Question about Vacuums
Hi I need a new heater element as no longer heating up. I have tested it and there is no continuity when tested. The part has 230V 2x600WIRCA on it. Please advise me were i can purchase. Regards Gary
  • 1,150 Answers
The above Heating Element 230V 2x600WIRCA is also a part in...
My DeLonghi Magnifica EAM3500 Coffee Maker displays the message "Heating Up... Please Wait"..... after the quick "power on" diagnostic routine completes OK.
It has stopped getting HOT. and ends up with an error message after a period of time.
The Coffee Maker has a Heating Element numbered 2X600WIRCA as part of what DeLonghi call "The Generator Module".
Mine shows open circuit and has 188vac across the terminals.
It also has an 8" nichrome (resistor) wire across both terminals which are probably putting a small load on the circuit.
Both in line temperature cutouts are closed. Which would be normal.
The small temperature control thermistor appears to be functional.
If it's connector is pulled of the control circuit board, the unit gets a fault message on the LCD Screen & the power on diagnostic fails.
This Generator Module (with heating element fixed to it) has a part number of 7332182500
There is a diagram on
http://www.ereplacementparts.com/delonghi-eam3500-magnifica-parts-c-122345_122351_122712.html
also available on
http://www.appliancepartswarehouse.com.au/7332182500-generator-delonghi-p-96257.html
and
http://www.4delonghi.co.uk/search.pl?t=31382.3024002819&query=2290822OH
The element could be prised away from the generator if unavailable elsewhere and required for another type of repair.
Hope this helps someone else
Cheers
Trevor
Posted on Jul 15, 2014
Hi Gary i have the same problem with my esam 6620 did you find where you could get the part from?
Posted on Apr 16, 2012
How do I diagnose the heating element for a shark steam mop
please go to http://www.sharkclean.com/products/shark-pro-steam-pocket-mop-s3601/support/how-to-videos.shtml and see the video for better troubleshooting and fix it.
However , if the system has heating element you must use the VOM for test continuity, if they donot the heating is faulty.
God bless you
Jul 22, 2012 | Vacuums
Won't heat the water
Continuity check from the input to the output. If open, then check from the heater element to the out put and then the other side, then the switches and other safety switches. When you find an open component that shouldn't be you have found your problem. You need and ohmmeter or continutiy checker. If don't know what I am talking about get it looked at by someone who does. If you do, then I should have to tell you any of this.
Nov 11, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Delonghi toaster elements are losing their heat
There are three likely problems:
1. The toaster and/or heater elements need to be cleaned. If they get coated with food material they will not function correctly.
2. The heater element could just be going bad. You would need to search the web with your model number to find the appropriate replacement part then open up the unit sufficiently to disconnect the old elements and replace the new elements. You need to ensure that the connections are correct because loose connections would not permit sufficient electricity to enable the elements to heat up.
3. The thermostat could be going or gone. This controls the amount of power provided to the elements and thus determines how much they heat up. Again, you would need to search for replacement part.
Aug 11, 2011 | Vacuums
Why is it important that the resistance of an extension cord be small when it is used to power an electric heater?
Hi pipay thinti...
You must have little resistance (large wire) in the electrical cord because you want the elements of the heater to heat up and not the cord...if you had high resistance in the cord it would get too hot and melt the plastic coatings.
Please take time to rate me
Jul 26, 2011 | Vacuums
Forgot what kind of water to use - distilled or other wise can not find manual, can I get one - Model GS7RW Thanks, Susan
hi.
i am assuming it is the GS7RW garment steamer and not actually a vacuum cleaner.
any electrical item with a heating element should be used with distilled or de-ionised water.
if you live in a "hard water" area where the water contains dissolved calcuim salts, these will cause scaling and furring up of the heater element. easiest way to tell is to look inside your kettle. if there are white deposits on the base or heating element, your steamer will get the same deposits and work less effectively.
another option is to use the scented ironing waters available from many supermarkets for use in steam irons. these will not harm your steamer, and will also make your clothes smell nice as they come in a range of scents.
this link does have some instructions that may help.
http://www.conair.com/instruction_booklets/06PC2349%20gs7rw%20IB.pdf
Jun 14, 2011 | Vacuums
Russell Hobbs RHI 405 iron - Iron switches on but does not heat up
Please check the mains cord and see if there is continuity of the main wire, from the plug to the iron. Now check the continuity of the heating element and also the functioning of the thermostat.
These test must show a continuity or the main-heating element is open.
Mar 28, 2011 | Vacuums
The indicator is flahing as to say it is heating up the water but continues to do so and never heats up
What kind of Vacuum has a water heater in it?
That is a new one-- unless we are talking about a steam cleaning machine?
Tell us more about the machine, and if you can see where the Heater is?-- and the power to it, etc., etc.
Dec 27, 2010 | Vacuums
Heater does not generate steam / water temperature not hot enough shark S3202 has only been user 10 to 15 times. can a new heating element be installed? where can I buy element?
The element is not sold anywhere... go figure...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Dec 15, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop model #S3202 is no longer heating and producing steam
The heating element may have died or there is an obstruction...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
Jul 22, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Heater/fan issues
There is a safety switch which will shut the heater element off if the fan doesn't run. If the fan doesn't circulate air, the element would overheat and could possibly start a fire, so the switch will shut the element down. I'm not familiar with this heater, but I would check to make sure the fan is operating and also check for any filters that may be plugged and restricting air flow. If anything interferes with the air passing through the heater, the overheat switch will shut down the element. That's the best I can do from here. Good luck.
Feb 28, 2008 | Vacuums
Vacuums Logo
218 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
