Question about VinoTemp VT-TC32G
My Vinotemp TC32G fan is rattling around, not spinning, just rattling.
2 Suggested Answers
  • 5 Answers
SOURCE: Do you carry the thermostat for vinotemp wine
You can purchase replacement parts for virtually all Vinotemp coolers directly from Vinotemp. Some parts are listed/available on Vinotemp.com (http://www.vinotemp.com/Browse.aspx/446/Replacement-Parts) But otherwise, just give their service department a call or shoot them an email and you can confirm the part number and purchase the required part.
Posted on Oct 04, 2010
Where can i order of P6R8MC OR0503 relay?
http://www.appliancepartspros.com/mcf-ptc-starter-312200500017-ap5671689.html
Aug 26, 2016 | VinoTemp VT-TC32G
Vinotemp 28teds doesn't work, no fan, temp or light, what's up
Probably somewhere in its history there was an incident of total failure.
Dec 31, 2013 | VinoTemp 28Bottle FreeStanding Wine Cellar...
My vt-tc32g will work for a bit and then stop
If it cycles very irraticly then the temp control could be out of calibration and will need to be replaced. There usually is about a 5-10 degree difference between on and off for the temp control and will be worse with no product in the cooler
Sep 06, 2012 | VinoTemp VT-TC32G
The unit is on a hardwood floor and there is water damage to the floor. The unit appears to be dry now. Could it have a leak that can't be seen?
The potential for water leaking to the floor is probably still there. Open the door of the unit, look in the back and you will see a white plate; that is the evaporator. When the unit is running, there is a light frost that forms on the front and back surface of the evaporator; sometimes the frost can get a bit thick because of air laden moisture infiltration or the frequency of door opening. That frost eventually will melt and drain from a drain hole right underneath the evaporator. If that drain hole is plugged up, water will eventually leak out from under the door. Keep that hole clean and patent and also check the state of the water collecting pan underneath the the unit. That might solve your water problem.
Jan 21, 2011 | VinoTemp VT-TC32G
Do you carry the thermostat for vinotemp wine cellar TC32G?
Jul 23, 2010 | VinoTemp (TC32GB)
Tc32g unit gets too cold
Too cold usually means temp control switch is out. Temp controller turns the compressor on and off based on the temp. It can be a mechanical switch or a circuit board, but good chance it has failed.
Mar 29, 2010 | VinoTemp VT-TC32G
Fan Won't Spin
Is it humming like a stuck motor or rattling, like a loose fan. If it's rattling, the fan could eith be loose on the motor or, the center hub could have broken loose.
Aug 10, 2009 | Carrier 38CKC036 Air Conditioner
It stop working and there is a clicking noise in the back area.
first unplug unit for a few hours . remove back . under there there is a compressor and a fan plug in did the fan motor start itself ? if not touch blade a little , did it start now ? if so you have a bad fan motor ( real common with this cooler ) if the fan allways ran no problem you have a bad start relay on the compressor ( this is another real common problem ) you need to order a fan motor and or a start relay from vinotemp . on an order i made a week ago they had the motor but not the relay (relay kit ) it was on backorder , you may get lucky i just looked i do not have the phone #with me but you can fiind it on there website (thats where i found it ) good luck ps :on second thought dont play around , order the fan motor and the relay together no mater if the fan is working or not , even if it is it will not be for long Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 26, 2009 | VinoTemp VT-60 Wine Cooler
Vinotemp LG 16TEDSW
It sounds like you're having a control board PCB issue. You can often get replacement parts directly from Vinotemp. Of course, I'm sure the issue will be easier to resolve if your unit is still under warranty. If not, they should still be able to sell you the parts you need and then you or a qualified repair person can replace whatevers needed. Instructions for some service issues can be found on the Vinotemp website in the Customer Service section. You can also request service for your unit there. Hope you get it fixed!
Jan 09, 2009 | VinoTemp (VINO-24GN)
Vinotemp wine cooler won't cool
It sounds like your control module is bad. Vinotemp does list the replacement part as available at a cost of around $35
Nov 14, 2008 | VinoTemp (VT60GNV) Wine Cooler
VinoTemp VT-TC32G Logo
102 people viewed this question
Top VinoTemp Refrigerators Experts
Vernon Taylor
Ilia Bichin
Are you a VinoTemp Refrigerator Expert? Answer questions, earn points and help others
