I have a Hampton Bay Remote Control model DC 6020 that quit working. I have replaced the batteries and see the images on-screen but the fan does not respond. There are no obvious switches on the fan itself, no pull strings, and it is wired to a wall switch which is turned on. The light on the fan functions with the switch but not with the remote (it did before the batteries died). Does it need to be reprogrammed somehow? Thanks for your help.
Junoon007
  • 1011 Answers
SOURCE: Remote control not working
Dear Sir/madam,
Check these steps........
1. Adjusting the dip switches:
Each fan/remote combination is set to work on a specific frequency, much like tuning in a specifc radio station. Some fans allow you to set this frequency by means of a set of small switches called "dip switches". There is one set located inside the remote, and the other set would be position on the fan, with the remote receiver electronics. This would be either on top of the motor, or inside the switch housing or ceiling canopy. These switches "tune" the remote and fan (received) to the same "station" and therefore must be set to the same setting. If a fan is not responding to the remote you can check to make sure that the switches are set to the same setting in both locations, and/or try a different setting. They are also useful if you have two remote fans, you will want to be sure each fan is set different so the remotes do not interfere. Lastly, if some other wireless device is interfering with the fan (causing it to turn on and off seemingly at random) such as a garage door opener or cordless phone, you can try a different setting on the dip switches.
2. Universal remotes:
If your fan remote is lost or broken, many suppliers, including this web site, offer a universal remote designed to work with the majority of different remote operated ceiling fans. Many are also universal for operating televions etc so you can control all your leisure and comfort devices from one unit.
3. Replacement parts:
Unfortunately, outside of Universal remotes, general replacement parts are not available for remote control systems. Your best bet is to contact the manufacturer.
3a. Repair:
Also unforunately, most problems with remote controls cannot be repaired outside of what is suggested above. If you have problems, contact the manufacturer, perhaps the fan is under warranty, or parts are available. Otherwise chances are the fan will stay broken.
4. Converting to 3 speed:
One common question: My fan's remote is broken, can I just convert it to a 3 speed pullchain like other fans? Again unfortunately, if you have to ask the question, then chances are the answer is no. It can be done but there are no universal directions, it varies drastically from fan motor to fan motor, and requires a fair amount of technical and electronic skill. A few exceptions: If the fan has a "remote bypass" switch you can select it and then use a wall control (or pullchain if there is one attached to the fan). Or . . .
5. Add-on remote kits
Some fan remote systems are not built into the fan, they were an option added by the installer at an additional cost. Usually they consist of a remote receiver wired to the fan inside the ceiling canopy, and the fan will still have a pullchain that is not used. If this is the case then the receiver can be removed and replaced with another remote/receiver kit, or the fan can be operated as standard with the 3 speed pullchain.
thanks
good luck
Posted on Aug 07, 2008
  • 157 Answers
SOURCE: hampton bay fan, wall mount remote control
Hello burrow31. There maybe a switch located on the fan stating 'remote/manual'. Check your manual. Remove the battiers in your remote and short out the battery contact terminals. Reinstall the battiers, start the fan and after fan has reached set speed press & hold fan speed button for one second. Still no speed change contact the Mgfr. with model & serial #.
Posted on Oct 13, 2008
  • 37 Answers
SOURCE: Have a Hampton Bay ceiling fan that doesn't work.
I'm pretty sure that home depot does sell remotes for that brand, although you may have to buy a new receiver to go with it. Otherwise try a lighting store near where you live. They seem to be able to order things like that.
Posted on Jan 24, 2009
TheMobilian
  • 8220 Answers
SOURCE: Hampton Bay air conditioner wall unit doesn't cool
Might be the CAPACITOR
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 01, 2009
  • 691 Answers
SOURCE: blown capacitor on 4 year old ac hampton bay is
Not common, keep in mind compositor work almost like a fuse but restrict certain amount of voltage to flow through, power surge or unit overload from AC compressor kicking on and off can cause the resistor to fail; its parts of electronics working. My AC unit trip my main fuse box once in the great while, nothing surprises me when it come to electronics.
Posted on Jul 16, 2009
Hampton bay fan with remote quit working. Fan does not work with or without remote. It is just dead
  • Disconnect power at the source
  • Remove remote battery and press all buttons to eliminate stuck button
  • Reinstall battery. Apply power to fan
  • Check operation
The remote control may have failed completely
Jun 15, 2017 | Hampton Bay Dryers
Ceiling fan with remote control stopped working suddenly, ruled out battery for remote control, because I changed a new one, ruled out circuit since everything is working, I don't have a pull on the...
with Hampton Fans,, normally if the remote is good with a known good battery , and it quits working,, its the remote receiver, not the actual remote that goes bad. you can contact these guys I heard they have the part you need http://www.ceiling-fans-n-more.com/hampton-bay-ceiling-fan-parts.php
Sep 07, 2011 | Hampton Bay 24750 Huntington III Ceiling...
I have a Hampton Bay Cieling fan, model # FAN- DH L3H2003, and the remote control does not work. How can I get a replacement?
before you buy a new hand-held remote ... have you changed ALL the batteries. There's a set in the hand-held remote and batteries in the receiver, which is behind the fan's cowling. If you haven't changed them all, I'd do that before investing in a new remote control.
if you find, after changing all the batteries, you do need a new remote control, here is a link to one for all Hampton Bay Ceiling Fans.
http://www.homedepot.com/h_d1/N-5yc1v/R-100071965/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Hope this helped you. Please let me know. Thanks.
Jun 01, 2011 | Hampton Bay Heating & Cooling
Unable to get fan to respond to remote Hampton Bay 54
these fans must be reset as follows remove the battery from the remote manually turn off the wall power switch put the batteries back in the remote turn on the wall power switch press the remote buttons...if this doesn't work let me know
Jun 01, 2009 | Universal Remote Control Hampton Bay...
Fan and dimmer remote does not work
The remote is a Hampton Bay remote that should dim the light and fan on and off. I replaced the battery and do not have a red light when I press the button. Light and fan does not turn off with remote.
Mar 01, 2009 | Universal Remote Control Hampton Bay...
Jan 09, 2009 | Hampton Bay 52 In. White Redington...
Ceiling fan/light quit working with remote
Fan does not respond to remote, checked and replaced batteries in remote. No response, and unfortunately it is now well out o warranty but have the same fan in another room purchased same year 2003 which is moving along fine. Cannot find instruction book for either one. Please help. Thanks
Dec 11, 2008 | Hampton Bay (261025) Dual Mount Ceiling...
Remote control replacement.
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
You can also try ebay for OEM replacement fan remotes for the various brands including Hampton Bay...
Dec 10, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Remote control, changed battery, still nothing
You can also try ebay for OEM replacement fan remotes for various brands including Hampton Bay...
Nov 25, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Fan won't go on
It's probably the electronics inside the fan. They may need replacing. http://www.ceiling-fans-n-more.com/hampton-bay-ceiling-fan-parts.php
Jun 27, 2007 | Hampton Bay 04078 Avanti Ceiling Fan
Heating & Cooling Logo
171 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
