Question about Cuisinart TOB-30 Toaster Oven with Convection Cooking
When i set the toaster dial to toast, nothing comes on. when i turn on the broiler or oven, the unit works fine. please help! the toaster oven is 4 years old and i it has been a great appliance. i prefer to fix it rather than replace it. the cuisinart service number was of no help to me. please help!
SOURCE: Cuisinart toaster oven modele no.TOB-30BWC, serial no.50421.
I have the same problem. It is due to a bad relay switch in the toaster. I have found that for now, my toaster will work if I leave it on the "TOAST" function rather than "OFF" overnight. I think it lets some current or voltage hit the relay and encourages it to work.
I will try to replace the relay and post a "how to" on that when it is done.
May all of your toasting be succesful.
Posted on Jan 21, 2008
SOURCE: Cuisinart Model TOB30BC Control Function
My toaster oven would not turn on. At first inspection it was not obvious what the problem was. But after sanding the contacts, and cleaning the contacts and cam with rubbing alcohol/cue-tips and a paper towel, as Caseytronic suggests above (let every thing dry completely!) It works like new now. Just be sure to turn off the power first as there is a lot of bare metal in the electrical circuit in here.
Posted on Mar 19, 2008
  • 5 Answers
SOURCE: broiler element
Its an on or off thing. No way to control the flow of electricity.
The elements are bigger than necessary to heat the unit quickly, the problem you have is a bad thing with food that burns easily but a good thing that makes these units come up to temp so quickly after turning on.
Unfortunately the only thing you can do is put more space between the element and your food or use aluminum foil (not suggested, its too close to the burners).
Eventually the contacks will fail (unless you are one of the lucky ones).
Good Luck
Posted on May 30, 2008
SOURCE: warning tone?
Have you tried turning the function button to off? This has worked for mine.
Posted on Sep 15, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Cuisinart Toaster Oven Broiler Not working properly
This is not a defect - it is just how the unit operates. You can set it to Broil, and the top element should not come on. Make sure the wire rack is turned upside down so that it curves inward and try one more time.
-Tha Mp3 Doctor
Posted on Jan 11, 2009
Black & Decker Toaster Oven - elements cycle on and off, which makes for a SLOW cook.
Oven has three modes: 1) oven mode cycles elements on and off to maintain a specific temp setting for up to 60 min. 2) toast should keep all elements on for a few min. 3) broil mode top elements only always on, up to 60 min. Make sure you have dials in correct position and use the toast timer.
Apr 17, 2014 | Toaster Ovens
KCO223 toast function not working
I too have the same KCO223 countertop toaster oven, and the toast function is not working. All other functions work fine, but the blue light won't come on in the TOAST mode setting.
Apr 09, 2014 | KitchenAid 12" Convection Toaster Oven...
-Tha Mp3 Doctor
Jan 04, 2009 | Cuisinart TOB30BW Toaster Oven with...
Re: Used Unit
http://personafile.com/Black-&-Decker-Toast-R-Oven-Broiler-TRO600-TRO603-TRO604-P0508755200417.htm
need adobe
Sep 14, 2008 | Black & Decker TRO603 Toast-R-Oven Toaster...
Toaster switch- Black and decker- TRO360TY6
I don't know if you can fix it but if you are good at basic diagnosis you can take off the right side and see if the toast latch is broken or perhaps out of place. This type of unit is not so easy to take apart and put back together. The parts fit is a bit strange.
May 14, 2008 | Black & Decker TRO360 Toast-R-Oven Toaster...
The contacts for these toasters fail. The plasic cam that depresses the contacts also can melt. The design is poor and no replacement parts are available. When selecting a setting, if the selection is not exactly perfect, the contacts arc and eventually fail. Unless cuisinart changes the selection cam to a solid state or relay, this failure will continue to happen during normal use. If your unit works properly do not switch the function setting while heating, this will cause the contacts to arc and erode the contact surface. This posting is applicable to the TOB-30BC, TOB-30BCC and probably all TOB-30XXX models.
Dec 26, 2007 | Cuisinart TOB-30 Toaster Oven with...
Black & decker toster oven
Black and Decker Toast-R-Oven Countertop Oven/Broiler Mfg Part No: CTO650
same problem here, toaster works, then when I go turn on the oven ........nothing!
Oct 29, 2007 | Black & Decker CTO649 Toaster Oven with...
Cuisinart TOB-30 Toaster Oven with Convection Cooking Logo
139 people viewed this question
Top Cuisinart Toaster Ovens Experts
D. E. Hev
Lawrence Oravetz
ray gallant
Are you a Cuisinart Toaster Oven Expert? Answer questions, earn points and help others
