Question about Ovens
Currys built in oven CBCONW10 We installed a new electric oven today, and some heat is coming through the door at the top. Is this normal/safe?.
the dr
  • 447 Answers
SOURCE: KEB5247 Kitchenaid built in electric double oven
Yes the inner door glass is a replaceable part and the door will have to be disasembled but not replaced. I can help with sourcing any parts for you since you used a premium post.
Posted on Jan 02, 2008
SOURCE: Whirlpool self-cleaning electric built in oven
I have the same problem. Who has a solution?
Posted on Aug 24, 2008
tzweeb
  • 318 Answers
SOURCE: Jenn-Air electric wall oven door opens slightly when in bake mode
you either have a bent door hinge or a broken door spring.
check the hinges by opening the door and see if it opens past 90 degrees. if it leans towards the floor then the hinges are bent.
if not then your door springs are broken off. you can check this by seeing if the door "feels" heavy when opening.
either way the door should close tight against the frame when up and the light should not come on without opening the door.
Posted on Jan 22, 2009
SOURCE: Re Neff B1451 oven door not sealing against oven body at top
If you take the hinges off, you can fit some washers between the hinges and the door to make it close it further. Probably not as good as new hinges, but cheaper. 2mm of washers will close a 5mm gap
Posted on Jun 17, 2009
See this thread:
http://www.bobvila.com/BBS/Jenn_Air_Oven_door-Appliances-1-F3784.html
This worked for me (or at least helped the repair guy get the right parts for my model). Had to replace both the hinges and the hinge brackets. Seems to be a defect in these Jenn-air ovens going back to about 2006. After the parts replacement, the door lines up better, but still does not feel like it really closes solidly. At least glass on the door lines up better with the glass on the control panel.
Posted on Aug 09, 2009
Our electric convection oven heats up and when you open the door and close again it no longer heats, fan stays on and the light goes on when door open and off when door is closed, any ideas?? Thanks
Hi, You can look at the micro switch on the oven door, sounds like it might have been installed on a normally open auxiliary rather than a normally closed aux. hope this helps
Oct 09, 2014 | Ovens
Oven doesn't seem to heat up enough
There is a cooling fan In a STOVES 720 to keep the fabric of the oven cool. If this fails the overheat thermostats will cut in and shut the heating elements off. The cooling fan does in fact blow air out of various places in and around the doors. The top oven has a small element and takes a long time to warm up. If you are not confident that the thermostats are working correctly, then I suggest you purchase an oven thermometer from someone like Lakeland and see how that relate to what you are actually setting on the cooker dial. As I said the top oven leave a lot to be desired!
Oct 30, 2011 | Stoves 720EF Electric Double Oven
I have a GE Profile JT965 built-in wall oven with microwave. The microwave just quit heating. Last night it worked and today it does not. The turntable turns and the light comes on but no heat. The...
Twelve years is an appliance eternity. There may be an open internal fuse, a defective door interlock, magnetron failure, and/or control board failure.
Dec 20, 2017 | GE Profile JT965 Electric Double Oven
Hi, I only just installed Baumatic single built in fan oven (B0616SS). I did as instructed and left on for 39 - 40 minutes at max 250 temp. I noticed that the oven door was very hot to touch, too hot! This...
Hello- This is a brand new model, but it works the same as the rest. Heat is produced by the elements. The fan has an element that glows when heating the air. --Convection oven glass gets hotter than normal fanless models.-- This is all normal operation of the oven.  To ensure full life of oven, avoid using the 'self-clean' feature. Techs call this the 'self-destruct' cycle. Please reply to this post if info is helpful- have more if needed- Thanks- Ed
Mar 19, 2010 | Baumatic B604SS Stainless Steel Gas Single...
GE Double Oven doors locked and circuit not responding
Hi, well this is a brain tester!! I think you need really to look at this in a simple way. Check to see where the door lock wires come from first? Find where the mains power comes into? then if it goes directly to the main control board then check to see if there is any power getting through the board to the otherside where the wires disapear into the cooker. I would consider checking the control board for any signs of burn damage and then look at the clock unit to as these are normally the main components in the cooker that will stop it from working.
Good luck,,,,,,,,,,,,,,,
Jan 02, 2009 | GE Profile JTP56 Electric Double Oven
Stoves 900GDO Bottom oven door seal
You will probably have to replace the oven door hinges.
This should solve the problem
Dec 02, 2008 | Stoves 720EF Electric Double Oven
Kuppersbusch EEB9800.0 oven - thermostat sensor defective
you need part number 165047 cable harness and part number 161629 thermostat pt1000 call currys partmaster and get a quote on the parts
Aug 26, 2008 | Kuppersbusch EEB 6800.0 JX Electric Single...
Magic chef stove and oven installed 1978
Yes this is normal. you can use that burner to keep things warm without turning it on, saves energy.
Dec 14, 2007 | Magic Chef 9512 Electric Single Oven
Ovens Logo
87 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
