series of screws going around the perimeter of the back panel. Usually you do not have to remove the back of the top part where the controls are. You will then see a metal shroud set at an angle that is about 6" wide and about 2' long which contains the heating element. Disconnect the wires, unscrew the housing, then there are usually some screw holding the element in,
Before you replace the element, use an ohmmeter to test for continuity. If you have a closed circuit, it's probably not the element that is bad. There are 2 or 3 thermal fuses that, if blown, will not allow the elemet to heat. 2 are usually attached to the element housing and there may be one on the vent exhaust housing between the fan and where the air comes out. To test these, remove the leads and test them with the ohmmeter as you did the element. An open circuit on any of these means they are blown and must be replaced.
Posted on Mar 27, 2011
  • 4,349 Answers
We REALLY, REALLY need the brand and model......(!) Heating elements are typically located in a chamber. in the rear of the machine. UNPLUG the machine before you do anything......There is surprisingly little failure of the element, MUCH more common are tripped circuit breakers, restricted air flow (causing thermal limiters to open), and restricted air flow.
Can't find model11066922500
Hello;
My name is Peter. I am a retired field service appliance technician.
Your heating element is difficult to get at.
25438420-j5jtgwve0qxm0uckbdimcx40-4-0.jpg Unplug the dryer before installing this heating element. Remove the bottom front service panel to access and replace the heating element.
This heating element is rated at 5500 watts.
This Dryer Heating Element part #3387747
Cost: $59.00
It is located in side the housing.
You may just be plugged up with lint in your hot air distribution manifold.
Or have a bad high temperature limit switch located on the back on your hot air exhaust manifold.
25438420-j5jtgwve0qxm0uckbdimcx40-4-5.jpg Tell me what your problem is.
Feb 16, 2015 | Kenmore Dryers
My dryer whirlpool still blow cool air but do not heat please tell me what the problem henry le
Bad heating element or bad thermo fuse.
You will have to unplug the dryer and remove the back to access the heating element. The thermo fuse is located on the side of the heating element.
If you don't have a meter to test the element and thermo fuse or just don't know how simply remove them from the dryer and take them to your local appliance repair shop and they can test them for you.
Aug 03, 2011 | Whirlpool LER4600 Electric Dryer
No heat
heating element is bad theirs a place on the back of dryer thats removable and the heating element slides out take it to a place that sales used dryers washers and ect show them your element and tell them what kind of dryer it came out of. For about 20.00 to 30.00 dollors they will give you one. All you need is a screw driver if I remember. A Phillips. My replacement has lasted almost 4 years now.
Sep 06, 2010 | Dryers
Whirlpool Cabrio - How do I tell if my heating
If you are comfortable useing a volt meter and a ohm meter I can walk you throught the steps otherwise you need to call a repairman, If you are not getting any heat and the tumbler is turning it is possible the element is bad again only a test meter can tell for sure or you can take the dryer apart and look at the element to see if it is broken make sure the power is turned off at the breaker first also unplug the dryer.
Apr 16, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
I have no heat in my dryer. How can I tell if it
check for continuity on the heating elements leads.
No heat
Well first of all you can tell us the model number of your dryer, so we can help you...... anyway if your dryer is a electrical dryer then first you check Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. Please post comments for further help or information..........
Good Luck!!
Mar 28, 2010 | Hotpoint Dryers
The old element has 3 wires the new element only
You need to take the high limit thermostat off of the old element. It sits over one of the terminals of the heating element, and has two termnals on it. It should just be one screw to take it off.
Dec 05, 2009 | Roper REX4634KQ Electric Dryer
Dryer heating element
To the heating element goes Red and Red with White.
To the Hi-limit thermostat goes Red with White and Black.
To the Thermal cut-off goes Black and Red.
Dec 11, 2008 | Whirlpool GEW9250 Electric Dryer
Need to replace the heating element in stackable Kenmore model 417.98702891
hi thanks for the question just underneath the dryer on the front theres a panel remove this panel the element is on the right thanks for the question the appliance doc
Mar 12, 2008 | Kenmore 98702 Stacked Washer/Dryer
Hotpoint Aquarius Condensor Dryer not getting Hot
I don't know Hotpoint models but I do know Malber models very well which also have a condensing dryer. The dryer has a fan and a heating coil or heating element, similar to a hair dryer. If you are getting no air flow, then it could be the fan. If you are getting air flow but it is not hot, then it is probably the heating element which burnt out. In the Malber machine, the top cover comes off and you can see an aluminum duct on top with two terminals sticking out the side. These two terminals go to the heating element inside the duct, and the heater element is like the heating element in an oven. You have to remove the duct and then it splits into a top and bottom half, and then you can remove the heating element to replace it. The way to tell if it is bad is to run the machine in a dry cycle and see if there is 110 volts across the heating element terminals. If there is power, but no heat, then the heating element is bad. That element is usually the first thing to fail.
Feb 11, 2008 | Hotpoint NVL333EY Electric Dryer
Dryers Logo
Top Dryers Experts
