Question about Sony KDF-E50A10 50 in. LCD HDTV
I have no picture. I have sound, but you can not increase or decrease the volume. I can change channel theu the cable box but still no picture. The lamp indicator light is not on. Sony KDF-E50A10 Serial 8524126
    Genius:
  • 1,112 Answers
Hi:
Just because your lamp indicator is not on does not mean that its not time to replace the lamp. This light only comes on if the lamp shatters in its housing, but if the lamp is worn or faulty it will not light the lamp light just no picture symptoms replace your lamp first.
Posted on Mar 27, 2011
No sound or power
IF ALL WIRES ARE CORRECTLY BEEN SETUP OR INSTALLED THEN THE NEXT STEP IS TO CONFIGURE THE SYSTEM TO WORK ON ALL SPEAKERS...
Before the setup of the speakers' channels
  • Press the SURR. button on the remote to select multichannel surround mode before adjusting the speaker settings.
  • In case of sound distortion, press and hold the SOUND button to select another transmission channel for the wireless rear speakers.
Setting Speakers' Channels
  1. Press 060227073157_11231.jpg to stop playback, then press SYSTEM MENU.
  2. Press 060227073234_11234.jpg repeatedly to select { Audio Setup Page }.
  3. Press 060227073211_11232.jpg060227073221_11233.jpg to highlight { Speaker Setup Page }, then press 060227073234_11234.jpg.
  4. Enter its submenu by pressing 060227073234_11234.jpg.
  5. Press 060227073211_11232.jpg060227073221_11233.jpg to highlight one of the options below at a time, then press 060227073234_11234.jpg.
    • { Speakers Volume } – Volume level setting for individual speakers (-6dB – +6dB).
    • { Speakers Delay } – Delay times setting in relation to the listening position/ distance for centre and surround speakers.
  6. Press 060227073245_11235.jpg060227073234_11234.jpg to adjust to the setting that best suit your surround sound needs.
  7. Press OK to confirm.
Notes:
  • 1 ms increase/decrease of delay time is equivalent to 30 cm change in distance. Use the longer delay time settings when the rear speakers are closer to the listener than the front speakers.
  • The test tone will automatically be generated to help you judge the sound level of each speaker.
Jan 27, 2008 | Philips Cineos HTS9800W System
My t.v. turns on for 20 seconds then it just cuts the picture off but i can still hear the sound
The way to test whether or not the television needs to be repaired is to do some things to it after it has cut off the picture. Making sure you can still hear the sound but no longer see the picture turn the volume up and down. If you can hear the volume increasing and decreasing, but you cannot see the volume indicator itself on the screen then you'll know that possibly the inverter(s) is/are loose or that the inverter board needs to be replaced. If you can see the volume indicator moving back and forth across your television screen then you might have a problem with your signal source i.e. your set top box (cable box/satellite tv box), your connecting cables or the connections themselves.
Apr 21, 2011 | Memorex MLT1921 19 in. LCD TV
No sound on sony tv
Your set may have a choice of audio sources and outputs in the basic (initial) setup since it is not uncommon to mute the internal speakers and get your sound from a home theatre system or receiver. Also, if you are using S-video connectors between converter and set, there is no sound path, this is video only, and you will have to add a couple of cables, likely with RCA connectors, between the two.
For reference: Audio cables: Red=right channel, White=left.
Sep 06, 2009 | Insignia Digital-to-Analog Converter for...
Channel numbers change but channel does not
The problem is in the "Guide-Plus" set-up. Go theu the set-up process again and when it asks you if you have a cable box select NO.
May 25, 2009 | RCA P61960 61" Rear Projection Television
Cant change channel
The up/down ch buttons will only go to channels that are set up in the tv....go to the menu....settings....and set up the channels you wish to view, once the channels are set up, the buttons will work
clarkco
Feb 27, 2009 | iLO 3200 32 in. LCD Television
Popping sound
In our area this is commonly the cable boxes. Does it occur on DVD or other sources? If not:
Reboot your scientific atlanta cable box by unplugging it from the wall for a few seconds, then plug it in and wait about 5 minuites for the time to come on again before use.
Dec 16, 2007 | Samsung DLP HL-P5663W 56" TV
P61927 troubleshooting white noise
a similar problem was discussed here a while ago, ill quote from there: "This problem may occur when some TV's are connected to a volume control converter. To correct this, decrease the TV's volume until the buzz disappears. Now use the decoder/converter volume control and increase the sound to a comfortable listening level." hope it will help.
Jan 13, 2006 | RCA P61927 61" Rear Projection Television
Sony KDF-E50A10 50 in. LCD HDTV Logo
100 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
