Question about Panasonic KX TG2267 Cordless Phone (kx-tg2267)
I cannot disable the mute .the numbers oh the base is pnlc1001vat sand under the serial 3 it says 8jaxa. I really hope you can help because I cannot call out no one hears me Help
I have an old Singer Treadle Sewing Machine but do not know where to locate the serial number to help find the value. Where should it be located?
Hard to say. Serial numbers can be found almost anywhere. Sometimes they are stamped in the metal of the base, maybe under the machine. Check the edge of the base if it is installed in a cabinet. Machines like this usually have only a serial number, no model number. The serial number will designate the model number on this list:
Singer Sewing Machine Company Serial Numbers
Don't expect it to be worth a whole lot of money. Most of the time, their biggest value is to the owner who can continue to use these awesome machines for many years yet.
Jul 30, 2016 | Singer Sewing Machines
Year wash machine was made. Model #11081821110 serial number c91910043
According to Appliance411.com date it:
Brand: Kenmore
Type: Clothes Washer
Country: USA
Model: 11081821110
Serial: C91910043 alertbubble-2.gif This product could have been manufactured on multiple dates. Personal assistance may be needed to date the product more accurately. According to the serial number this product may have been manufactured in Clyde, OH, May of 1979 or 1989. Based on the model number supplied, this product design may have been introduced to the marketplace in 1988 or 2011 in which case the closest date indicated by the serial number may be the actual manufacturing date for this product.
Feb 15, 2016 | Washing Machines
Find serial number
Serial numbers are usually placed on the base of the laptop or under the battery.
Dec 15, 2013 | Computers & Internet
Needs a code for stereo 5000 RDS EON.
Your going to need to contact Ford, Just the serial number will not do. These codes you cannot get online, you need to get it from the data base at the ford dealer.
Just thought I would give you some insight before wasting you time and money on something that will not work.
Sep 23, 2012 | Ford Mondeo Cars & Trucks
How do I clean the Baseplate
Good day!
The easiest way to clean the base plate of your electric iron is to use a sand paper (P200) p200 is the number of the sand paper that you need to use..
Scrub gently it in the base of iron until the real color of the metal is appear..If the color of the metal is appear it means the metal base plate is cleaned and ready to use..
Thank you and I hope this simple information help you..
Jun 17, 2011 | Philips Irons
Is there a website to find out if my Connex 3300 is under waranty using the serial number?
Connex has a one year warrent,Don will sometime give you a couple of months,thats who repairs them.A hint with connex,galaxy and general radios.Look at the serial number the first two digits is the year the next two is the month that it was made. Hope this helps.If you need Don's number please get back to me.Good Luck.
Jun 15, 2011 | Connex 3300 240-Channels Base CB Radio
Phone is on mute...how can I turn mute off
If by mute you mean disables your voice while talking - during a call press the left soft key to disable the mute option.
If the phone is silent, hold the upper side key for 3 seconds.
Hope this helps.
Jan 25, 2011 | LG VX5500 Cell Phone
Does anyone know if a serial number of 0499 is correct for a remington 11-48, 28 guage shotgun? I am looking at buying it from an individual and thought the number was rather low. Thank you.
It could be correct, the best way to tell is look carefully at the serial number and just in front and behind it..if it looks as if it's been filed/sanded and reblued stay away from it. Obliterating, or even restamping a serial number is a federal offense.
Hope this helps, Mark the Gunsmith
Please leave feedback, Thanks!
Jan 09, 2010 | Optics
Usb to serial converter
1. The USB to Serial has a comm port number, you can change that in Control Panel>Hardware and Software >Device Manager>Click on the adapter and make sure it's not disabled and try COMM 3 or a diffrent port you might have two conflicting each other.
I use Allen-Bradley and I also have to run it as admistrative privleges.
Hope this helps.
Jul 28, 2009 | Acer ALU 131 (91.AB861.001) Serial Adapter
How do I add an extension handset to my current config?
IF it was a used handset it was likely registered to another base. I just switched bases (1line to a 2 line base). I had to "deregister" the handsets from the old base. I am not sure if you can deregister if the old base is not present? With the old base plugged into power I hit the "function key" at the bottom left of the handset and scrolled down to initial settings. Under registration is "deregistration". I selected that and it put the handset back to its default out of the box. Then simply hit the mute button on the New base and OK on the handset. Worked for all 5 of my old handsets.
Hope this helps
Jan 27, 2008 | Panasonic KX TGA270S Cordless Expansion...
Panasonic KX TG2267 Cordless Phone (kx-tg2267) Logo
16 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
