Question about Pioneer CDJ-800 Turntable
LCD Display!!!!!!!! My power comes on but the LCD display screen doesnt show numbers or anything. Can it be fixed and can you recommended a place to get it fixed
  • 515 Answers
More than likely the ribbon cable is bad - unless there is damage to the LCD PC Board. Any knowledgeable repair shop should be able to replace this very easily.
- Davis
DJ Pro Audio
www.DJPROLAB.com
www.DJPROAUDIO.com
Posted on Aug 08, 2008
My laserjet 4250 donot display on screen while power led is on
Power off the machine, remove right door, open formatter door ,remove RAM mounted on formatter clean the contacts with Isopropyl alcohol fix it back & try if no, remove and reset the formatter..If no check LCD display...
Nov 16, 2011 | HP 4250 Monochrome LaserJet Printer
My laptop is working but the screen doesnt show anything
Possible that the fault is relative of a faulty LCD DISPLAY. Connect an external monitor and see if the PC works properly . if so the fault is confirmed to be of the LCD. check the voltage to the display, the back light voltage and the cluster cord to the LCD panel. sometimes there can be a break in the hinges, check continuity to confirm. if not the display driver /LCD panel can be suspected.
Sep 17, 2011 | Computers & Internet
The LCD screen can not display anything. i want to know the problem is because of the LCD or ribbon cable. please tell the solution to fix the problem
the ribbon is shorting against the metal plate. remove lcd and place insulation between cable and plate and reassemble. should fix the problem.
Dec 05, 2009 | Sony Ericsson W380i Cellular Phone
The lcd screen on MY moultrie d 40 doesnt show anything except a bunch of lines at teh bottom. can this be fixed?
Yes, the LCD display needs replacing, a known prob. Contact Moultrie by e-mail @ www.moultriefeeders.com and tell them the prob.They will ship a new display with instructions no cost to you.
Nov 15, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
My Sony Ericsson W580 just shows a white sceen an i cant go to anything else
More than likely you will need to replace the display screen but before you do take the screen out and reseat the LCD connector. This will sometimes fix a white screen.
If not, a new LCD screen runs about 15 dollars shipped from eBay and is pretty easy to replace.
Check out the following link for instructions on replacing the LCD display and links to buy the screen.
Sony Ericsson W580i LCD Display Replacement
I hope that helps you out
Mar 22, 2009 | Sony Ericsson w580i Cellular Phone
Blank LCD screen
problem is with lcd only may be its gone...
because in most cases they lights but doesnt show anything..
chirag
Apr 03, 2008 | Lexmark 4600 MFP
Canon powershot a540 black/web screen display
jvsnype and ygjeff21, have you checked to see if the pistures also come up as blank or distorted (a sure sign of a CCD failure)? If the pictures are OK, then it might be that you accidentally hit the DISP button, or the camera has a loose LCD ribbon cable connector. The reason I would suspect either is that ygjeff mentioned that the LCD would spring to life when he played with the buttons on the back of the camera.
If and only if the camera still takes good pics, and the DISP button has been checked, then would next recommend reseating the LCD ribbon cable into its connector (ALSO ONLY IF THE CAMERA IS NO LONGER UNDER WARRANTY). The following link may be of some help. Wouldn't recommend going any farther than the first three pictures. You just want to jiggle or reseat the ribbon cable where the LCD connects to the circuit board, nothing else:
http://photography-on-the.net/forum/showthread.php?t=251630
Feb 06, 2008 | Canon PowerShot A450 Digital Camera
Need help my samsung s630
my lcd isnt broken ive taken hundrerds of pics but all of the sudden it doesnt display anything just black screen like its off!! WTF!! i didnt do anything it was fine then 5 minutes later it wasnt
Nov 14, 2007 | Samsung Digimax S630 Digital Camera
Screen dosent display
if your laptop still turns on but doesnt display. change out the fl inverter. if that doesnt fix it then its your lcd screen. but i suggest first changing the inverter.
Nov 01, 2007 | Toshiba Satellite P25-S607 Notebook
Pioneer CDJ-800 Turntable Logo
317 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
