Question about Sport & Outdoor - Others
After a storm last night, I have a ps 16 comm error. all of the pumps on the primary control unit work, but the fountain pump and light on the secondary box does not work. when you turn on the fountain, the relay does not make a click.. the fuse was blown in the unit, it only had a single 3 amp fuse. I replaced it and turned the power back on and the fuse immediately blew out again. so there is either a surge from the main unit to the secondary unit, or a surge in the secondary unit.. How should i proceed to find out? as i said, all is working on the primary unit as far as the controls, menus, timers, and pumps connected to the first sets of relays.
  • 68 Answers
SOURCE: Commercial Hobart dishwasher
I can't imagine a bad relay board would blow a fuse. The relay board would need to make a bad connection to ground to blow a fuse -- I don't see it.
If you could supply me with the ML#, I'll take a look at the wiring diagram and give you an educated answer.
Not that I recall clearly which fuse is for the drain solenoid, but the two sound related. If a drain valve is obstructed by debris, it will heat up the coil and short it out. I don't know the spec'd ohms, but I would suspect at least 50. I'd check it.
Posted on Jun 10, 2008
  • 13 Answers
SOURCE: Kawasaki Vulcan Classic 1500
Was any of the wires cut through?  Just a shot in the dark, but try unplugging and re-plugging the wire connector going into the clutch lever.  If that doesn't work submit more information.
Posted on Jan 03, 2009
  • 5 Answers
SOURCE: sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Posted on Mar 19, 2009
  • 225 Answers
SOURCE: my water pump works when u test it on battery but
go back to the water pump and test for voltage if no voltage trace wiring back to fuses sounds like broken wire.
Posted on Jun 07, 2009
  • 4234 Answers
SOURCE: Fuse replaced but blows againwhen remote clicked for CT32SL14
This is a problem with the main poiwer supply. It could be simply a shorted rectifier diode or more complex. Without taking measurements inside the set or at least seeing what the condition is of the board, there is little we can do to help. This unit shoul dbe brought to a service shop with a request for a detailed estimate. Armed with that info, we should be able to guide you through the actual repair. Expect to pay $50 or more for the estimate.
Dan
Posted on Aug 20, 2009
Davey pressure pump will not run, was running fine last night
You checked the power supply and it works, you may have to take it aprt to clean the magnegtic inters or replace the inters or pump because broken shaft, trash gets in them and stops the rotation of the pump blades. But really need more info on the pump.
Oct 24, 2013 | Garden
Pressure pump will not run
Thats a good chance of whats happened, but it could of gotten hot and triped a safty switch; look for a small red button in control panel or pump.
Error code 105
Info for Error code 105
105. (01101001) Phase 2 to 6 - Comms Error Time Out
These faults are reported when the Display Module detects an error in
the communications between the Display Module and the Motor
Control Module.
Note: If the product is an IW, the wrong Motor Control Module may
have been fitted. Replace with a compatible part.
Phase 2 to 4 and Phase 6
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module.
Tertiary Source: Rotor Position Sensor (Phase 5 and 6).
Action: Replace Rotor Position Sensor. If this corrects
the fault, refit the original Display Module or
Phase 5
Primary Source: Pump
Action: Measure resistance of pump. If resistance is
less than 33 ohms, replace pump.
Secondary Source: Display Module.
Tertiary Source: Motor Control Module.
Quaternary Source: Rotor Position Sensor.
Sep 26, 2013 | Fisher and Paykel Washing Machines
The pump is on a timer and last night during a storm the pump stopped working?
Try connecting the pump to the mains and bypassing the timer.
If the pump works then the timer is faulty and needs to be replaced.
If the pump does not work then the pump motor is faulty,
Jul 20, 2012 | Pentair Pool & Spa
Hi there, we had blackout last night and our ac unit mitsubishi electric has an error code E6 is coming up! how can i fix this problem?Thanks
E-6 Indoor/outdoor transmission error. error.
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Jan 23, 2011 | Heating & Cooling
I have a 1993 VW Passat VR6, My problem is when I try to start it, I have no spark from the spark plugs..What could be the problem or how do I fix this?????
GO TO THIS SiTE TO CHECK THE FUSE BOX!
http://vwtech.no-ip.info/images/golf/post90.gif
This are the FUSE and RELAY number SLOT!
Fuse No. Description Ampere Rating 1 Headlight, low beam, left 10 2 Headlight, low beam, right 10 3 Instrument panel lights, license plate lights 10 4 Glove compartment light 15 5 Wiper/washer 15 6 Fresh air blower 16-valve only: Air conditioning 20 7 Taillights, side marker light, right 10 8 Taillights, side marker light, left 0 9 Rear window defogger 20 10 2.0 16-valve only: Fog lights 15 11 Headlight, high beam, left,High beam indicator light 10 12 Headlight, high beam, right 10 13 Horn 16-valve only: Radiator cooling fan 10 14 Back-up lights, washer nozzle heaters 10 15 2.0 16-valve only: Engine electronics, stabilizer valve, cold start valve 10 16 Instrument panel warning lights, 16-valve only: Multi function indicator 15 17 Emergency flasher switch, turn signals 10 18 Fuel pump, oxygen sensor heater 20 19 Radiator cooling fan, air conditioning 30 20 Brake lights, cruise control 10 21 Interior lights, digital clock 16-valve only: Luggage compartment light,multi function indicator, central locking 15 22 Radio, cigarette lighter 10
Relays Relay No. Description 1 Air conditioning 2 Open 3 Digifant control unit 4 Load reduction relay 5 Low coolant level control unit or Open 6 Emergency flashers 7 Rear Wiper 8 Intermittent wipers 9 Seat belt warning system control unit (possibly headlight warning too?) 10 Fog lights 11 Horn 12 Fuel pump (except diesel)Glow plugs (diesel) 13 Radiator cooling fan after run (except 16-valve)2.0 16-valve: Starter interlock relay 14 Automatic trans., coolant temperature indicator,starter interlock relay (except 2.0 16-valve)2.0 16-valve: Radiator cooling fan after run 15 ABS pump relay 16 ABS relay 17 Heated seat control unit, driver 18 Heated seat control unit, passenger, or power seat circuit breaker 19 Automatic transmission 20 Open 21 Power window relay, ABS hydraulic pump fuse 22 ABS valves fuse 23 Air conditioning, power seat fuse 24 Power window fuse
Nov 17, 2010 | 1993 Volkswagen Passat
Correct placement for Flotec Utility Pump
should be in drain basin to work properly and check that float moves freely.
May 26, 2009 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
Carrier Infiniti system, system maufunction on primary display
Call a Carrier service comapny and have them investigate further, when system malfunction comes up on the user interface usually there is a substantial problem.
Either that or the User Interface has gone bad and needs to be replaced
May 14, 2009 | Carrier Heating & Cooling
Sport & Outdoor - Others Logo
46 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
