Question about Empire Heating & Cooling
Empire FAW-60-2-spp fan short cycles about 4 seconds on/off
    Brigadier General:
  • 4,736 Answers
From what you have described, it sounds as if the Fan Control Switch, ECS Part # R-1941, which works in conjunction with the Limit Control Switch (ECS Part # 912073) is failing and needs to be replaced. You can order these parts directly from Empire Comfort Systems. If you decide to replace these parts yourself, it will give you an opportunity to thoroughly clean the interior of the Wall Furnace, if you haven't already. If you need further information, contact Empire Comfort Systems, Technical Service @ 800-851-3153 Monday - Friday.
Hope this helped you to troubleshoot the problem. Please don't forget to rate my response. Thanks!
Posted on Mar 27, 2011
Faw 55 no fan operation
All fan switches should read open line or "OL" when the furnace is cool, but if the motor seems stiff see if it is oilable. It may have small holes covered by yellow or black plastic plugs covering the holes. If it does and you have not oiled it, go to the hardware store and ask for a motor oiler such as a Zoom spout. Place 3-5 drops of oil in each hole then spin the motor by hand, it may loosen up. The limit side of the fan/limit switch has no impact on the fan motor.
Feb 01, 2015 | Empire Comfort Systems EMP FAW-55-SPP-1N -...
The pilor light is on and stays on. but furnace won't kick on. we raised temp on thermostat and can hear a click from furnace but it wont kick on at all. The burner lights but won't stay lit. we have an...
Check the venting to the outside, to make sure it's not obstructed in any way. There may be an issue with the overheating circuit, too. In case you have misplaced your Owners Manual, I have included a link to it, that you can download and print for future reference. Pay particular attention to page 15. If all else fails, call Empire Comfort Systems 800-851-3153 and ask for Rich or John in Technical Service Dept.
http://www.empirecomfort.com/EMPIRECOMFORT/pdf2010/manuals/12431-12-1109-DV55PP.pdf
Hope this helps to heat up things for you. Please let me know.
Mar 17, 2011 | Heating & Cooling
Tv desn't turn on,power light just flashes ten times and then stops and then again
Error Indication Information
Error No. Error Information ERROR DESCRIPTION LAMP LED OSD LAMP OFF
(Note 3) (Note 4)
POWER LED TEMP LED
Note:
1.When any of the above errors has occurred, the LED will flash as shown above every 5 seconds.
2.When two or more errors have occurred at the same time, the LED will light up or flash as shown above, and then
change to another every 5 seconds in turn.
3.Warning OSD appears when the Air Filter is clogged 90%, accumulated operation time of the Lamp reaches 5000 hours,
or accumulated operation time of the Air Filter reaches 400 hours.
4.LAMP OFF: The LED will flash right after the Lamp goes off.
5.IC2301 is mounted on LCD Main C.B.A. which is included in the Projection Unit.
6.IC6001 is mounted on TV Main C.B.A.
Clogged air filter
more than 90%
15)
16)
17)
18)
1)
2)
3)
4)
5)
6)
7)
11)
8)
9)
10)
12)
13)
14)
- flashes 5 times -
every 5 seconds
IC2301(pin82) detects the clogged air filter, then indicates the
error when the air filter is clogged 90%.
Front Fan stop or
Lamp Fan stop
flashes orange
once every
5 seconds
IC2301(pin12) detects the Front FAN stop or Lamp
FAN stop, then indicates the error when the Front FAN
or Lamp FAN is stopped.
Lamp Cover open
Temperature Sensor
short or open
flashes orange
twice every
5 seconds
flashes orange
3 times every
5 seconds
flashes green for
140 seconds.
flashing red for
60 seconds.
light up red.
flashes once
every 5 seconds
flashes once
every 5 seconds
flashes red for
10 minutes
flashes once
every 5 seconds
Abnormal
Temperature
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Request for Lamp
Replacement - - lights up
Power Ballast Error
(abnormal
Lamp voltage)
flashes 3 times
every 5 seconds
Power Ballast Error
(abnormal
temperature)
flashes 4 times
every 5 seconds
Power Ballast Error
(other causes) - -
Request for Filter
Cleaning -
Abnormal Voltage
on 16 V line of
LCD Main C.B.A.
flashes twice
every 5 seconds
flashes twice
every 5 seconds
Abnormal Voltage
on 14 V line of
LCD Main C.B.A.
flashes 3 times
every 5 seconds
flashes 3 times
every 5 seconds
Abnormal Voltage
on 7 V line of
LCD Main C.B.A.
flashes 4 times
every 5 seconds
flashes 4 times
every 5 seconds
IC2301(pin76) detects the Lamp Cover Unit condition
(open or close), then indicates the error when the
Lamp Cover Unit is open.
