Question about Amana 22 cu.ft. Side-By-Side Cabinet Depth Refrigerator, ACD2238HTS
I have an Amana ACD2238HTS side-by-side that will not cool, I have checked the compressor and it is running as well as the condensor fan. Any suggestions??
HVACRH20
  • 237 Answers
SOURCE: amana side by side compressor not running
Cleaning the fins is always good. Is the fan by the compressor running? It needs to help cool the compressor. The description you mention sounds like the compressor is overheated and tripping the thermal overload on the compressor. See if you can turn if off for a day to let it all return to room temp then see if the compressor kicks on. If it was overheated it should run again for a while before overheating again. Let us know how that works and we can go from there.
Posted on Nov 30, 2006
22yooper
  • 828 Answers
SOURCE: KENMORE TRIO 2004 59675523400 REEFER/FREEZER NOT COOLING
It is the compressor that has failed. The hum is it trying to start and the following click is the overload protector opening. What is the temperature where the refrigerator is located? Allow the compressor to cool down before trying to restart it. If it still does not restart after it has cooled off it is done.
Posted on Jun 03, 2008
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
Techsim
  • 59 Answers
SOURCE: Amana SxS fridge not cooling or freezing
You have a sealed system problem. There is either a small leak or a restriction somewhere in the tubing. This isn't something you could've caused so don't worry about that. Unfortunately this isn't something you can fix yourself either. You require a certified refrigeration technician to fix this problem.
Posted on Nov 03, 2008
  • 18 Answers
SOURCE: amana side by side not cooling
any properly operating compressor will be hot to the touch,that is the way they evaporate water taken from defrosting. On fridge compressors there are two windings, 'run' and 'start'. the start winding will give it the initial boost and the run winding will keep it running for as long as it needs to. If the start winding gives out the fridge will do what you're describing because it's only using the run. you will need an appliance repair tech to fix it. On the other hand, refrigerators also need clean coils and air flow to operate correctly. Try removing any bags, boxes of cereal, brooms, etc. out from on top and around the fridge. Second check your coils, they are either on the back or underneath (behind the snap-in kick plate) and either vacuum them if you can, or use a product alled 'blast-a-coil' or other similar coil cleaning agent to clean them. That should work for you, if not, post again, we'll work on it!
Posted on Jan 22, 2009
Refrigerator not cooling.
No the evaporator fan not running has nothing to do with the compressor. I would suspect that you are freezing up over the evaporator because the fan is not running and when it ices up the air can not flow through properly therefore causing the refrigerator side to get warmer. Replace the fan and you should be fine. Take the back panel inside the freezer off and see if you are all iced up. If you bare then I would replace the fan . You also said the defrost heater did not come on. That will also cause a freeze up. Possible replacement of the defrost heater may be needed. Good Luck!
Jul 25, 2015 | Amana Refrigerators
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
Location of ac high pressure cutout switch on a 97 Plymouth voyager. Could it be a different problem? Had to replaced the PCM and a couple sensors because of a short in the wiring cluster. Now the ac...
HIGH PRESSURE CUTOFF SWITCH LOCATED ON AC COMPRESSOR DISCHARGE LINE LEADING TO THE CONDENSOR.THE HIGH PRESSURE CUTOFF SWITCH WILL CUT OFF THE AC COMPRESSOR IF SYSTEM PRESSURE RISES TO HIGH CAUSED BY RESTRICTION IN THE REFRIGERANT CIRCUIT OR OVERHEATED CONDENSOR.MAKE SURE COOLING FAN IS RUNNING WHEN THE AC SWITCH IS ON.THE COOLING FAN KEEP CONDENSOR COOL, IF COOLING FAN DONT RUN.YOUR AC WILL STOP BLOWING COLD AIR.HAVE THE REFRIGERANT SYSTEM CHECK OUT.MAKE SURE YOUR LOW SIDE PRESSURE IS 10 - 37 PSI. THE HIGH SIDE PRESSURE SHOULD BE 112 - 210 PSI. CHECK THE AC COMPRESSOR CLUTCH FUSE AND RELAY.
Jul 29, 2011 | Plymouth Voyager Cars & Trucks
I have an amana 90 home air conditioner w/ a amana prestige compressor. compessor runs but cooling fan not turning ,fan is not locked up and unit has power .of course w/fan not turning home is not...
Could be a couple of reasons for this:
1. Condensor fan motor bad.
2. Condensor fan motor loss of power.
3. Condensor fan motor capictor bad.
Unit has control for fan for low ambient operation and unit is low on freon telling fan its cold out side and dont run.
Hope this helps. wally
Jul 22, 2011 | Amana Heating & Cooling
Side by side doesn't cool down enough. Freezer
If the back panel on the inside of the freezer section is all snowed up looking you have a defrost problem, if the fan in the back of the freezer is not running, you may have a bad fan motor or a bad defrost terminator, hold freezer door switch closed with your hand and listen for fan.
If the fan by the compressor stopped on the outside of unit or the condensor coils are badly in need of cleaning it also will not cool properly.
Lastly, a leak or bad compressor may be the cause.(unit usually runs without shutting off, hope this helps
Jan 12, 2010 | Amana Refrigerators
Condenser shuts down after a couple of hours.
check capacitors, make sure the condensor coil is clean. sounds like the compressor is overheating. is the condensor fan motor still turning when it stops cooling. if not check low voltage wires to condensor, furnace and t-stat
Aug 19, 2009 | Amana Haier AP125HD Air Conditioner
FRONT OF SIDE PANELS FEEL VERY HOT
need to check to see if your condensor fan is running. this fan is located by the compressor. it will run at the same time the compressor is running. this fan keeps the condensor coils cooled off. if its not running then the unit tries to cool down through the cabinet
Jun 24, 2009 | Whirlpool ED5VHGXM Side by Side...
The freezer is cold but not cold enough to make ice
Check the back (interior) lower half of the freezer wall. If you see a frost build up, you either have an issue with your defrost cicuit (timer, heater, thermostat) or the evaporator (freezer) fan is not running. If there is not a frost build up on the back wall you either have a sealed system (weak compressor, leak or restriction) problem....or the condensor fan motor is not working. This would cause the compressor to overheat and shut down until cooled, and prevent the deep freeze.
Jun 05, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana DBR 2201 CW fridge, freezer good fridge not cooling
sounds like you have a bad evaporator fan motor, located in the freezer section ,it circulates the air up to the refrigerator compartment
Nov 30, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana 22 cu.ft. Side-By-Side Cabinet Depth Refrigerator, ACD2238HTS Logo
42 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
