Question about Vacuums
Can not get heating elements to stay red hot. This is a Viking sauna serial # C-05/0496 Saunatec TYP 1714-60-17. Thanks for any help. Rich G
Suddenly stopped steaming, tank filled steam light stays on, no steam but heats up? Problem solving in manual just states the obvious? Can you suggest anything else or will I have to contact Hoover
Perhaps Element not heating to full temperature to generate steam.
Temperature sensor may be faulty if element is ok.
1 Element or 2 ????
Sorry... No magic fix button
Open it up and start testing things.
a multimeter comes in handy here.
or
back to Hoover repair centre
Good Luck
Feb 03, 2016 | Hoover Vacuums
I have the euro steam blaster s3325 when I turn it on, the steam ready **** comes on right away not heating can the heating element be replaced? thanks
There is a device attach to the heating element called a thermo fuse, this devise brakes down when it get to hot.
open the machine and replace it with the same value. it is written on it..
Nov 20, 2012 | Euro-Pro S3325 Handheld Steam Vacuum
I have a vintage GE coffee perculator made in the 1930's and 1940's Cat No. 119P102 which I bought from an antinque store in Chicago 2 months ago. It has worked beautifully until yesterday morning...
The first problem is the time you will use a product of the very old time , and ask you not wonder what it mains happened in the interval between 1930 and 2016 maybe its not only the changeof 110V to 120 volts it is not much difference but far enough to worry and what the effect is on the heat dissipation of the heating element inside (the coffee must be too hot 90 and 95 degrees are normal all the cables and more parts of Should Be Replaced if it was not modifiedin all Those years, it Should Be modified, and it was modified there must be for shure a big wire resistor be Placed in serial to release to the high aC power on the heating element. and maybe many more parts. gaskets cables and more must Be Replaced iif not safety for all. preventinfo and usefull to a hot Become bitter tasting coffee temperature.
Sep 25, 2011 | GE Vacuums
Hi - I have an Ocean Sales, Inc. steam mop, model #7603 that I have loved using. It has now stopped producing steam. I can't find my manual. Can this be fixed, or is it time for the trash can? ...
There is a heating element in there that gets hot and produces steam. Obviously it is not getting power or it has burned out. If it is the latter you need to find out how much the repair part, if available, costs. The expense and hassle might just not be worth it.
Jul 23, 2011 | Vacuums
Recently I purchased Sanyo Eneloop NC-MQN04ES Charger. I need the user manual for this charger. How many hours does it takes to charge 4 aa and aaa Batteries. I charged it for more than 6 hrs. But the led...
This is from the user 's manual i just copy paste it
Specification: Voltage : AC 220V - AC 240V,
Input : 50/60 Hz 6W,
Output : DC 2.4V 220-280mA x2 (AA),
100-140mA x2 (AAA),
LED indicator : ON - charging OFF - Timer off (approx 16hours) Battrey/Charge Time Approximate Hours :
-Eneloop Ni-MH AA (typ 2000mAh) 10(h),
-Eneloop Ni-MH AAA (typ 800mAh) 8(h),
-Ni-MH AA (typ 2700mAh) 13(h),
-Ni-MH AA (typ 2500mAh) 12(h),
-Ni-MH AA (typ 2100mAh) 10(h),
-Ni-MH AA (typ 1700mAh) 8(h),
-Ni-MH AAA (typ 1000mAh) 10(h),
-Ni-MH AAA (typ 900mAh) 9(h),
-Dimension : 118 x 75 x 40 mm
Jul 03, 2010 | Vacuums
DZ9080 IRON IS NOT VERY OLD, BUT HAS HEATING AND STEAMING PROBLEMS. IT MAY BE ALL HEATING RELATED! MY WIFE WILL SOMETIMES JUST LEAVE IT "ON" FOR TWO HOURS AND THEN IT WILL START STEAMING AGAIN. I CANNOT...
I couldn't find any warranty information on this iron, but I suspect that the heating element either has a faulty connection or part of it has cracked, making contact at time, but poor contact at other times. The unit will have to be taken apart and inspected and troubleshot, and that's why I was inquiring about the warranty. Someone in a review of them said that their website and 800 number weren't working, so you might try to refer to your manual that came with it for support. Another person who uses them regularly said they just last for about 3 years before needing to be replaced. If the warranty isn't valid for you, I would disassemble it and try to see if an electrical connection to the element is cracked, perhaps, or has heat damage, then try to secure it. If the element's cracked or damaged by heat, it will need to be replaced. There's a chance the control unit's faulty, and any fix could run into some money. If you do have it serviced, get an estimate first. Sometimes it's just better to bite the bullet and get a new one. Good luck, and hope this helps.
Jun 25, 2010 | Rowenta Vacuums
Bissell will not heat up
There is a heating element which is prone to fail. I don't know if I would bother to have this repaired if the Bissell is out of warranty because I don't think it adds a lot to the performance. I think it's most important for good cleaning to put very hot water into the machine, and then work slowly with lots of water and rinsing and vacuuming. Remember that carpet shampoo never makes dirt vanish-- it only loosens it so you can rinse and **** it up. If you don't **** it up, the floor stays dirty. So you have to go slowly and rinse a lot until the water is beige instead of black!.
The heater may help heat the water a little more, but it's no biggie IMO.
May 14, 2009 | Bissell ProHeat Deep Cleaner Upright...
Powerwash proheat
If the unit is spraying ok but your just not getting hot water you could have a defective heater even if the light is on. To test you would need to take the handle apart and see if the heater gets hot by touching it give it about 2 Min's to heat up but be careful it will burn you if it is working properly. Another thing to remember is that even if it is working properly the water won't be very hot especially if you put cold water in it to start out with. The best thing to do is fill it with the hottest water you can get from the tap don't boil it or anything but this will help. If you need any parts or cleaning solution for this machine or any other visit www.stevessewandvac.com .
Jul 07, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Prolectrix 3 tier steam
Is the unit spraying ok? If not then the heater may be plugged. Other than that, you should fill the tank with hot tap water, the the heater will only heat it alittle more, you won't really see steam.
Jan 19, 2008 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
