Question about Kenmore Washing Machines
Kenmore washer will not empty water - Kenmore Washing Machines
  • 822 Answers
Pump .............or blocked pipe or drain..............
cheers
Posted on Mar 27, 2011
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
My Kenmore H2t front load washer won't drain and
Hallo there
So it will not do what it is told. This happened to my Candy machine the other day. It was finished and I opened the door, out came water and I got 5 towels on the floor to dry up the water. Closed the door again and put empty water on, it emptied the water, stopped the machine and put spin on and it made it.
My experience ,learned the hard way, to wait long enough after the machine stops as well as between changing programs.
I this will be of some use to you.
Kolbrun
Apr 15, 2012 | Kenmore Washing Machines
98702 Stacked Washer / Dryer Your question about 98702 Stacked Washer / Dryer has been posted. Mom has a Kenmore stackable washer. She ran water in for a load and the water ran out of the washer and onto...
Get the control panel off and remove the water pressure tubing. Blow it out and reconnect to pressure switch. Remove water so that pressure can once again build inside the tube. Retry>
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 22, 2011 | Kenmore 98702 Stacked Washer/Dryer
We put a heavy blanket in the washer and the load stopped suddenly with a washer full of water. It wouldn't spin or empty and made a weak sound but nothing worked. We had to manually empty the water....
Usually that means the drive belt is loose and slipping. You should be able to tighten or replace the belt.
To test the belt you have to remove the washer back.
Jul 29, 2011 | Kenmore Washing Machines
My Kenmore series 80 washer does not fill up all the way with water even when it is on full load.
on most top load washer the level of water should be no more tha 13 inches of water on a empty tub.the rule of thumb is there should be between two to three holes visible above the water line
Sep 17, 2009 | Kenmore 24032\24036 Top Load Washer
The washer fills and empties but no spin or agitate
I assume by empties you mean it pumps the water out.
That being the case you will need a way to make sure the timer is sending power to the motor. If it is emptying by itself then you have a siphon problem and need to raise the drain hose exit above the top of the washer or install a siphon break.
Eric
Jun 08, 2009 | Kenmore 23012 Top Load Washer
Kenmore front loader ,, fab softner will not empty
your cold water may be the issue, turn off your water and check the screens to the cold water side. make sure the machine gets cold water.
Nov 02, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
