Question about Refrigerators
Cannot remove plastic cover for lightbulb. Have removed 2 screws but cover won't cone off.
  • 822 Answers
Try moving cover to the right..............
cheers
Posted on Mar 27, 2011
How to remove lightbulb?
There are several different types.
Some, usually the larger ones, have to be pushed in and then turned counter-clockwise, then pilles out.
Others, typically the smaller ones, are simply pulled straight out.
Then there are the ones that are installed in removable sockets. These sockets have to be removed from the back of the light, and then the bulbs are removed from the holder
Sep 23, 2015 | Cars & Trucks
How to change shifter lightbulb
Pry out bezel around shifter very carefully, remove clip/screw for shifter handle after pushing down small chrome cover on bottom of handle. Remove shifter cover (screws or clips hold it in place) to gain access to blub. 1/8 turn to left on socket and it is out
Sep 01, 2014 | 2006 Nissan Sentra
How to replace lightbulb
Is this a countertop microwave or an over-the-rang (OTR) microwave? If it's a countertop model, you need to completely remove the outer case to get to the lightbulb. If it's and OTR microwave, there usually is an access cover located behind the grill vent. You can remove that grille vent by removing the 2 to 4 screws above the grill vent. Then either slide the grill vent 1/4" to the left to remove it, or else (depending on the model), just pull out the top of the grill vent, followed by the bottom. Then you should be able to see the lightbulb access cover. Usually there is 1 screw that you have to remove. But unplug the microwave before you to any further! Now remove the screw, lift up and remove the cover, and you should be able to get to the light bulb.
Aug 10, 2014 | Kenmore Microwave Ovens
I can't remove the speaker
Remove the protecting grill in front. Check if the cone is still connected to the rubber band. If not, remove the screws around the speaker. Open the casing itself. Do not forget the screw in the middle of the battery compartment. Remove the bottom cover. Disconnect the 2 wires on the speaker and take out the speaker. It will come out with the plastic protection around it. Looking at the cone now, push up the Carton cone and keep it in place by putting some tissue paper or small cloth underneath. Clean the cone first. Use some rubber cement on the outer edges of the cone and press the rubber back on the cone. Let it dry for an hour and then remove the tissue / cloth, so the cone goes back to its normal position.You can use some extra rubber (those pre-glued strips that you would use to fix a bicycle tire) to make it extra strong. Remount everything back in place and voila....it works again!If your cone is not damaged, the casing most probably does not seal good anymore. Tighten all screws a little more and use plastic electrical tape all around to seal all joints. The bass is produced inside the casing itself and pushed out via a horn. If it is not closed off well, your bass sounds grumpy.
Oct 08, 2012 | Harman Kardon Go + Play Portable Speaker...
Two questions how do you change a low beam lightbulb in a cadillac srx 2005 and why in early morning starts does the same car hesitate to pull away?
1. Remove front wheel well front half splash guard, each side. There are about 2 screws and the guard pulls forward to seperate from the rear half.
2. After removing the splash guard, you can access one screw that attaches the front fascia, each side.
3. Then about 6 plastic push pin type screws along the bottom, underneath.
4. About 5 push pin type screws on the top.
5. Fascia should then simply pull forward. It is a bit bulky and an extra pair of hands is helpful.
6. Then there are 3 screws to remove the headlamp assembly. Unclip the wiring harness.
7. Then 4 screws to remove the bulb access cover plate.
Dec 24, 2010 | 2005 Cadillac SRX
The brush on my hayden 6000 supervac is not rotating when power is on and i can't figure out how to open the vac to get to the belt. help please
First you will want to remove the light cover. this can be done by pusing as you look at the front of the powerbrush on both the left and right side of the head.
There you will find the lightbulb and 2 screws to remove. Remove both of the screws and turn over to pry with a screwdriver at both the sides of the powerbrush to remove the top cover.
Once you have the lens cover off you will also see in the plastic the belt change instructions.
When you want to put the top cover back on, it will act much like a hinge, hook it on to the front of the head where the brush is, and snap it back into place at the back.
Nov 04, 2010 | Hayden Industries SuperVac 6000 Central...
How do you change the lightbulb inside the oven??? I cannot get the cover off!
AROUND THE COVER THERE IS A CARBON BUILD UP CLEAN WITH OVEN CLEANER AND YOU SHOULD SEE THE SMALL SCREW HOLDING THE COVER IN REMOVE IT AND GENTLY PRISE IT OFF ..
Nov 22, 2009 | Kitchen Ranges
How do I replace the lightbulb. NEFF B1442 series 3 Oven
1. Some glass covers are held on with a wire clip over them. It should be visible.
2. Some have a 'ring' which is screwed to the oven cavity around the light cover. On that design the screws need to be removed from the surrounding retaining ring.
3. On may later model the glass light cover screws into place. Those covers should 9hopefully) be able to be unscrewed the same you you'd remove a jar lid.
Nov 07, 2009 | Ovens
The stop ligths is off
try changing the lightbulb by removing some screws on the back you can take the plastic covering off and then you would be able to remove and change the lightbulb
Jul 01, 2009 | 1996 Chevrolet Beretta
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
