SOURCE: ice maker failure
1) Check the filler tube which allows water to enter the dispenser through the back wall of the freezer. This tube may be frozen inside. You can pull the tube out gently and clear it. 2) The inlet valve may be faulty/blocked. Where the water connects to the water valves behind the fridge, try to swap the plugs around from the one valve to the other. They should be colour coded. Then try dispensing water. If water runs into the ice-maker then the ice maker valve is faulty/blocked.
SOURCE: Fridge won't dispense ice through door.
First take the hopper out and let it de-ice completely making sure that it is dry before re-installing it. Make sure that the auger moves when re installed with no ice in it.
SOURCE: my grass scorpion willn't start,I have changed
To make sure that you have the right plug,you need to specify the make and model number of your trimmer.The first thing you need to do is check and make sure you have spark to the plug.
Set the trimmer down.Take out the spark plug.Put the plug into the plug boot and set it on top of the motor.Make sure the switch is on,and pull the recoil a couple of times.Look at the end of the plug to see if you have spark,and make sure it is blue.
If you have spark,you might have a problem with your carburetor settings.
Testimonial: "thanks for the help elimated one question."
SOURCE: NO SPARK, HAVE NEW PLUG BUT IT CONTINUES TO FLOOD.
If raw fuel comes out of the muffler then you have an extreme flooding condition. There are no Model Numbers to tell me which type of saw we are working on but this works most of the time.
Try this: Remove the spark plug and BE CERTAIN the stop-switch is in the OFF position. Take the saw outside and bring a fire extinguisher with you! Hold the saw by the rear handle and let the muffler hang down to the lowest point possible. SLOWLY begin to pull the starter rope and observe the fuel being pumped out of the muffler. Gradually increase the speed of the rope pull and get as much fuel out as possible. When satisfied that it's dry, it isnt. Use compressed air to LIGHTLY blow into the spark plug hole and continue to pull the rope. (Might need 50 or more pulls!) Blow the spark plug dry and reinstall it.
Turn the switch ON, leave the choke OFF, and hold the trigger wide open. Start the saw and allow it to run at full throttle until it clears out all unburnt fuel and has good throttle response. If you need further assistance reply to this post with the make and model of the saw and I will be happy to help.
Hope this is helpful,
Dolf-
