Question about Rheem Paloma Tankless Water Heaters PTG-74PVN Tankless RTG-74PVN
Hi. We have a Paloma Tankless Water Heater model no. PTG-74PVN-1 and we keep getting the error C 7-76 or C 8-76. We cleaned the filter but the problem is not going away. The hot water turns off after a couple of seconds of running. Can you e-mail us with instructions on how else we can fix this. Thank you.
Open following link for Rheem/Paloma/Richmond/Ruud tankless troubleshoot resources including error codes, self help, manuals, parts links, tips, and contact information.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 28, 2011
Paloma model no. ptg2-42pvp
Bad remote control, bad pc board, bad wire between pc board and remote control
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 26, 2014 | Rheem Paloma Tankless Water Heaters...
I have a Paloma PTG-74PVN-1 high volume tankless water heater installed in 2007. Recently, I am having hot water temperature problem, no error code is displayed, but it can not heat the hot water beyoun...
Even though you are not getting an error code, there are may be some diagnostics in the controller that can identify whether it's an electronic (controller/sensor) or a heat exchanger issue. I would contact Rheem tier-2 support.
Jul 01, 2014 | Rheem Paloma Tankless Water Heaters...
Paloma tankless water heater will ignite but shuts off after a minute or two on cold mornings. The first time it restarts it defaults to 120 degrees and the second time it defaults to 100. Seems to be...
No error code.
Incoming water is very cold.
Before calling service technician:
Catch up on maintenance.
Clean water filter.
Delime heat exchanger.
Check for crossover
Check water flow is high enough
Set temperature lower.
Install tempering tank.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#no-error
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#temperature
Gene
Feb 14, 2014 | Rheem Paloma Tankless Water Heaters...
Paloma tankless water heater model no PTG-74XP-2 error code c8
In several cases i have had to change the pcb board.... code 76 is no communication between remote thermostat and pcb..... this is a problem the first generation rheems seem to be having.... contact rheem if under warranty you will need to get pcb and program chip sent to you. Really need a experienced tech to install board and program it for you...... hope this helps...
Jan 25, 2012 | Rheem Paloma Tankless Water Heaters...
Thermostat flashes IL ? Model PTG-53PVN
http://www.palomatankless.com/owners/homeowner+trouble.lasso#28-11
The Controller displays error code "1L."
There is a build-up of lime in your Paloma.
Contact your plumber to service the Paloma by flushing out the lime.
Also search u-tube for flushing lime out of tankless.
Dec 29, 2010 | Rheem Paloma Tankless Water Heaters...
My paloma tankless keeps failing with a code of
SINCE U DIDN'T PROVIDE A MODEL NUMBER, THE BEST I CAN DO IS GIVE U THEIR PHONE NUMBER:
1 800 873 3507
Dec 08, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
PALOMA PTG-74PVN-1 Code C8 12 my water heater
C8 is the last stop in the point of burner ignition and a total of eight error codes. Error code 12 is a supplemental code that means your LP gas supply is too low...have your LP tank service and try again.
HTH,
Mike...
Dec 06, 2009 | Rheem Paloma Tankless Water Heaters...
I have a paloma ptg-74pvn and the digital temp. display keeps shu
How reliable is your AC? With the digital r/c connected, every time the heater recovers from power outage it's in the OFF default state. If you can not fix the power issue, disconnect the remote control. The w/h will recover in the ON state.
Nov 13, 2009 | Rheem Paloma Tankless Water Heaters...
I have a paloma tankless water heater about 3 years old model PTG-74PVN and it works for 2 minutes and shuts off with error code C4 and 13 flashing. (City water pressure is fine)Can anyone help? Thanks...
I had the same problem with my Paloma a year and a half after installation...contacted Rheem customer service (800-432-8373) and they recommened a local installer in my area. The technican diagnosed the problem as the "flow control valve"; he managed to get Rheem/Paloma to cover the part under warranty...I only had to shell out the money for the install.
Nov 03, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Paloma PTG 74PVN Tankless Water Heater
did you check the filters on the the water valves, i am not exactly sure about your codes that are shoeing but if you could read it and post them, i know on some of the units 76 means there is low water pressure and the filters are behind 2 caps one on each side above the shut off valve take off the caps and remove the screens, clean them and replace them ,, make sure you turn off the water on both side first or you will get wet
May 18, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Rheem Paloma  Tankless Water Heaters PTG-74PVN  Tankless RTG-74PVN Logo
667 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
