Question about Moultrie GameSpy 4.0 Digital Camera Deluxe
Same as many others, my I-60 also has LCD display problems. I see that they will either fix it or send the screen for me to replace myself. What I haven't been able to find is how difficult it is to do. Are there any written instructions or videos available to show exactly how it's done? I'd hate to screw mine up, but I'd also prefer not to wait the 6-8 weeks for their repair.
  • Moultrie Expert
  • 296 Answers
Moultrie will send instructions with LCD...easy to replace, but keep screws from each assembly separate...some are about same size but different threads.
Have to remove plug and remote card from battery compartment; remove (5) screws from face...pop it out...remove (4) screws from camera board...genty unplug camera board(3 plugin ports)...remove (5) screws from main board...gently unplug from LCD and lay over out of the way...do not unsolder...remove (4) screws from LCD..replce LCD with new one and reassemble in reverse order....make sure main board properly aligns with on-off-aim switch..harded than when board was removed...replace screw nearest this switch 1st...now continue reassembly...takes longer to type this than to complete task(one finger typist).
Posted on Dec 11, 2011
My lenovo LCD screen is flickering black and striped lines, how to get it fixed in Richmond Hill Ontario
Laptop computers have LCD displays that are sensitive to many things. LCD displays have faults that sometimes produce a flickering screen, lines, dots or a faint display. These screens are sensitive to magnetic fields or electronic items near the computer. Speakers, cell phones, lights and other electrical items are examples. Your display also could be flickering due to software issues such as the video drivers or hardware issues relating to the inverter going bad or the LCD screen itself needing to be replaced. Trace the cause of your problem to come to a resolution.
1.Turn off the computer. Disconnect all external devices. Turn the computer over (bottom facing up). Take out the battery and reseat it. Turn the computer on.
2.Reset your resolution and refresh rate.
Windows XP:
Right click an open area on your desktop. Click "Properties" in the drop-down menu.
Click the "Advanced" button at the bottom of settings tab. Another dialog box appears. Click the "Monitor" tab. Change the Refresh rate to your default, or 60 hertz. Click "OK."
Windows Vista:
Click "Start, Control Panel." Find and click "Appearance and Personalization." Click "Adjust Screen Resolution." Change resolution to the default, or 800 x 600. Click "Advanced Settings." Click the "Monitor" tab. Change the refresh rate to the default, or 60 hertz. Click "OK."
Windows 7:
Click "Start, Control Panel." Find and click "Display" Click "Change display settings" on the left side. Change screen resolution to 800 x 600. Click "Advanced Settings" in the lower right. Click the "Monitor" tab. Change the refresh rate to 60 hertz. Click "OK."
3.Check the computer's surroundings. Move away any speakers, fluorescent lights, fans, cell phones, radios and any other electrical device that can cause flickering. Temporarily move electrical items away from the computer to see if they are producing this issue.
If the flicker stops, put back one item at a time to determine what is causing the problem.
4.Connect an external monitor to your laptop computer to see if that screen is also flickering. If there is no flicker, then the problem is strictly with the laptop, indicating a possible hardware failure. Contact the manufacturer for a replacement LCD.
If the flicker continues, go to next step.
5.Reset/Update your video driver. Click "Start" and right-click "My Computer." Click "Properties." The "System Properties" dialog box will appear.
6.Click "Device Manager." A list of items will appear. Click the (+) sign next to "Display Adapters."
7.Right-click the video adapter and click "Uninstall." Confirm removal. Restart the computer. The video driver will automatically reinstall itself.
8.Check to see if the flicker still exists. If so, go to the manufacturer's website. Download and install the newest video driver and BIOS for the computer.
9.Restart computer once drivers are installed. Continue to the next step if there is still flickering.
10.Open up your display screen all the way. If the flicker stops by opening it a certain distance, it is the display inverter. If the flicker still exists, the LCD screen should be replaced.
11.Contact the manufacturer of the computer for more information and a possible replacement inverter and LCD display. This will depend on the manufacturer and the computer itself.
I hope you find it very helpful. Thanks
Sep 05, 2011 | Lenovo 3000 N200 Notebook
My Toshiba Portege R200-S2031 LCD display has developed lines across top and RH side of screen. What kind of fix is there?
First, give the screen a good cleaning using a microfiber cloth. This may inadvertently remove the lines even though they are in the display.
If this doesn't work, you'll have to send the laptop back for repairs. Screens are not a component that can be replaced easily (such as RAM or a hard drive).
If your laptop is not under warranty, scope out some local computer shops that can replace the display for you. Make sure to ask them for a quote BEFORE they do work on your computer, otherwise they have the right to deny you your laptop, once they fix it, until you pay up (a possibly very nasty price).
Mar 30, 2010 | Toshiba Portege R200-60 12.1 XGA LCD...
Cracked the lcd screen on my samsung t819 by T-Mobel. can i fix this myself? where do i buy the parts? where do i get instructions for repairing?
Hi,  I dont think you can fix it by yourself...... u can find more details here
Thanks for using fixya....
Nov 10, 2008 | Cell Phones
Can the lcd screen be replaced?
i have the same problem here. i sat down on my camera Doh! It need a new LCD screen, for sur, and i have a line whit a black/purple spot on the LCD. I open my camera and i separate the screen from the other part (white light) and i search instruction to continue the repairing, i can send photos of what it's look like, well im searching further instruction to replace the LCD screen.
Oct 18, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Samsung sync master 510 monitor display problem
It may be that the LCD monitor will not display all screen resolutions so you may need to change your resolution to match the desired resolution and refresh rate of the LCD. In your case the computer should be outputting:
1024x768 pixels
60 Hz
You can change these settings by right clicking on the desktop and clicking properties and they're under the settings tab. Change the screen resolution by moving the slider to the recommended setting (1024x768)
and
under the advanced button click the "monitor" tab - make sure the screen refresh rate is set to 60 hertz (60 hz)
May 21, 2008 | Samsung SyncMaster 510N 15" LCD Monitor
When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why might this be happening, and how can I fix it? my new lcd monitor blinks on for 1 second then off but my...
Refresh rate may be set too high for LCD
hook up crt monitor
1. Open control panel-display
Click on settings tab and set to a lower screen res such as 800x600
Try lcd
2. Open control panel-display
click advanced button
click on monitor tab
set screen refresh rate to 60 hz
Try lcd
May 20, 2008 | Computers & Internet
Cracked LCD Screen
Hi Chivetalkin,
You can get this fixed for $60 which includes repair, 90 day warranty and return shipping by one of the Repair shops listed on Fixya. This is if you reside the USA. Go click on "Repair Directory" at the bottom of this screen. Then on "Video Game Consoles", you will see the ads for Repair shops. The one I am talking about specializes in Playstations. Its not junked. I just repair one today. $60 is a great deal.
Nov 23, 2007 | Sony PlayStation Portable (PSP) Console
Broken Screen
The black liquid means the display is damaged beyond repair. That's the liquid crystal (LC) in the display (LCD). Where you send it for repairs would depend on the manufacturer, the store you bought it from, and if you have a service plan or not, but it's not something you can do yourself unfortunately. Been there too :(
Here's the link to the repair information page on the Palm website:
http://www.palm.com/us/support/contact/repair.html
Let us know how you make out.
Nov 13, 2007 | Palm Tungsten E2 Handheld
Moultrie GameSpy 4.0 Digital Camera Deluxe Logo
61 people viewed this question
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
