My skybox plus (in multiroom) installed april 2008... keeps coming up with no satalite signal being received... technical fault.. have to keep turning it off and on at wall socket also picture stutters a lot. My HD box in main room stutters and sometimes does not record programmes.. Be good if you could help rather than ring sky. Thx
Thx for offering expert help... but had to ring for sky engineer in the end who will be dealing with the issue next week.
Posted on Aug 05, 2008
Just purchased panansonic tc-p42g25 plasm. message on screen (channel not available no signal).
U tries cable or satalite boxes unplug,replug it back like an hour later?Now,the satalite or cable boxes should resetting itself back to the factory setting and upgrading it softwwares.The tv should have a signal now.If not,it is the cable or satalite boxes fault.Call the cable or satalite companies,request for a new box.
Nov 27, 2010 | Panasonic Televison & Video
Why is my gps losing its signal
Try connecting it to the computer and running an update from TomTom Home, there is a GPS fix that might help. Obviously the TomTom needs clearence to see the satalites in the sky otherwise try a hard reset with a pen in the bottom.
Jun 25, 2010 | Tomtom ONE GPS Receiver
Why wouldn't my ifinder h2o c gps not pick up any satalite signal
The most common reasons are thus
1) You do not have the right PORT and BAUD set
Consult the manual for the software.
2) You are noit in a location where the sky is visible to the unit)
move outside and away from buildings or electrical items
3) Your battery power is too low to get a fix
4) nThe SIIRF chip is damaged
Please rate my help++++Thanks for using FIXYA
May 20, 2010 | Lowrance iFINDER H2O C Plus GPS Receiver
My Matag Skybox compressor will not turn on. I can here it clicking and trying to come on.
HI. This is a strong indication of starter/overload relay failure. This clicking noise is coming directly fromm the relay device. it is damaged. this relay is the main starter of the compressor unit. It receives a signal from the main PCB. Once the power signal is received, the relay will regulate the starting, and stopping of the compressor, via control board and thermostat assembly. The failed relay will need to be replaced, asap. Once replaced, the unit will operate correctly. The relay is mounted on the side of the compressor. Once the bracket, and terminal wires are removed, you can gently pull it away form the compressor, to check the contacts and connections for corrosion. If any of the contacts or terminal connections are worn, replace them. Worn contacts, or corroded connections will not allow for proper current flow.
NOTE_ I would advise to locate the clicking. Make sure its coming form the compressor/relay location. There are some units of this nature out there that are fixed(compressor and relay intergraion). If this is the case, simply replace the entire compressor unit. If the clickiong is coming from the main control board(PCB), the PCB, will be the culprit.
Dec 01, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Hi, i am having problems with the multiroom on my AVR 630
Go into your OSD (on screed display).
Go to multiroom.
Change the SB AMPS from MAIN to MULTI.
Make sure you have only analogue sources, it will not amplify digital inputs for the MR.
Oct 09, 2009 | Harman Kardon AVR 630 Receiver
My samsung 40" lcd has developed a fault, it won't switch on! it keeps clicking on and off. Have you come across this problem before?
We are experiencing the same problem with our 40" Samsung LCD that was purchased in April 2008.We have already replaced the Sattelite DISH. It appears to be a short.
Aug 29, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
2003 hyundai tiburon. Left turn signal keeps flashing as long as car is on.
Bad news, it's your interior relay-fuse controler..... 800$ canadian money installation included at your dealer. I had this bug late
April this year.
I saw the tech change mine, it's so stupid to install, maybe you can buy it and install it your self
Aug 02, 2009 | 2003 Hyundai Tiburon
Cannot get signal
Your question is posted in a refrigeration section.
Try replacing the LNB, which is the device your cable(s) connect to at the dish.
Mar 29, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Acer Monitor Doesn't Receive Signal From Computer
can you test your monitor on another computer to verify the monitor is at fault? If the monitor is at fault its time for a new one, factory warranties on monitors are usually 1 year unless you purchased an extended warranty.Otherwise repair is usually more costly than buying a new one.
Dec 25, 2007 | Acer 17" AL1706B LCD Monitor
Televison & Video Logo
137 people viewed this question
Top Televison & Video Experts
