We have a Maytag Epic Z washing machine. We had been getting F21 errors but a previous gentleman solved that for us. Now we are getting a F1 error. It goes straight to the error so we can't get the load of clothes out that we need. Help, Please.
  • bghenriksen Mar 27, 2011
    Sir
    I must not have been clear. We had already cleared the F21 error. I listed that to give you the recent history. Now we are getting a F1 error.
    OK. I will probably contact a repairman for that as I have no way of determining if the control board is bad or not. Is there some way to get the door unlocked so we can get the clothes out that are locked in that we need?
  • Washing Mach... Master
  • 1,902 Answers
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Posted on Mar 27, 2011
  • Kevin White
    Kevin White Mar 27, 2011
    Sorry, did not read F1 in your previous question, Error Code F1
    means that the control is either bad or the wiring harness to the control has
    some issues. Please check the control board for any bad components as you might
    need complete replacement of the control. Please get back to me if you have any
    other questions.
    Kevin
    Kevin
  • Kevin White
    Yes you can take out the bottom access panel after removing the screws that are there and then locate the door latch and pull the lever down to open the door lock assembly.
Maytag epic Z Washer shuts down at spin cycle
F21 usually indicates a pump problem however when that is not the problem then the place to look is the board itself as there is a mis communication between it and pump cycle? If the pump cannot operate it will not allow it to go into the spin.
Jan 13, 2015 | Maytag Epic Z and Performance Series 2000...
F21 code how do you fix this
http://frontloadwasherguide.blogspot.com/2011/06/maytag-epic-and-epic-z-series-f21-error.html
Jan 12, 2012 | Maytag Washing Machines
My Maytag washer has a flashing F 15. What does that mean?
The following list of codes indicates an electronics communication problem with the washer: * Epic® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
* Epic ZTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Hope this helps.
Jun 24, 2011 | Maytag EPIC MFW9700S Front Load Washer
Maytag epic z washer error code F21-have unplugged for 15 mins. and removed front panel and drained and found some coins and removed BUT it worked for a few mins. then the error code reappeared. what is...
F21 indicates a Long Drain error code. This indicates that you have an obstruction somewhere in the drainage system. In most cases, this means you probably have a clog in the drain pump.
You may have something getting caught in the pump impeller and slowing it down. Or, you may have something clogging the drain lines. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
If this solution doesn't solve your problem, you may have to replace the drain pump.The error code will continue to appear until the pump is replaced.
Thank you !!
Aug 01, 2010 | Maytag Washing Machines
Maytag Epic Z with error codes F20 and F24
my epic will start & wash & then gets F 20 & won't drain until I hit start again
Oct 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
I am getting error code F21
long drain time for the washer, it being an epic it should be under warranty call whirlpool at their toll free number depending where you live for free service
May 06, 2008 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
