Question about Kenmore 22422 Top Load Washer
Not draining and spining like it use to - Kenmore 22422 Top Load Washer
  • Kenmore Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Mar 27, 2011
Water not spining out
CLOTHES ARE SOAKED BECAUSE YOUR WASHER IS NOT DRAINING THE WATER.....ONCE YOUR MACHINE HAS DRAINED ENOUGH WATER OUT IT SHOULD START SPINNING AGAIN
Apr 16, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Water is not drining from the machine and when i drain it by hand i then start the machine it brings the water in but does not start the wash the eco and fast light come on flashing what can i do to solve...
shut iff the water disconnect the drain line and clean out the drain pull the entire unit out and disconnect the drain that goes into the drain pump clean and make sure there is nothing clogged in the drain line. remove the drain pump and do a bench test on the drain pump to assure the impellar is spining on the inside of the drain pump. Reconnect your unit but leave the drain line going into a large bucket turn on the water supply press for the unit to start its cycle after a couple minutes then press and hold cancel for three seconds this puts the unit into the drain function while the unit is draining the water observe how strong the flow of water is going into the bucket. If when you observe the impellar you do not see the impellar spining then replace the drain pump most likely you have something caught in the drain line of where the line plugs into your sink area. If you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in simiilar situations in the future Thanks Rick
Apr 11, 2011 | Dishwashers
Wasing mechine does not stop spining after draining water &keeps spining ,does not stop automatically untill i stop manually eitherby opening the lid or pulling the knob
You need to replace the timer switch on your machine. If you will post your Maytag model number I can direct you to the part you will need.
Happy Holidays
Dec 13, 2010 | Maytag Washing Machines
Not spining and water not draining
Access the water pump and look for plugged drain hoses or a plugged filter as well as a slipping impeller on the pump shaft--or even a dead pump motor. Spin usually will not occur if there is a high water level in the machine. Try draining the tub into a bucket, then see if it will go into spin mode. Hope this helps!
Jun 27, 2010 | LG WM2277H Front Load Washer
GE washer not spine
First thing you can due is to manually move the time to drain and spin mode. This will check your timer to see if your timer is working. If it start working then it is your timer. It will be your timer gone bad.
Dec 05, 2009 | GE Washing Machines
Pav2300aww spinning very slow,and not draining
In all these Cases it sounds like a faulty lip seal. These special seals have Sealed bearings inside. Water gets through the seal and into the bearing which causes it to thump (like a helicopter) or squeal very loudly. As far as draining, the machine has to reach a curtain speed before the pump can turn fast enough to work.
Nov 02, 2007 | Maytag Performa PAV2200
Kenmore 22422 Top Load Washer Logo
48 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
