Question about Pioneer CDJ-800 Turntable
My LCD Display
Saturday my club had a power outage and my cdj 800 went out, it came back on but the display was not on... No number no bpm track listing etc.
How can i get this repaired and can i do it myself. If not can you recommended me to anybody in Atlanta Georgia, who may can fix this problem before saturday
  • 515 Answers
Well, one of 2 things may have gone bad...
1) Ribbon Cable
2) LCD PC Board
The first is easily fixed. The second, is not. As for service centers, I suggest you contact Pioneer - www.pioneerelectronics.com
- Davis
DJ Pro Audio
www.DJPROLAB.com
www.DJPROAUDIO.com
Posted on Aug 08, 2008
6ya staff
SOURCE:
There is a disk stuck in my pioneer cdj-800 on the track display it say 00 e-9101 and i cant eject from deck
hii there,
Please look bottom (turn ur CDJ 180 degree) there will be a pin
to eject the disc from ur CDJ. Also make sure when u do it ur CDJ must be turn off.
thx
djajay
Aug 06, 2010 | Pioneer CDJ-800 Turntable
Pioneer cdj 800 mk2 playing mp3s, jogwheel & screen dont work
More than likely the contact pad (aka Membrane pad) is probably damaged... or the flat cable which connects to the main processor, might be loose, or damaged.
You'll need to get this professionally checked out by a qualified technician. It's not an easy fix.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
Aug 28, 2009 | Pioneer CDJ-800MK2 Turntable
Pioneer cdj 800 display often goes out, but comes back on after I give it a good whack (yeah I know, but it worked in Back to the Future and for my cdj's). What's the problem here/where can I parts
I am an aircraft mechanic not an electrician, but I narrowed it down to the power supply. Somewhere on the power supply there is a connection that is making a bad connection. I will keep looking and post if found! :)
Jun 28, 2009 | Pioneer CDJ-800 Turntable
Displays gone on CDJ800
It sounds like a power supply to the both display pcb's is missing, unfortuanetly i wouldnt recommend attempting to fix this yourself, if you havent had it repaired then you can send it to us.
Regards.
http://www.audiovisualservices.info/
Dec 11, 2008 | Pioneer CDJ-800 Turntable
Stanton c.304 cdj reading disk but cant go bno futher
Check the sled motor is operating correctly.
Aug 05, 2017 | Stanton C.304
Hello I own 2 cdj 800 mk3 which I use professionally every week for the past 2 years. Recently I am experiencing problems with the pitch control waivering up and down about 2 bpm. I have found this with...
It's possible that you can remedy the problem by cleaning the controls. Being as how they are analog controls and facing directly upward they get dust and dirt in them quite easily. Use a cleaner that is designed for slide controls, one with a silicone lubricant, not one that's straight alcohol as the control will get stiff and not move smoothly.
If cleaning does not do the trick then yes, you'll have to replace it.
Oct 14, 2008 | Pioneer Audio Players & Recorders
Round lcd?
Unfortinetly i cant recommend to you a quick fix or a quick check as the fault seems to be intermittent,
i would suggest taking the player to your cdj pioneer dealer.
email: [email protected] for all your dj equipment repairs.
Thanks.
Aug 16, 2008 | Pioneer CDJ-800 Turntable
LCD Display!!!!!!!!
More than likely the ribbon cable is bad - unless there is damage to the LCD PC Board. Any knowledgeable repair shop should be able to replace this very easily.
- Davis
DJ Pro Audio
www.DJPROLAB.com
www.DJPROAUDIO.com
Aug 04, 2008 | Pioneer CDJ-800 Turntable
I can't see the digital readout
There may have a been a slight power surge which fried either a resistor or IC inside the unit. This is NOT a self repair, and you will have to get it serviced by a professional service center.
Good Luck.
- DJ PRO AUDIO
www.DJPROLAB.com
Feb 27, 2008 | Pioneer CDJ-800 Turntable
ILO 32inch TV
ILO 32" lcd hdmi tech support Eastern Time
8:30 am - 9:00 pm (monday through friday)
9:00 am - 5:00 pm (saturday)
1-800-428-1105
my 8 month old tv doesnt even turn blue. just blinking red light where on/off light display appears. very discouraged cause wallmart will not help. trying techsupport. i found this number from my purchase paperwork. hope it is helpfull to you.
Dec 10, 2007 | iLO 3200 32 in. LCD Television
Pioneer CDJ-800 Turntable Logo
347 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Ben Armstrong
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
