Question about Gold Medal 2001ST Silver Streak Citation Popcorn Maker
Older model Citation 2001.Need wiring diagram for 3 main power wires(black,white and red,no green.) going to the bussbar(?),and the switches. They only need to be pushed back on to posts,but there are quite a few posts.It was taken apart for cleaning. How do I know for sure which posts?
    Genius:
  • 1,739 Answers
Suggest you contact Gold Medals Products Co. directly. You can make a web-based inquiry here:
http://www.gmpopcorn.com/contact-us.cfm
or you can call directly at 1-800-543-0862. If you watch the instructional video at the following link, they also include contact information and invite inquiries in an Owner's Manual has been misplaced. They may also be open to providing a wiring diagram.
http://www.gmpopcorn.com/tutorial-videos.cfm#
For future reference, available parts:
http://www.gmpopcorn.com/store/Results.cfm?category=5&secondary=38&keywords2=&Submit=Search
Posted on Mar 27, 2011
Need wire color diagram
Black = AC hot
Red = switched AC hot
Yellow = AC hot from a another source - another control panel as an example.
White = neutral
red w/white tracer = switched neutral
Green or green w/ yellow tracer = ground/earth ground
blue = DC voltage, ie, 12vdc, 24vdc
white w/blue tracer = dc common
Brown = AC 3 pahse - phase A
Orange = AC 3 pahse - phase B
Yellow = AC 3 Phase - phase C
shileds: think of current loops
2 cond
clear or red = +
black = -(neg)
3 cond
red = power (24vdc typically for transducers)
clear = + (signal output)
black = - (signal common)
Hope this helps, oh, and any panel I have design and wired this way is easily understaood by 99% of all service and electrical people I have worked with.
Apr 15, 2015 | Cars & Trucks
I need a wiring diagram for a viper 5701 alarm/ remote start to 2000 celica. I got it used with no instructions
http://www.broadbandreports.com/r0/download/1719726~1dde657f739f4c4af788bc21302e8a8b/Viper-5701-NewStyle-Install.pdf
Constant 12V+ Black/Red and White Ignition Switch Harness Starter Black/White Thin Wire in Ignition Switch Harness Ignition Black/Orange Ignition Switch Harness Ignition 2 Blue/Red Ignition Switch Harness Accessory Gray Ignition Switch Harness Tach Brown/White ECM Brake Switch Green/White Brake Switch Trunk Pin Light Green (-) Switch or Dome Light in Trunk Parking Lights Dark Green (-) Parking Light Switch Head Lamp Red/Blue (-) Right Side of Center Console at ECU Factory Disarm n/a Door Trigger Red/White (-) Driver's Kick Panel Door Lock Purple/White (-) Switch in Center Console Door Unlock Pink/Black (-) Horn Wire Blue/Black(-) Steering Column Windows Up LF=Green, RF=Blue (passenger's switch main) Windows Down LF=Red, RF=White/Blue
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
Dec 30, 2014 | Vehicle Parts & Accessories
Iam wiring a celing fan with a remote(added). The wires from wall switch are green(ground), white(neutral) black(fan) red(light)? Hooked to the wall switch remote. 2. Fan green, white, blue, black. 3....
I'm an electrician and will be happy to help you out. I need a little more information to answer accurately first. 1) What is the brand and model number of the "ceiling fan with remote". 2) If replacing / adding switches, how many locations will control the fan / light fixture? Please provide this info and I'm sure we can get this working very quickly.
Dec 12, 2012 | Dryers
I NEED A FREE SCHEMATIC FOR 2001 ACURA MDX STEREO MODEL 39101-S3V-A131-M1
Hi there:
I suggest to check this on 2001 Acura MDX Car Stereo Radio Wiring Diagram...
Radio Constant 12V+ Wire: White or White/Blue
Radio Ignition Switched 12V+ Wire: White/Red
Radio Ground Wire: Black
Radio Illumination Dimmer Wire: Red/Black
Radio Antenna Trigger Wire: Yellow/White
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 29, 2012 | 2001 Acura MDX
Need connection diagram Thks
The following diagram is for timers with green, black, white, and red wires:
If your timer is different, add a comment with model number.
Manual says:
Timer-black-wire to Hot; Timer-red-wire to Load (lights)
Timer-white-wire to Neutral.
Here's what to do
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground.
5) Turn on electricity, and push manual override button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Nov 14, 2010 | Woods 59007 Decora Style 3015105 Minute...
Need radio wiring diagram for 2001 mitsubishi eclipse
CHeck HERE the 2001 diagram.
Hope helps (remember rated this).
Jul 05, 2010 | 2001 Mitsubishi Eclipse Spyder
Need a wiring diagram for a sony cdx-gt08 it is going into a 2000 saturn sl2 I have the new wiring harness but need to know what wires go where
yellow to yellow main power wire
red to red key wire
black to black ground
speaker wires are green purple for rear speakers and white and grey for front speakers solid wire color is power and black lines is ground
orange is dimmer switch you wont need it
blue wire is for power anntenna your car shouldn't have it and blue with white stripe is remote wire if you have an amp it will shut off your amp when hooked up any other wire unnessary for your car some head units need a anntenna adapter to work good luck. remember ground before anything and disconnect the battery so you don't blow the fuse
Mar 13, 2010 | Sony XPLOD CDX-GT200 CD Player
I need a fuse diagram for 2001 Nissan Pathfinder
Do you want to install a new unit or wht ? u may use this reference to work upon ....
Get yourself a digital multimeter. Find the +12V constant, 12V remote, and ground. Connect them to the new head unit. For speaker wire get yourself a 9V toy battery and listen to poping noise. If you have a factory amp you need to power up the factory amp. Use the wiring diagram below to serve as a guide. Test your wire first before connecting them.
NISSAN
P o w e r
Memory (+12v Constant) Red
Ignition (+12v Switched) (varies) Brown or Green
Ground (-) Black (varies - most don't have one)
Illumination Red/White
Dimmer Red/Black
Power Antenna Green
S p e a k e r s
Right Front (+) Brown
Right Front (-) Brown/White
Left Front (+) Black
Left Front (-) Black/White
Right Rear (+) Blue
Right Rear (-) Pink
Left Rear (+) Red
Left Rear (-) Green
Feb 04, 2010 | 2001 Nissan Pathfinder
Radio wiring diagram
2001 Honda Prelude Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/White
Radio Ignition Switched 12V+ Wire: Yellow/Red
Radio Antenna Trigger Wire: N/A
pls rate
Jan 09, 2010 | 2001 Honda Prelude
10-3 w/ ground wiring diagram
your 2 hots phase wires RED and BLACK need to go to the L1 and L2 terminals,the white goes to the "N" neutral terminal and green or green w/yellow stripe is case safety ground---now at the breaker the RED/BLACK are connected under each one of two screws on the breaker the white goes to the NEUTRAL BUS BAR on the palel surface where all the white wires are already, also the green goes to the neutral bus bar,this only applies if this is the MAIN house power panel, is you wire it to a sub box panel then the neutral must be isolated from the sub panel chassis and ground can still be connected to panels case
Oct 04, 2009 | Dryers
Gold Medal 2001ST Silver Streak Citation Popcorn Maker Logo
229 people viewed this question
Top Gold Medal Kitchen Appliances - Others Experts
Oloyede Monsuru
john h
Tom Chichester
Are you a Gold Medal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
