Question about Sony Cyber-shot DSC-W55 Digital Camera
I turn the camera on and the screen is blank with a message saying access then it beeps a number of times and then a message comes up saying turn the power on and off again. I have taken battery out and back in but this has not altered the problem. Please can you advise
  • 6,831 Answers
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Mar 27, 2011
When I turn the camera on it says access , the lens goes in and out then I get a beep and message reads turn the power off and on again. I've done this over and over again and it still won't work. ...
One thing to test before going to repair, make sure you are using a fully charged and correct battery for your camera.
If so, the camera will need repair. This is a common problem and can be fixed. Teleplan Camera Repair does a great job and their blog is also very informative.
Repair: http://www.teleplancamerarepair.com/Sony_Cyber-shot_DSC-W30
Aug 04, 2010 | Sony Cyber-shot DSC-W30 Digital Camera
I have the Canon PowerShot A520 Digital Camera and
you may need to take it in to the camera place to get the internal batery for the clock replaced also you may need to up load the driver program for the camera
the memory card may need the safe slide to be mooved
Jul 11, 2010 | Canon PowerShot A520 Digital Camera
Turn on the power and the camera beeps 3 times?
hmmm... accesses the card ok? 3 beeps on a computer is a memory thing... might try a differnt SD card... Otherwise, probably is trash, cameras are so cheap that having a shop repair them is just not worth it.
Peace,
Mar 28, 2010 | Samsung S85 Digital Camera
Every time I try to turn the camera on it beeps and the screen says access... then says turn the power off then on again. Why?
This problem is related to optical zoom motor,The part detail is given below:
Part No. Description
A-1231-924-A LSV-1160A
Replace the said part number and your camera work fine again.
Thanks for using fixya.
Jul 29, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
ACCESS???
1. Please make sure that you're using a fully charged battery.
2. Please try Initializing the Camera. To initialize the Camera.
First, press the Menu button on the Camera to display the Menu items.
Then, select the SETUP option under the Menu.
Then, select the SETUP1 under the SETUP.
Then, select the Initialize under the SETUP1 option to Initialize the Camera.
If the issue still persists, then try Power Resetting the Camera.
First, turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the Power switch for 30 seconds.
Then, reinsert the battery pack into the Camera and turn ON the Camera.
If the issue still persists after performing the steps provided above service of the Camera is required.
Jun 17, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Sony cybershot 4.1 megapixels mpegmovie vx dsc-s90
Your camera has problem in Lens mechanism. If Lens doesn't open properly, camera will not show picture at all. There would be Loading Motor section demaged in Lens mechanism and it needs to be replaced to work camera OK.
Now come to blue screen in playback mode, This model doesn't have internal memory, so you need memory stick/ card to see previously taken pictures.
Jun 21, 2008 | Cameras
Yeah, try to tapp the lens assembly with finger when it keeps going in and out.
May 05, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Error message
my camera did the same thing, lens retracts 3 or 4 times, and then proceeded with an error message "turn off and on again". I pressed the power button probably about 10 times, didn't work, so then i gave it a good smack on the top of the frame a few times while repeatedly pressing the power button and it did the trick. Hasn't gave me problems since...hope it helps
Mar 29, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Sony-cyber-shot dsc-w50
Lens unit is faulty, may have had sand or damage at some time, focus assembly inside the lens is not focussing
Sep 16, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
27 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