IC6001(pin85) detects the Duct FAN stop, then
indicates the error when the Duct FAN is stopped.
IC2301(pin74 and 75) detects open or short of the Temperature
Sensor (R2911) on Front Thermistor C.B.A., then indicates the
error when Temperature Sensor is open or shorted.
(The error is not detected for 1 minute after Lamp ON.)
IC2301(pin74 and 75) detects the temperature attached near
the Front FAN by the Temperature Sensor (R2911) on Front
Thermistor C.B.A., then indicates the error when the
temperature becomes more than 43 C (109 F).
IC6001(pin86 and 87) detects open or short of the
Temperature Sensor (R2901) on Lamp Thermistor C.B.A.,
then indicates the error when Temperature Sensor is open or
shorted.
(The error is not detected for 4 minutes after Lamp ON.)
the Lamp by the Temperature Sensor (R2901) on Lamp
temperature becomes more than 60 C (140 F).
IC2301(pin11) detects the error of LCD Power C.B.A.,
then indicates the error when the temperature fuse
(117 C)(243 F) in LCD Power C.B.A. is open.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp
is cracked.
IC2301(pin11) detects the error of the Lamp, then indicates the
error when the Lamp is short-circuit.
IC2301(pin48) detects +16V line voltage on LCD Main
C.B.A., then indicates the error when the voltage
becomes less than +13V.
IC2301(pin47) detects +14V line voltage on LCD Main
becomes less than +11V.
IC2301(pin45) detects +7V line voltage on LCD Main
becomes less than +5.7V.
IC2301(pin44) detects +3.3V line voltage on LCD Main
becomes less than +2.5V.
flashes 3 times
every 5 seconds
flashes 4 times
every 5 seconds
Abnormal Voltage
on 3.3 V line of
LCD Main C.B.A.
- flashes 5 times
every 5 seconds
Forced cooling
The failure of Lamp
light up
Temperature Sensor
short or open
Abnormal
Temperature
Duct Fan stop -
When accumulated operation time of the the Lamp reaches
5000 hours, OSD (replacing the Lamp) appears on the screen.
Note: The Lamp time is stored in EEPROM (IC2305).
When accumulated operation time of the Air Filter reaches 400
hours, OSD (cleaning the Air Filter) appears on the screen.
Note: The Filter time is stored in EEPROM (IC2305).
During forced cooling, this indication is indicated.
IC2301 (pin11) detects the failure of light up processing of
the Lamp, then the POWER LED is changed as follows.
1) POWER LED flashes green for 140 seconds (while turning on).
2) POWER LED flashes red for 60 seconds (while cooling).
3) POWER LED lights up red (standby).
Note: If the Lamp will not light after attempting turning on the
power 2 or 3 times, the Lamp, the LCD Power C.B.A. or the
LCD Main C.B.A. may be defective.
Error Symptom Problem Possible Solutio
May 30, 2010 | Panasonic Viera TH-50PX80U Plasma TV
AC is off but compressor cycles periodically
most likely your compressor contact is stuck closed, and will need to be replaced. if the fan also runs when the compressor comes on you may have a short between the t-stat and unit. hope this helps.
Jun 14, 2009 | Dometic Rooftop RV Air Conditioner
Fan relay or sequencer.
If it were the sequencer, the heat wouldn't come on at all but the fan would blow. It's the fan relay but it could be the t-stat again. If you get a power surge when the unit is running, it can short out that portion only but typically, it will short out either the heat or the cool side depending on what is running not just the fan.
Feb 28, 2009 | Better Living SPP High Efficiency...
Short ring every 30 minutes after hooking up SPP-A2770 telephone?
You might have a Phone Company Message Servicve and this is your call to answer your message.
Short Ring.... = message
AL
Feb 09, 2009 | Sony SPP ID910 Cordless Phone (SPP-ID910)
Pilot lights and one panel burns
Empire faw 40 makes a loud bang when starting up. There are three burners. The pilot light is on one burner. When the furnace starts, gas is lit on that burner and the flame is passed on to the other burners by a small channel that can get stopped up. You just have to remove the burners and clean the channel with a small file, like on a finger nail clipper. This can be difficult due to the pilot assemble being attached with two bolts. The bolt on the right has to be removed with a short screw driver. You can not get a socket on it. After you remove it there is enough play to remove the bracket and gas burners.3_4_2012_5_06_50_am.jpg
Nov 23, 2008 | Empire DV-215 Direct Vent Natural Gas...
Heating & Cooling Logo
321 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
vance jones
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
