Question about Sanyo PDGDXL100 2700 ANSI Lumens DLP Video Projector Projector
Bulb popped - Sanyo PDGDXL100 2700 ANSI Lumens DLP Video Projector Projector
  • 442 Answers
Does the projector now come up with the leds indicating the lamp is no good. Or does it now not work at all
Posted on Mar 28, 2011
How do I replace the rear license plate bulb on a 2011 Nissan quest ?
usually on most vehicles the fixture that holds the bulb pops out and you can access the bulb. If yours doesn't pop out then you will need to remove the panel on the liftgate door to get to the bulb.
May 18, 2014 | 2005 Nissan Quest
Primer bulb won't reinflate on Craftsman weed eater after replacing fuel lines
Sounds like bulb not seated well...check to make sure it has all seals in place. Some pop in, some seal with a rubber seal.
Apr 10, 2014 | Garden
Toshiba 56hm66 bulbs popping
may have got a bad new one or ballast board in set is bad. It powers the lamp.
Nov 29, 2012 | Toshiba 56HM66 56" Projection HDTV
How do i replae ny 2004 malibu maxx interior dome bulb?
To replace the bulb the cover pops off, you will need a small screwdriver or something like that to remove the cover then the bulb just pulls out and then the cover pops back on.
Mar 13, 2011 | 2004 Chevrolet Malibu Maxx
How do i change the light bulb above the license plate
it will pop out if you use a very small screwdriver once popped,pull old bulb out and replace,these bulbs usually have no screwin and only need pulled out and push in.adrian,,,,
Dec 16, 2010 | 2001 Hyundai Accent
Brake light fuse popping
have you got a normal bulb (2 pins) in the place of a brakelight bulb (3 pins) that would pop the fuse... Also replace both brake bulbs as one may be shorted internally.
Jan 24, 2010 | 2006 Chrysler PT Cruiser
How to change headlight bulb for a 2003 VW Jetta GLI
If you pop the hood, there should be a blub door right behind the headlight. Open the door, turn the bulb and it should pop out, ready for the new bulb
Oct 14, 2009 | 2003 Volkswagen Jetta TDI
How do i change my rear indicator bulb in my 04 beetle?
open rear hatch and look strait down on inside boot well. the plastic trim has access holes that pop out on either side just behind the lights. pop out the access cover on the side with burnt bulb, then reach inside that hole and you will fins a large plastic "wingnut", unscrew it<careful not to drop it or you'll have to take the whole boot apart to retrieve it> after removing wingnut carefully pop out lens from outside , replace bulb and reinstall after testing
Mar 19, 2009 | 2000 Volkswagen Beetle
I cant get the old headlight bulbs outta of my 2001 ford focus any answers on how to get them out easily
All of the Focus model lights are identical. I recently installed Sylvania Cool Blue's on my '01 ZX3. Pop the hood. At the front of the car, look to the back of the headlight assembly. There will be a plastic cover on the back. On some models, you need to unscrew the plastic cap; on others, it just pops or screws off. There is a small retaining clip that surrounds and holds the bulb in place. Removing the clip can be tricky. On my Focus Wagon, there is a special place to push and release the clip that is above the bulb - perhaps further above than you might think. Gently push this aside with your hand and the bulb assembly will come right out. Just remove the original bulb and pop the new one in. These bulbs have a standard three-prong setup so there's only one way to install the new bulb. Pop the assembly back in place, attach the retaining clip and put the plastic cover back on. On the driver's side, you may want to remove the battery cover to give yourself a little extra room to work. No tools. 10 minutes.
Feb 18, 2009 | 2001 Ford Focus
Sanyo PDGDXL100 2700 ANSI Lumens DLP Video Projector Projector Logo
46 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
