Question about Emerson SR330 Remote Control
Emerson SR330 remote control (for ceiling fan) stopped working. Light switch on wall indicates fan is receiving power. Light goes on within remote to indicate fresh batteries in the remote. I have another identical remote in the house for same fan. Positive that remotes have not been switched. Is there something I can do (using the other remote) to switch the working remote to the other ceiling fan? Or something I can check in the working remote to verify that the other remote is, indeed, not working? Thanks for any help. Tim Glosson McHenry, IL
  • Anonymous Feb 01, 2017
    Try a Westinghouse 77870 remote. Worked for my Emerson cf4800. Replaced broken SR 330 remote
    Top Expert:
  • Emerson Master
  • 75,767 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts. ...
Posted on Feb 01, 2017
5 Suggested Answers
  • 5 Answers
SOURCE: Emerson Jumbo universal remote code search feature does not work
The Learn feature on this remote worked well for me. It takes a little time because you have to teach it the code for each button but it worked well for my cable remote, which I had never been able to get any universal remote to work with.
Posted on Jan 08, 2010
SOURCE: Cannot get a RCA Universal Remote to work on Emerson, EWT19S2
The code is 139
Posted on May 15, 2010
ercupa190
  • 12223 Answers
SOURCE: Emerson SR330 remote not working
1) Test the wires inside from remote control, could some wires is loose you need to solder.
2) Clean the contact batteries with special spray contact cleaner.
3) Retight the spring contact batteries for better contact.
4) After you did all this , if there are NOT function you mus open the remote and resolder any point for cool solder.
5) Otherwise you must reset the remote and put again the code go www.fitness.manualsonline. com or www.remotecodelist.com and download for free.
sincerely. God bless you
Posted on May 08, 2012
gopakumarg43
  • 75767 Answers
SOURCE: emerson ceiling fan remote won't work
Check the remote control for its infrared emission. Check its battery contacts for any rust or dust. Check it with fresh batteries.
Posted on Nov 06, 2012
I have an emerson ceiling fan with a light AND emerson SWQSRR controller.I can't figure out how the SWQSRR controller could control the fan and light seperately by only using 1 yellow wire?
Because it's a wall remote. Remotes will work fan & light with one hot wire. You should have a receiver in the canopy of the fan.
Oct 18, 2015 | Emerson Dryers
Wall switch control not working
Fan speed and light intensity are controlled by the remote as indicated in the instructions for the fan.
Dec 12, 2013 | Hunter 1912 Mission 21978 Ceiling Fan
Connecting wires
You are just missing one wire to all the circuits. The ones that work are good ... add the one wire that is not hooking up to the others to complete a serial circuit.
Mar 30, 2017 | Hampton Bay AC434-WB 52'' Ponte Vecchio...
Fan on the ceiling fan works, light does not, it is an Emerson unit wall switch only not remote control
Try pulling the chain once and then try the wall control. Is it a wall REMOTE or dual control? Do you have the number of the wall control?
Aug 31, 2013 | Hunter 52" Ceiling Fan With Light And...
May 08, 2012 | Emerson SR330 Remote Control
Monte Carlo ceiling fan and light not working
Even a brief power outage can cause amnesia in the receiver. You can try disconnecting power at the source and spending a few minutes removing the battery from the wall-mounted remote and pressing all buttons to eliminate the 'stuck button' problem. Reinstall the remote battery and reconnect main power to the unit. Test operation.
Lastly, there always is the possibility that some gremlin changed your original control setup.
Jun 23, 2017 | Dryers
Fan is Erratic
Ceiling fans with wireless remote controls have an electronic receiver installed in the fan, which controls the light, dimming, and fan speed. Sometimes the receiver goes bad and needs to be replaced. If you have had any power outages or power surges, they may have fried the receiver. I've noticed that my ceiling fan light turns on when the power is restored after a power outage. Now, whenever my power goes out, I shut off the light switch that powers my ceiling fan so It doesn't experience a surge to to the controller when the power comes back on. I've purchased new receivers on eBay and Amazon to replace my blown remotes and receivers.
Sep 07, 2008 | Hunter 22451 The Brookline Brushed Nickel...
Ceiling fan
If the switch is "OFF" on the wall, the remote will not control anything. The power has to reach the receiver first. If it worked before you turrned the swich off, than one of two things. Either
A: You blew a circuit to the unit or
B: Your receiver went out.
First thing I would do is check that POWER is getting to the receiver.
Sep 06, 2008 | Universal Remote Control Hampton Bay...
Emerson SR330 Remote Control Logo
460 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
